I have a 52in jvc and replaced the bulb but when I turn it on the red light keeps flashing rapidly and then turns itself off
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Have you done a bulb time reset; before and after the bulb replacement? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 10, 2014
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
SOURCE: no sound on my 52in jvc tv
i unplugged my tv and when i turned it back on had picture but no sound and all cards are still in tack.
Posted on Sep 04, 2008
SOURCE: JVC 56FN97
Make sure the bulb is seated properly in it's hole. It has to be an exact fit or it won't work.
Posted on Oct 16, 2008
SOURCE: my jvc hd-56g886
replace the lamp
Posted on Nov 04, 2008
welcomejee
  • 10594 Answers
SOURCE: Replaced the bulb, now the tv will turn off and flash red light
3 times red light flash shows that lamp cover is not seated / fixed properly.
Please check lamp cover and fix it securely.
Posted on Dec 11, 2008
I have sourced out all fuses and bulbs, yet continue to have a rapid right turn signal. I don't know where else to look. help?
replace the right rear bulb. the quick flashing indicates a bad bulb. it could be a wiring problem to the rear for the signal light that you will have to check out starting at the socket and working forward.
Mar 29, 2015 | 2005 Chevrolet Uplander
Grand prix front turn signals lights will not work but rears flash rapidly.
Definitely not the flasher, as long as it is flashing or blinking somewhere. Rapid flashing indicates a burned bulb, but since you already tried new bulbs in front, possibly bad bulb sockets, loose connectors, or a bad ground for the front bulbs. If you have a test light or voltmeter (multimeter), check for power at the socket when turns are on. If power then at the front, try new bulbs or trace the ground for those lights. If no power to the socket for turn signals, recheck wiring.
Apr 02, 2013 | 1995 Pontiac Grand Prix
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Blue and red light flashes but no picture
I have the exact same problem. Replaced the bulb and ballast and the lights still flash rapidly. Bulb had burst before I ignored the onscreen replace warning.
Does anyone have a clue?
Nov 27, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
I have a 52in JVC TV. about 3ys old when I turn it on I can hear it coming on, but then it clicks off. The red lamp light keeps blinking
sorry to tell you you may have to buy a bulb which is on the bottom right hand side i know this it happened mine too
Oct 16, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
JVC 56FN97
Sep 17, 2008 | JVC HD-56FN97 56" Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
