Strong oil smell off riello 40 oil burner when starting up
3 Suggested Answers
SOURCE: riello burner will not pump oil to nozzel to burn.
Revisit the photocell:
1. Check if you connected the socket end, into the two pins properly, as it is possible to miss a pin.
2. Try to borrow a working photocell or use yours in another burner to make a determination.
Posted on Jan 03, 2009
rollandrolls
SOURCE: riello oil burner runs for 2 seconds and then stops ??
1. Take off the red cover which is held on by a screw.
2. Use an allan key to loosen the screw facing you.
3. Turn on boiler. The boiler will draw the oil through and bubbles of air will escape through the screw you have loosened.
4. When it is just oil coming through the cracks around the screw, re-tighten the screw and turn on again.
Posted on Feb 15, 2012
I recently installed a new furnace ..with a Riello 40 series burner models f3 how many litres Of fuel should I be burning pr hour ..
The Riello 40 Series F3 Burner has a firing range from .50 Gallons per hour to .95 gallons per hour. The burner is adjusted by the tech for the proper BTU input.
Mar 09, 2018 | Heating & Cooling
Riello f5 oil motor will not start
Is your electric air shutter opening? That causes power to come on. Here's a link.
http://www.weil-mclain.com/sites/default/files/field-file/sgo-riello-oil-burner-manual_0.pdf don-ohio (:^)
Jan 19, 2017 | Heating & Cooling
I have a riello burner 40 it will fire and come to temp but wont refire, goes into lockout
My first guess would be that it sounds like a clogged oil filter, air in your fuel line, is piping overhead, or leak in a fitting or connection causing it to loose it's prime when running.
I have also seen primary controls that are faulty do this, watching the complete cycle of the run time will give you more clues as to when the control actually locks out. Does it lock out during the run cycle as the boiler reaches temp.? If so,check for oil line and suction issues as stated above.
If it locks out on start up after reaching boiler set temperature, if hitting reset right away burner doesn't start and lock out occurs with no motor engaging, check motor (Note: Some motors when HOT will not kick in when powered, but after they cool down naturally they start, motor shaft may also be bound up tight, replacement is necessary) if burner motor spins but does not fire, check for fuel flow to the nozzle, be sure oil is pumping to the nozzle, if it is, clean cad cell eye, and check transformer for spark, if all is good.. replace primary control.
Disclaimer:
Of course all this information is technical troubleshooting information and should be performed by a Licensed Technician, not knowing how to properly test for flame failure can cause injury, fire or worse! Consult a technician in your area if you are not proficient at oil burner repair!
Nov 21, 2014 | Honeywell Biasi B10-3 Boiler ,riello...
Have strong oil smell when riello 40 oil burner starts up
I looked at the drawings from this unit and it is completely sealed between the heat exchanger and supply air. So you should not smell oil at any time you have a leak some place look for that .
Nov 09, 2014 | Heating & Cooling
Riello burner
You need to measure the manifold pressures before and after the gas valve and adjust accordingly to fuel used, 3.5" NG or 11" Propane.
Nov 06, 2013 | Honeywell Biasi B10-3 Boiler ,riello...
Riello oil burner problem - Furnce blower starts on thermostat call but Riello burner needs to be manually reset for ignition.
BUrners trip on safety for a number of reasons. When the burner is working you should not see any smoke in the smokepipe. If you do then the settings are off and adjustments need to be made. If the unit does not actually light then the problem can either be with the nozzle, the oil pump or filter. Lastly, you may not be getting spark. If you get more specific I may be able to guide you through step by step.
Feb 02, 2011 | Heating & Cooling
Riello oil burner RDB Hi everybody i have a Riello oil burner RDB . I am wondering is there a way to make it more oil efficient?
does it have the air damper installed? You can add a magic heater to the flue and dump heat into your basement.. thats maybe 5 to 10 percent more efficient
Sep 25, 2010 | Heating & Cooling
I have a riello oil burner, starts to fire up for a few seconds and fails , fuel is ok any ideas please
i have a riello oil burner 40 F5, starts to fire up for a few seconds and fails , but then it will start for a few minutes...then shuts off... house is not being heated sufficient. There's hot water but after one shower the water starts getting cold....fuel is ok any ideas please
Nov 28, 2009 | SySTOR Systems (400S52) Burner
Riello 40 F5 oil burner, on boiler, intermittently running
with a forced draught burner the fan motor would be checked via a pressure switch. if the pressure switch is not set correctly or the fan is too weak the contacts will not be made in the switch and the burner will lockout. if the damper is not open enough when the fan runs then the air supply will be too small for the switch to make. check to see if you have a capacitor on the fan windings if this is faulty then the fan will fail intermittently.
Jan 19, 2009 | Heating & Cooling
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
