Question about Vacuums
Can anybody recommend a reasonably priced vacuum cleaner that works well and either has bags or is easy to empty?
Can anybody recommend a reasonably priced vacuum cleaner that works well and either has bags or is easy to empty? It must be easy to push and pull. I want answers based on personal experience, not something from an ad. I don't need it to deep cleaner, just make the carpets reasonably presentable. There are no pets in the house.
  •  Brian Main
    Brian Main Nov 10, 2014
    The Eureka I have is Model #AS1104A
    Master:
  • 464 Answers
We use both a Eureka Multi-cyclone and Dyson DC07. They are both easy to use and empty and do a good job. The Eureka was several hundred dollars cheaper.
Posted on Nov 10, 2014
  • 2 more comments
  • Gerry Rains
    Gerry Rains Nov 10, 2014
    Brian, I cannot find anything called a Eureka multi-cyclone but I found many different multi-cyclonic models. Some of them were light, some weren't. Some got rave reviews but they tended to be heavy. Could you please tell me what the Model name and number of your vacuum cleaner are?
  • Tiffany Bowe
    Tiffany Bowe Nov 16, 2014
    Bissell Powerforce bagless, I got it for $40 on sale at walmart and it is the best vacuum I have ever bought. It has removeable washable filters. When these get dirty it starts not picking up very well but they are so simple to clean in you sink let dry and put back together. It's very very simple my 6 year old could figure it out I'm sure. Excellent vacuum.....my mom had a 400 one that is now in the garage because she liked mine so much! Hope this helps.
  • Tiffany Bowe
    Main Information Product Title: PowerForce® Helix™ Bagless 12B1 Model #: 12B1 Similar Models: 1240, 1240U, 1240V, 1240W, 12B1C, 12B1D, 12B1E, 12B1R, 12B1U, 12B1V, 12B1W Quantity: 1 List Price: $47.84 Rewards Points: 48 Warranty: 1 year limited Special Features Powerful, easy to use bagless system Experience powerful suction with the Helix System for longer lasting pick-up performance Large dirt cup holds more dirt for more room to room cleaning Dual Edge Cleaning provides Surround Suction® to clean hard to reach areas like baseboards and around furniture Microban® Protection: No Surface Type: Carpet, Upholstery, Low Pile Carpet Power Rating: 10 Amps Heater: No Filtration: 3 Stage Cleaning Path Width: 13.5" Cleaning System: Helix System Weight: 15 lbs Power Power Rating: 10 Amps Power Source: Corded Heater: No Air Flow Indicator: No Brush System: Rotating Brush On/Off Switch: No Power Cord Length: 20' Automatic Cord Rewind: No Filtration Filter: Style 9/10/12 Pre-Motor Filter Filtration: 3 Stage Clean Filter Indicator: No Dirt Collection Surface Type: Carpet, Upholstery, Low Pile Carpet Cleaning System: Helix System Cleaning Path Width: 13.5" Surface Height Settings: 5 Dual Edge Cleaning: Yes Bag Type: Bagless Easy Empty™ Dirt Cup: Yes Dirt Sensor: No Specialty Tools Multi-Use Tools: Combination Dusting Brush/Upholstery Tool, Flexible Crevice Tool Reach Extension Tools: Extension Wand Other Specs Color: Midnight Blue Carry Handle: Yes Headlight: No Soft Bumper: Yes Belt Type: Style 7/9/10/12/14/16 Replacement Belt
  • Tiffany Bowe
    Basically the above important info is it's 15 lbs and the model is 12b1 PowerForce Helix Bagless
reddevil6
  • 1673 Answers
SOURCE: dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
Posted on Jan 09, 2008
SOURCE: suction
Don't panic! Easy fix!
I was having the same problem, but I removed the base plate from the bottom of the vaccum (5 screws on mine), revealing the roller and the engine. Just behind the roller is an intake tube. Mine had a piece of wrapping paper stuck in it causing everything else to clog up.
Posted on Dec 09, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
Empty Henry vacuum bag
pull the two locking tabs on either side of the body of the cleaner out
lift the motor off the base
remove the secondary filter
pull the bag opening back off the hose tube
when replacing the bag make sure the bag is fitted all the way back against the body over the hose tube
reassembly is the reverse
Nov 22, 2015 | Henry Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
Release button to empty cylinder wont work cant get it off manually
Hello, the canister empty function works by pulling a long plastic rod that moves the catch on the bottom access door. It sounds like either the puller is stuck or that the rod may be broken. If the puller does move upward when pulled, then the later in most likely. You can check by removing the Torque screws and pulling the top section off very gently, because the canister really needs to be opened and removed first, do this outside to avoid a dirt spill in the house, either way I would look for a used canister from another machine, which is really a much cheaper and less dirty option.
Mar 07, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
After changing the bag on my riccar it is very hard to push'
after putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Apr 22, 2013 | Riccar 8955 Upright Vacuum
How do I install a new bag into the electro lux oxygen vacuum
I had the same problem. I was worried about pulling on the cardboard, that it would break. There is a little yellow lever and I could not understand what it was for. Finally, I decided to go ahead and pull on the cardboard and slide out the bag. It worked. I am not sure the yellow lever does anything, although it might help to push it to the right. The bag slid out and the new one slid in.
May 15, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Doesnt ****
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 30, 2010 | Hoover U6311-930 Power Drive Bagged...
My Miele bags for S241 vacuum cleaner have just been replaced by the new HyClean bag. There are less in the box and you can't empty them either - a mesh of cords being in the way. I knoe you're not...
The old style bags are not available any longer. The new HyClean bags have a larger capacity then the original style. You get the same amount of capacity out a box of the new bags as you did the box of the old. I know they are still expensive. I would recommend calling an internet company and trying to buy a quantity of bags at a time to see if you can get a little better price.
Sep 28, 2009 | Miele S4210 Sirius Bagged Canister Vacuum
My vacuum died. It won't turn on. It is not the outlet. Is it a blown fuse? How do I replace the fuse? Where does it go? This vacuum is a little over 2 years old. My older Hoover WindTunnel STILL works and...
It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
Jul 09, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Bad on/off switch hoover U6476
Feb 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Canister Pulled Vacuum Cleaner
go to thehooverstore and search for your machine. there are exploded diagrams for all hoover machines with parts lists and prices.
Sep 04, 2007 | Hoover Portapower C2094 Bagged Canister...
Vacuums Logo
50 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
