Question about Audio Technica Audio-Technica ATW-T202 Microphone
My mic wireless mic sounds like it has a ground loop hum when it is in standy mode and when it is all the way on. I've switched cables and batteries what could be causing this hum?
    New Friend:
  • 151 Answers
You could try another power adapter on the receiver, maybe this one blew the filter capacitor. I doubt your problem being the mic, rather check the receiver. Luck !
Posted on Nov 25, 2014
Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Oct 04, 2012 | Alesis PalmTrack Handheld Portable SD...
Audio buddy buzz
Background 50 or 60 Hz buzz can be radiated from nearby wiring or conducted. Grounding is important but that can also be a cause. I suggest you search accidental hum loops.
Poor or faulty power supply regulation or smoothing can inject a mains hum into audio. This would need checking with an oscilloscope which could also be used perhaps to help search for the source.
Radiated hum can be picked up and injected into high gain amplifier inputs and long leads, poor screening and impedance mismatch can make things much worse.
I haven't helped much but I hope I have given you food for thought and further research.
May 30, 2017 | M-Audio M Audio Audio Buddy Microphone
Hum when mixer is turned on
If it is a 60Hz or 120 hz hum, the fault may be a bad solder connection to a filter capacitor in the power supply.
If it is a hum like a bad mic connection, you may have dirty contacts on an input, dirty tracks on a mixer control, even on the EQ portion.
It may also be a bad cable is connected, or a 1/4 inch jacked input may not be grounding out when the plug is removed. You may have a bad ground on the power feed and you have a ground loop as a result, or a cable is faulty and creating it's pwn ground loop to something else.
Contact cleaner is not a bad idea, slide pots are notorious for spurious noise over time. LPS1 is not bad, but it does use silicone as the dry lubricant portion.
If all of that is ruled out, look internally for bad solder joints- anything that looks crumbly is suspect, and also check for loose wires and jacks with bad solder connections. Also look for loose connectors too.
Mar 29, 2012 | Mackie 3204VLZ3 32-Channel USB Mixer
I`ve just bought a new Fender Telecaster Deluxe. When I plug it into my amp there`s a slight hissing hum. When I touch the strings it stops. I`ve tried it through a different amp & changed leads so
you may have a ground loop problem and when you touch the strings you complete the ground loop so the noise dissapears. make sure the amp is plugged into a proper grounded outlet. also there is an aftermarket ground plate that goes under the pick guard. that is what I put on mine to cut the emf way down. if you bought the guitar from a dealer take it back to the store and ask them why you are getting so much noise.
Nov 26, 2011 | Fender American Deluxe Telecaster
Hi. My Magnum Omegaforce has a hum which comes from the speaker, but only when I plug the mic in. If I put the mic down there's no hum. If I pick up the mic or put my hand near it the hum...
Sound like the radio is looking for a ground. I would tell you to take it to a good CB Shop,not all shops work on this radio so be careful and ask them first.But you're touching it or almost touching it is giving it a "False Ground" causing it to hum.
Jul 03, 2011 | Magnum OmegaForce S45 CB Radio
When I connect the Mackie 1642-vlz3 from the "direct outs" to the line level inputs of the D3200 there is noise/hum (except for channel 1). There is no noise/hum in the XLR inputs. I have two...
Make sure ALL of the interconnected equipment is powered from the SAME receptacle to avoid ground loops due to the safety ground. DO NOT Use two wire power or use ground lifting plug adapters. Make sure you use balanced lines, either XLR or TRS cables. Do NOT use TS cables.
Jun 01, 2011 | Korg D3200 Digital Studio
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Hum sound when plug in. if i touch the input jack the hum sound disapear.
The best way to test your sound problem is to buy another pair of patch cables/RCA cables and try those, most likely you have a ground loop in the RCA cables, basically you are creating a ground when you touch it.
Dec 04, 2009 | Fishman Audio Amp Temp - Green Amplifier...
RCA Pre-Out Making Producing a Mumming and a Popping Sound.
the speakers hook to speaker wires not to any thing else no power no negative poles do you have a remote shut off switch connected to amp this would be important to cut off amp
when cut off amp if you still here the humming this can be an indicator of low power being produced by alternator alternators produce 14 anything below 12 would mean replacement of alternator
if alternator fine then you need to find new ground for amp and make sure you have a good ground for sterio this can be checked with a test light
to check a ground all you do is hook gator clip to power then touch test light end to ground on radio end light comes on got a good ground (make sure not to touch any other sterio wires just the ground wire while connected to power to check grounds)
if pulsing in test light on the ground means you have a bad ground
just disconnect move to better ground
check the amp ground the same way as decribed above
May 09, 2008 | Pioneer DEH-P3900MP CD Player
Audio Technica Audio-Technica ATW-T202 Microphone Logo
106 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
