Question about Humidifiers
I have a sunbeam sul2512um ultra sonic humidifier . I have had it for a less than a year . When I turn it on it makes a very loud noise where the mist comes at the base . Is there anything I can do to stop this noise. Everything else works fine . The mist comes out perfectly but the noise is very annoying .
  • 104 Answers
Unfortunately thats the noiise a humidifier makes perhaps there are less noiser models on the market now you know as time goes by so technology becomes more amazing.
Posted on Nov 10, 2014
4 Suggested Answers
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Posted on May 30, 2008
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
  • 7 Answers
SOURCE: I need to know how to clean the base of my humidifier.
DAILY MAINTENANCE
Allow to cool before maintenance.
1. Before cleaning, set the control to OFF (0) position and unplug the unit from the electrical outlet.
2. Remove the water tank then unlock the misting chamber by rotating the safety lock towards the front of the unit. Lift mist chamber from the unit's base.
3. Empty water and minerals from the base ond place in the top rack of the dishwasher. This will remove any sediment and dirt that has accumulated in the base.
NOTE: It is imperative that the base is deaned properly. The base is dishwasher safe (top rack ONLY) for easy cleaning.
4. Wipe the heating element dean with a soft doth after it has had a chance to cool.
5. Replace misting chamber and engage safety lock. The Electronic Thermal Control Heating element is lined with a coating that is designed to provide the easiest cleaning and prolong the operating efficiency of the humidifier.
DO NOT use any metal or hard objects to dean the Heating Element. Never use detergents, gasoline,
kerosene, gloss deaner, furniture polish, point thinner or other household solvents to clean any part of the humidifier.
WEEKLY MAINTENANCE
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the trzy by partially filling the base with one 8-oz cup of undiluted white vinegar. Let solution stand 20 minutes, cleaning all interior surfaces with a soft brush. Dampen a doth with undiluted white vinegar and wipe out entire base to remove scale.
3. Rinse with doon worm water to remove scale and the white vinegar solution before beginning to disinfect the tank.
4. Wipe the heating element clean with a soft cloth after it has had chance to cool.
Disinfect tank:
1. Fill tank with 1/2 teaspoon of chlorine bleach and 1/2 gallon (1.91) of water.
2. Let the solution stand for 20 minutes, swishing every few minutes. Wet al surfaces.
3. Empty the tank after 20 minutes, and rinse well with water until tho bleach smell is gone. Dry with a clean cloth or papar towel.
4. Refill the water tank with cool wator; replace the housing and water tank. Repeat All Operating Instructions.
Posted on Jan 31, 2011
Walgreens Dual tank humidifier 2035 stopped working
I've never seen this model, but it would suggest that the unit is unable to function due to either an electrical failure or needs a serious deep cleaning (esp.the part that interacts with the water to form mist.) I would completely empty the unit and clean it, then partly fill the reservoir with 50/50 mix of white vinegar and water and let it sit for 24 hours (possibly longer) to remove any deposits. (Doesn't take much build up to kill the ultrasonic process). Other than that, try calling the manufacturer and see what they will do for you. (Think it's Sunbeam).
Dec 21, 2015 | Walgreens Dual Tank Ultra Sonic...
I have a 1099 general powered humidifier making a loud humming noise.
there are no moving parts in that humidifier other than the solenoid and it only moves open or closed are you sure the noise isn't caused by something else, maybe something close or even the furnace
Feb 23, 2014 | General Filters 1099-LH Humidifier
Where do I find manual for germgaurdian H3000 humidifier.
http://www.guardiantechnologies.com/product-instruction-manuals/
Germguaridan website.
This manual can be found under discontinued models. This was most likely discontinued because it is very sensitive and quits working too soon because of the ultrasonic sensor.
Dec 10, 2013 | Germ Guardian H-3000 Ultra-Sonic...
Hm2612-u is making really loud noise when running
Best solution is to take it back to the retailer for warranty repair or exchange.
Mar 03, 2013 | Holmes Homes HM2612-U Ultrasonic Comfort...
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Loud noise
Try checking the pick up tube that spins from the motor to the resivoir. If this is not seated properly or off balance even just a bit, it can cause your humidifier to sound like a small waterfall. Hope this helps
Aug 01, 2009 | Vicks Cool Mist V400 Humidifier
Aprilaire 760 furnace humidifier makes a loud screeching sound.
A bad circuit board should not make any noises. A bad solenoid valve could make a loud buzzing noise. If the noise is a squealing noise then you have defective bearings in the blower motor.
If you disconnect the low voltage wiring from the solenoid valve and you still hear the noise, then its not the solenoid valve.
Apr 06, 2009 | Aprilaire 700 Humidifier
Loud "Glonk" when humidifier turns off
Try turning the water valve going to the soleniod down. There may be too much pressure. You may have to replace solenoid one more time after making the adjustment.
Mar 12, 2008 | Aprilaire 700 Humidifier
Humidifiers Logo
111 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
