I have a whirlpool washer model WTW4800XQ1. It spins but doesn't drain. I taken apart all hoses...no clog. The water will drain through the pump when the unit is unplugged. Is there a way
Whirlpool washer model WTW4800XQ1. whirlpool washer model WTW4800XQ1
  • 104 Answers
It sounds like the pump does the water run out when the outlet pipe is laid flat on the floor or below the machine's height level? if so then the pump will need to be checked out
Posted on Nov 10, 2014
SOURCE: ge washer not draining or spinning
Washer will not drain or spin. Got the water out andf tried it . It would spin and seem to drain what little was left in the drum. When I added about 1" of water it would not drian or spin. Drum sets at an angle also.
Posted on Oct 29, 2008
  • 15 Answers
SOURCE: will not drain water after washing
it sounds like your lid switch ic either broken at the lid or it is non functional open the lid to manually see if it is broken you schould be able to see it visably on the lid if it is broke your machine will not go into spin and not drain
Posted on Dec 24, 2008
smartr10U
  • 1305 Answers
SOURCE: amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
Posted on May 10, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool washer agitates, but won't drain water
HI, any resistance when turning the impeller in this case will confirm pump failure. these motor should have very slight resistance when manually rotated. the unit will not initiate a full cycle if the pump is defective. replace the pump asap.
Posted on Jul 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Tub won't drain
The lid switch has a green ground wire and 2 hot wires. Jump them 2 hot wires and see if she pumps out.7bce33c.jpg025e16d.gif
More here
bypass it here for testing purposes. How it works: direct drive washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 12, 2010
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
I have the whirlpool model WTW495OXWD and it wont spin or drain,
see this causes:
drain line is clogged fix it,some sock is inside, take pliers and remove, if you can you need to remove the agitator, the propeel of pump can be defective replace.
frozen pulley pump replace
improve the drain line. if mayor that 4 inch cut of the diference, is a lower install air/gap siphon break assembly
Jun 21, 2012 | Whirlpool Washing Machines
Doesn't spin fast enough to remove water from tub. makes a steady noise that doesn't get louder or softer just stays steady
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Frididaire washer error 10 Washer will take in water but doesn't spin or complete cycle. Doesn't let water out.
Hello.
When Washing Machines electronic control has detected a condition then it indicate by showinh error code which needs to check. When you see a code, follow these steps to solve the problem.
However, there are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Challenging Instructions And Things You'll Need:
· Screwdriver,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop.
  1. A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Aug 02, 2011 | Washing Machines
Whirlpool Duet Sport Washer (model: wfw8300sw02) partially drains. Clothes spin out as dry as ever, but 2-4 cups of water are always left in the filter/pump. I've 1) emptied the filter 2) disconnected...
puzzled here because there is always some water left in machine this is normal .you are quite right when you say that when you take the drain hose out of stand pipe and lower it water comes out but that is because of gravity .
Jun 07, 2011 | Whirlpool Washing Machines
Whirlpool front loading washer
The 02 error code relates to a drain problem. Check that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Regarding the spinning noises and vibration, open washer's rear panel and look for a released or a malfunction shock absorber. Good luck!
Aug 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
