<!-- from fixya rte -->Machine squealing when spinning - Washing Machines
    Champion:
  • 216 Answers
LOOSE OR WORN BELT. CK BELT TENTIONER.
Posted on Nov 10, 2014
Testimonial: "Checked the belt and it was fine. anything else you may suggest..."
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
1982 Maytag Washer model LA210, drive belt squeal after spin.
That is usually normal. That is the sound of the brake applying against the tub to stop it. Smaller loads will be longer because the tub is moving faster and it takes longer to slow down.
May 06, 2012 | Maytag Washing Machines
Simpson Encore 605 - belt sometimes squeals during spin .What maintenance should I do? Spins fine - just squeals from time to time.
Many washers squeal when spin starts. A new belt usually solves it. A bit of belt dressing for car fan belts works wonders. **unplug it while you apply belt dressing!
There is usually a tension adjustment by moving the motor mount back a small amount. Don't over do the tension.
Apr 02, 2010 | Washing Machines
Squealing noise
possible causes are:
bra wire stuck in tub and rubs against the drum and squeals when on spin.
lip seal at front of bearings squealing - this is a difficult repair
Sep 02, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
