The default password 92729272, or 00000000 or 12345678 not working in Konica Minolta bizhub c253 i need help the old technicien is go
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
  • 44 Answers
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Posted on Nov 29, 2009
Bizhubman
  • 108 Answers
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
Posted on May 19, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
How do i adjust default tray for fax receiving
Go to your FAX option button on your C253 and paper then chose what tray you prepare to use press OK after to set the default tray.
Aug 26, 2015 | Konica Minolta Bizhub C253 Copier
How do I replace the fusing unit in Konica Minolta bizhub C253
POWER OFF MACHINE! Open the front door remove one screw from the small access UPPER RIGHT cover disconnect the three connectors two carry 120 VAC other sensor signals the open the right side of the machine two screws below the fuser and remove the unit. reinstall opposite direction. Be careful not to brake the sensor connector
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 11, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Bizhub c253 admin password
123478 or 00000000 default if not was changed require service to resest the pw to default or what you want.
May 12, 2014 | Konica Minolta bizhub C250 All-In-One...
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
Aug 06, 2013 | Konica Minolta Bizhub C253 Copier
What is error c-2527 of konica minolta bizhub c253
sorry, cannot find that error code in SM. Are u sure is it correct code?
Jun 28, 2013 | Konica Minolta Bizhub C253 Copier
Konica Minolta bizhub C253 - Displaying status on a webpage
the hp web jetadmin is quite good, it displays whatever info you select. use version 10.2
Mar 31, 2010 | Konica Minolta bizhub C250 All-In-One...
k24674
jasbo
jasbo
