Bon air 9000 btu mini split ac/heat pump will not turn on
Bon air 9000 btu mini split ac/heat pump will not turn on with the remote. How do I manually turn it on? I do not see any "On" switch on it....strange...
  • Sunny
    Sunny Feb 11, 2015
    Found out that the Circuit board on the Outside evaporator is ruined (lizard got in) and need a new one. Any help...?
    Problem Solver:
  • 10 Answers
Sounds like the solenoid on the reverse valve is not functional, manually take it off and see if there is a magnetic field on it
Posted on Nov 10, 2014
Sparks001
  • 4 Answers
SOURCE: We have a 9000 btu portable frigidare air
How high up is your exhaust hose in relation to the unit - if it is too hight, the pump may be struggling to discharge the water.
I assume this is a vented model, where you have a large diameter pip exhausting air outside (Around 110mm wide) if so, is there also a smaller pipe to carry the condensate water?
Posted on Jul 08, 2009
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
icemelts
  • 246 Answers
SOURCE: Celiera 12000 btu Mini-split ac unit blows cool
It's 'possible' but not likely that you need additional freon.
What is more likely is the 'filter' (for inside coil) is dirty and possibly the coil itself - and/or - the outside coil is dirty.
I would check out the filter - if dirty - I would change it and would also inspect the inside coil. If it's also dirty I would clean it the best I could (with a brush of some sort).
I would also check the outside coil and clean it if need be.
Hope this helps.
Posted on Jun 11, 2010
SOURCE: Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR
i want know that how can connection wiring of indoor panel and out door panel 0f carrier 42qg24-c / 38qg24-c ?
(i need wiring diagram)
Posted on Jul 06, 2010
User manual. Where can I get a copy
Pioneer Mini Split AC - Wholesale Prices, Open to Public‎
Adwww.highseer.com/Pioneer-HVACInformation & Support
Download Manuals, Parts Diagrams
Sales, Technical Brochures & More
Nov 08, 2015 | Pioneer Ductless Mini Split INVERTER Air...
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
I HAVE A SPLIT ROOM AIR CONDITIONER, OLDER STILL PACKED BUT WITHOUT MANUALS. THE LABEL GIVES MODEL NO: AG0AH09BWOG1 , SEARCHES DON´T GIVE RESULTS. CHEERS
The number may indicate its a 9000 btu ac/heat pump,just by knowing other types of ac Numbering is it 2 pieces IE;
the outdor condensing unit and a wall mounted evap.do you see a refrigerant line set ,are there connection points for refrig lines etc.
dan
Mar 02, 2009 | GE Heating & Cooling
Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
