Question about Canon imageRUNNER 2545i AllInOne Laser Printer
Canon ir 2545 ----> eror E000196.what i do ???? please help me
    Champion:
  • Canon Expert
  • 234 Answers
Error in eprom access.Replace DC controller PCB
Posted on Nov 12, 2014
SOURCE: my canon copier ir 2016j give an eror report code
- check the connector of the fixing film sensor.
- replace the fixing film sensor.
- check that the fixing film is not broken or out of place
Posted on Nov 25, 2009
canontech
  • 1219 Answers
SOURCE: I replaced the black tonner on my Canon ir 3320n & this eror sho
try to set the toner a few times more, this error code is developer trouble.So it could be that toner isnt recognized, not properly inserted, or you have some tape leftovers on toner, or you have broken developer unit, or ...
Posted on May 06, 2010
SOURCE: CANON IR 3570 eror code E000019
E019-0000 ? Waste toner bottle full for 2000 copies. Empty or replace waste toner bottle.
This is aimed at the office worker who is handy with a screwdriver.
Open toner cover. To the right of the toner bottle is a screw. Remove this screw fully. The next screw is tricky to describe. It's on the outside of the copier, under a rubber disk. To the left of the toner bottle. If you have both screws removed you should now be able to pull the toner cover to the left and pull towards you. The whole front cover should come away. The waste toner bottle is the big thing in-front of you, full of black powder.
Best to wear a P2 dust mask. Toner is not toxic. Otherwise you would not be able to touch a copied document. Toner is about seven microns across and can cause respiratory distress, or an asthma attack.
Do not use a vacuum cleaner to **** up toner. Most vacuum cleaners do not have sufficient filters to remove toner. All you will do is spread it around the office for others to inhale. This type of toner can also damage your vacuum cleaner.
To replace the front cover. Put the pegs on the right of the cover into the frame. On the bottom left of the cover is a wide hook. This needs to locate into the metal frame. The white peg with the hole is where the screw goes in.
Good luck
Posted on Oct 10, 2010
SOURCE: my canon ir 330-400pcl eror
My canon ir 330-400pcl eror E677 how to..
Posted on May 26, 2011
  • 12 Answers
SOURCE: copier canon ir 5065 prolems with eror code e 000808-0002
The error code E808 is not listed in the imageRUNNER 5570 / 6570 Service Manual. The error code description should read:
E808-0001 The IH power supply input voltages are higher than the stipulated voltages.
E808-0002 The IH power supply input voltages are lower than the stipulated voltages.
The remedy description for either code is to plug the machine into a wall outlet with the correct voltage and replace the fixing heater power supply.
Posted on Aug 29, 2012
Canon ir 3235 error e000196
error in communication between laser driver and dc controller,check the wiring and connectors
May 20, 2012 | Canon ImageRUNNER 3235 Black and White...
Canon ir 2545 error 0000
ERROR CODE E000002 IR 2545
Jan 26, 2012 | Office Equipment & Supplies
My canon image runner 2520 has been duly bought and well powered, but it brings error code e000020 and it does not print or scan,i need immediate help.
the problem is when i have replaced the drum of my canon ir 2520,appeared for me two big black lines and then appeared that code :e000196.thankssssssss.
Jul 20, 2011 | Office Equipment & Supplies
Eror e00014 pada ir 5000, sudah dierror *28* tetapi tetap masih eror. motor pemanas tetap gak jalan gimana yaaaa? tolong dong solusinya...
bos tolong nih, kode error E00004-0010 pada mesin canon ir 6570, gimana solusinya. terimakasih sebelumnya
Mar 17, 2011 | Canon imageRUNNER 5000 Copier
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
CANON IR 6050 IS AN ANALOG COPIER.
CANON IR 400 IS A DIGITAL COPIER.IR 400 IS SINGLE SCAN & MULTI PRINTS ,STACKLESS DUPLEX & ITS CAN BE USE PRINTER & FAX ALSO.
FOR MORE DETAILS VISIT WWW.CANON.COM
Mar 15, 2009 | Canon imageRUNNER 400S Copier
Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
Canon imageRUNNER 2545i AllInOne Laser Printer Logo
187 people viewed this question
old marine
old marine
