Question about Toys
Yiboo uj422 helicopter won't charge
I plug it in to charge and about 2 min later the green light goes back to red, and when i use it, it flies for about 20 sec
  • 2,119 Answers
Sounds like your batteries have gone bad.
Posted on Nov 10, 2014
Testimonial: "I just put in new batteries"
SOURCE: The instructions say that the
It's a typo in the instructions. The helicopter must be turned off to be chaged
Posted on Jan 04, 2009
SOURCE: Yiboo AH-64 3D RC Mini Apache Helicopter
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
Posted on Feb 10, 2010
SOURCE: MY YIBOO MINI HELICOPTER ONLY SPINS ROUND AND
Same thing happened to mine if its the same problem. Check if one of the rotors is chipped.
Posted on Feb 11, 2010
micromatikal
  • 2777 Answers
SOURCE: Brookstone Silver Bullet Helicopter: When I
This is a battery fault, unfortunately pretty common. How old is this helicopter? It may still be under warranty.
Let me know, there is not really much of anything you can do on your end... you are doing everything correctly for sure.
Tim
Posted on Oct 09, 2010
SOURCE: right out of the box
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Posted on Dec 28, 2010
Need to find out what model of yiboo helicopter this is to find the blade
Measure the length and width of the blade you have and then go on line to the Yiboo Helicopter website and talk to the technicians. Have the helicopter handy if they have other questions..don't forget to ask them for a parts list for your model (You'll need it if you fly it)!
Dec 28, 2012 | Toys
Helicopter charging red light not blinking
The charger may not be plugged in all the way in either the helicopter or the wall.
Aug 22, 2012 | Toys
Volitation 9053 flashing green light when charging brand new out the box
I have the same problem. I watched the video on helix.com and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
Nov 17, 2011 | xheli 9053 Outdoor Volitation Metal...
The gyropter will not charge when I plug it in
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
Aug 14, 2011 | JCPenney Gyropter RC Helicopter
How will be i identify it is fully charged battery i charged for 45 minites.But the battery will not be fully charged. please send me the solution for this problems
If using usb charger use usb port on back of desktop, not data port in front, also most laptops do not have fully powered usb ports due to battery consumption. The wall charger, or a usb charger plugged into a usb/ac adapter (like included with ipods and kindles or sold seperately) is your best bet for reliable charge.
Charging unit should have a light on it.
When charger is plugged into power source and not helicopter, the light will show you {#1} what it looks like when battery is fully charged. Typically this is steady on, and usually red. (sometimes green) When you connect helicopter to charger, the light will change (usually goes dark) to signify it is charging {#2}. When light comes on fully (or completely returns to #1) then charging is done. (Note: charging using a laptop usb or a front side data port usb can take several hours.) Watch the light on charging unit when you unplug helicopter, if it gets brighter, helicopter is not charged, plug it back in. Make sure to let battery cool for 10 minutes after every charge and 10 minutes after every flight, and never run battery all the way down. As soon as you can't maintain altitude, land and power off. Fully draining a Li/Po battery weakens it's ability to hold a charge and can ruin it.
If all else fails, replacement batteries are available from Amazon and many others, they are cheap (around 5$) and very easy to install with no soldering and just a small screwdriver.
Hope this helps
r
Dec 31, 2010 | SYMA Toys industrial Syma S032 Ready to...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
Me and my dad have 2 yiboo Uj4708 helicopters. We need to know how to change the frequency on them so we can fly them simotaniously. We can change the frequncy on the remotes, but don't know how on the...
Turn both helicopters and remotes off. Then switch the remote to another channel, either a,b, or c, turn on HELICOPTER FIRST, turn on REMOTE second. Move throttle up and down, helicopter should start responding.
Dec 26, 2010 | Toys
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Toys Logo
119 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
