Question about CORSAIR CX Series Modular CX750M 750W ATX Power Supply
PC Power Issue
Upon turning my PC on the motherboard light is sold green and boots up fine. However when I turn my pc off then boot it up the next day it wont start? I usually have the same issue when unplugging it and switching it off by the mains. Now I am not sure if its a PSU issue and whether I need a new one?
  • 104 Answers
It does sound like a psu problem, if you are comfortable with opening your pc then (remember to use anti static wrist band rubber matting etc) and remove the psu and give it a good dusting (as the dust does collect in on the fan and inside the unit itself (please be careful when working with this unit as it is a power unit and can be dangerous) put unit once cleaned back into the pc making sure you reconnect everything carefully. (if you are not sure rather take it to a professional as you can do some serious damage to your mother board and or peripherals. but this should give a few more boot ups ultimately you could replace it with a new PSU.
Posted on Nov 10, 2014
  • MR ROBERT BROLEY
    MR ROBERT BROLEY Nov 10, 2014
    I have removed the PSU and have tried compressed air to clean any dust and also checked my dust extractor tray which is at the bottom and its really clean. I may just replace the PSU but I am unsure of which model to go for.
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: first boot up works fine,
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 21, 2011
  • 343 Answers
SOURCE: Hello, I recently bought a CX500
Did you check the battery on the motherboard? The battery should read 3.3 volts with a volt meter. If you don't have a meter you can try swapping the battery from another motherboard. Or have the battery checked at a Radio Shack store. Also if you still have the Seasonic try hooking it back uo temporally outside the case to check if it is a power supply issue. If the old power supply failed while being connected to this motherboard it could have damaged it.
Thanks for using FixYa
Posted on Jul 02, 2011
How can i boot up when there is a beeping noise
A beeping computer can generally mean some bad/corrupt memory and the PC will not boot until it is remedied. You will need to power off the PC, ensuring you unplug the power cable each time. Take out a piece of memory, at a time, leaving the other memory, still in the PC, depending upon how the memory is read based upon the motherboard reading the dim (memory) slots, power back up and re-try. It is basically a process of elimination, until you find the bad memory. Also, depending upon your Dell model, there maybe some diagnostic lights at the rear of the PC to also indicate where the issue may lie, albeit, memory, motherboard, graphics, etc.
Jan 22, 2012 | Dell Inspiron 530 Desktop Computer...
I have a dell dimension 3000 that kept powering on and off on and off repeatedly. Its xp and I thought it was the power supply. I tried installing a correct power supply but nothing happened at all. I...
What you can do is to reseat all cables that are connected to the CPU. Also, try reseating all components connected to the motherboard. that includes the RAM, Video Card, etc. Here's the proper way to reseat them.
First, remove everything from the motherboard then install them one by one. Once you installed something, try to boot it up. until you have isolated the cause of the problem. The most common cause of this kind of issue is the memory(RAM).
That's what you need to do before you throw your desktop away.
Hope this helps!
Sep 13, 2011 | Dell Dimension 3000 PC Desktop
My HP Pavilion dv5 1125nr laptop won't boot up. The screen never lights up when the power is turned on, the little hard drive light next to the power light doesn't flash at all (normally it flashes...
check by removing the battery then put it back again power it on, or without battery power it on directly then check, if still the same problem, the fault is in the motherboard of the laptop, better take it the service center or consult some technician in your area
Aug 02, 2011 | HP Pavilion dv5-1125nr Notebook
My pc doesnt load every time I want to turn after i boot the power and press 1st, 2nd, 3rd and 4th boot... in the screen I can see Dell is loading but doesnt move, i try to press F12 for boot and the...
Are you Sure that the computer model is Dell Optiplex GX260? Because looking at the manual diagnostic lights are found at the back. and the fault can be determine If the ABCD lights are yellow or green. But None the less 2/3 Depicts a hard drive problem while 3/4 depicts a memory issue.
Hard drive Issue:
1. Disconnect all non essential cables at the back of the computer. Leave only the mouse, monitor and keyboard. See if it boots up normally
2. If it boot up fine. try plugging one peripheral at a time until you find which peripheral causes the computer not to POST (Power on Self Test)
3. If you still getting problems, Follow these steps
4. To access the BIOS you must tap F2 or delete key upon turning the computer on
5. Try to look for the Hard drive if it is detected by BIOS if not got to step 9
6. Look for Boot Sequence or anything that is associated Boot
7. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
8. Save the changes and Restart
9. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
10. If Step 9 did not work I think you need to replace the Hard drive
Memory Issue:
1. Open the chassis of the computer
2. Try taking out all memory modules
3. Rub the metal contacts of all memory with a pencil eraser
4. If more than one memory. Put one memory first and turn the computer on. If it turned on add another memory and turn the computer on. Repeat these steps until you determine which memory is faulty or all memory module contacts needs cleaning
Jun 16, 2011 | Dell OptiPlex GX260 PC Desktop
Alienware Aurora Desktop does not boot, has no HD activity
If the activity light on the front of the tower is not glowing than it can be an issue with the power supply of the PC. Try to open the tower and try to reseat the Power supply cables and check.
You can also try to Reseat the RAM (memory) sticks. If you have 2 Memory stick you can just try to boot the pc with the help of one stick and vice versa. If still the issue persist you can try to do a test on the Motherboard. Simply take out the Memory cards and power on the pc . if you hear a beeping noise than the Motherboard is fine and if you dont hear a beeping noise that it is a faulty Motherboard.
Jul 06, 2010 | Alienware PC Systems Alienware Aurora High...
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
I have a Dell XPS M1710. PC will not boot, no
On the mother board is an internal battery (round, silver type). Try replacing it and see if that fixes the issue.
Dec 23, 2017 | Dell XPS M1710 Notebook
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
Steady amber Power light
You are looking at a new mother board. I would take it to a certified technician shop, so they can run a stress test on the motherboard for final benidiction.
Aug 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
CORSAIR CX Series Modular CX750M 750W ATX Power Supply Logo
65 people viewed this question
Top CORSAIR Computers & Internet Experts
David Payne
David Payne
Are you a CORSAIR Computer and Internet Expert? Answer questions, earn points and help others
