Question about Amana Dryers
My amana dryer dosen't dry very good? Have took it apart and cleaned it. wasn't that much lint in it? Cleaned the lint exchast by taking it all apart and vacuumed it.
Mod. NED 4500VQ2 SER. m21654056
  • Amana Master
  • 2,119 Answers
Posted on Nov 10, 2014
  • 883 Answers
SOURCE: Cleaned vent hose, dryer still taking forever to dry clothes.
you have a family of squirrels living in the rest of the vent tube which is leading outside...check vent outside. I once had flying squirrels come into my house through the dryer vent! My dog had a kitten.
Posted on Jun 04, 2007
jsrock516
  • 5911 Answers
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Posted on Jul 28, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Posted on Mar 25, 2009
  • 686 Answers
SOURCE: frigidaire dryer stuck in cool down mode
post model number
Posted on Apr 05, 2009
richroth
  • 9472 Answers
SOURCE: my amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
Posted on May 23, 2012
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
I have an Amana Dryer, ned7200tw. It was taking forever to dry clothes, took twice through per load. We replaced the heating element 2 days ago, cleaned all the lint while it was apart, and it is still...
Did you check the trap door on the outside of the house where the vent goes outside. If the door is stuck or the end of the vent is blocked you will get excessive dry time like you are having. Also possibly a thermostat inside starting to go bad and sticking.
Mar 01, 2015 | Amana Dryers
My amana dryer smells like something's burning
May 22, 2012 | Amana NED7200TW Electric Dryer
Clothes dryer produces black soot when drying and leaves clothes darkened
lint build up is on heat element canister. take dryer apart on clean with a good vacumm cleaner. unplug first.
Mar 02, 2010 | Dryers
Not drying - indicator show AF
you might need to replace the heating element
Sep 05, 2009 | Dryers
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Dryer is taking several cycles to dry clothes.
Very common problem. You need to call a duct cleaning company and tell them to clean your dryer vent. Rule-of-thumb: dryer vents should be cleaned every couple of years to prevent them from being clogged with lint and causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is to go outside where the vent exits the house and feel the air-flow. should have adequate air-flow.
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
I think The dryer takes very long time to dry clothes
Good luck :)
Feb 24, 2009 | Amana NED7200TW Electric Dryer
My dryer is taking too many times to dry my clothes!
hello tmivie,
When you say you took the dryer apart and cleaned out all the lint, did you also check the vent system all the way to the outside and at the end where the duct exits your house? If you are getting heat and limited or restrictive air flow, your drying time will be excessive.. There may be other problems such as the blower itself isn't functioning properly to move the air out.. Since your dryer is electric, you can detach the vent line from the dryed and turn it on.. feel the exhaust flow to make sure it is pretty robust then reattach the vent and check for about the same flow at the exit point of your duct system. Let me know if that solves your problem or not so we can look at other ideas..
Regards,
Rick
Dec 01, 2008 | Crosley CDE6000 Electric Dryer
GE Electric Dryer
that is one thing I have learned, don't take anything apart that you dont need apart. Clean with shop vac-it will suck it out.
Jan 04, 2008 | GE DWXR483EBCC Electric Dryer
Dryers Logo
71 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
