Question about Garden
RELEASE SWITCH ON REAR OF RIDING TRACTOR.
Took of rear tire to fix flat.realalined keyway.put back on NS NOW IT WON'T GO FORWARD OR BACKWARDS.PULLEY JUST SPINS.THE ONLY OTHER THING I DID Was clean off top of rear,grass clipings etc.
  • 1,169 Answers
Double check the drive axle keyway and make sure key is still in there. Without it the drive axle just spins without driving either wheel.
Also if hydro static make sure the neutral lever is re-engaged. Operators sometimes put these in neutral and then forget to put them back when they to use the mower.
Posted on Nov 10, 2014
  • 49 Answers
SOURCE: Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Posted on Feb 06, 2009
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
wilsodfarm
  • 986 Answers
SOURCE: FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Posted on Jul 28, 2009
saailer
  • 1868 Answers
SOURCE: I have a Husqvarna YTH
Hello! There are two known faults with the Husqvarna YTH...# 1 is the drive belt slipping...The belts have a manufacturing defect, in that they are out of specification in length...After some usage slipping occurs...#2 is a brake recall which is described below...It refers to the 19.5 HP 42" cut but the 46" cut utilizes the same braking mechanism...Guru...saailer
Brake Recall.
http://www.usrecallnews.com/2009/07/cpsc-6146.html
Husqvarna Lawn Tractor Recall: Parking Brake Failure
July 9, 2009
NAME OF PRODUCT: CRAFTSMAN LAWN TRACTORS
UNITS: ABOUT 8,200
MANUFACTURER: HUSQVARNA CONSUMER OUTDOOR PRODUCTS N.A. INC., OF AUGUSTA, GA.
HAZARD: The tractor's parking brake may fail, which could result in a loss of control.
INCIDENTS/INJURIES: No incidents or injuries have been reported.
DESCRIPTION: The recalled Craftsman Power Lawn Tractor is gray, has a 19.5 horsepower engine, automatic drive and a 42 inch cutting deck. The model and serial numbers can be found on a plate under the tractor's seat. The following model and serial numbers are included in this Husqvarna lawn tractor recall.
MODELS CRAFTSMAN 917.289080, CRAFTSMAN 917.289081, Serial numbers, 012709A001000 THROUGH 031209D999999
SOLD BY: SEARS AND KMART STORES NATIONWIDE AND ON THE WEB AT WWW.SEARS.COM (http://WWW.SEARS.COM) FROM JANUARY 2009 THROUGH APRIL 2009 FOR ABOUT $1,200.
MANUFACTURED IN: UNITED STATES
REMEDY: CONSUMERS SHOULD STOP USING THE RECALLED TRACTORS IMMEDIATELY AND CONTACT SEARS FOR A FREE INSPECTION AT YOUR HOME AND, IF NECESSARY, A FREE REPAIR OF THE PARKING BRAKE CABLE. SEARS IS DIRECTLY CONTACTING CONSUMERS WHO PURCHASED THIS PRODUCT.
CONSUMER CONTACT: FOR ADDITIONAL INFORMATION, CONTACT SEARS AT (800) 978-7615 BETWEEN 9 A.M. AND 10 P.M. ET MONDAY THROUGH FRIDAY, OR VISIT SEAR'S WEB SITE AT WWW.SEARS.COM (http://WWW.SEARS.COM)
Posted on Dec 18, 2010
SOURCE: Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How ...
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
Posted on Jul 14, 2011
Mower will not shift into gear
Please review my answer to:
Craftsman tractor won go into gear had flat tire got it fixed and...
Oct 08, 2016 | Craftsman Garden
Trans bad?
Jack up the rear end using the frame. Put a person or cinder block on the seat, and put it in drive. Look for the shafts turning inside the wheels indicating broken keyways.
May 06, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
I removed, re-inflated and reinstalled back right tire on my Poulan 42", 18 hpr riding mower, now it won't engage in gears and move forward or backward. I've compared the reinstallion with...
there is a slot on the axle for a square key to fit in.
when you took off the wheel it might have fallin off.
look around for a little square piece of metal.
like a little bar.
put it in the slot and put wheel back on.
don't forget to vote for me.
thanks
Jul 16, 2011 | Garden
I took off one of my rear tires to get it fixed and after I put it back on it will not go into gear. Blade engages and motor starts but no forward or reverse
Hello, What has likely happen is the keyway (Sears part # 123583X) fell out. Verify this by:
setting the parking brake
lifting the side that you removed the wheel from
turn the wheel by hand
If it turns and the axle does not then the keyway is missing.
The part costs somewhere around $3.00 from Sears Parts.
To replace:
remove the snap ring and outer washers
turn the wheel by hand until the keyway channels line up
slide the keyway into the channel
replace the washers and snap ring
test by ensuring wheel no longer turns without the axle
I also recommend that you go to your local auto parts store and get some "antiseize". Put some on the axle before you replace the wheel that will keep it from rusting and making it near impossible to remove next time. I know Autozone sells it in small packets for about a buck-thirty.
I hope this helps. If it was useful please vote yes. Thank you!
May 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman mower 917.280810.It barely moves when clutch is released,even on flat ground.I changed the belt-no help.The transaxle pulley is engaged,and when I put my hand on the tire,the tire stops...
I don't quite get you, if the belt is running but the rear axle is not turning then your transmission is shot. If the belt is running and the rear axle is spinning with no forward or backward motion, then someone took the back wheels off and put them back on without installing the keyways.
Sep 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Our 20 hp 46" cut Husqvarna '08 riding mower will crank just fine but will not move forward or backward.
Check to make sure the belt that runs from the engine pulley back to the transaxle is on all the pulleys.If it is a hydrostatic transaxle make sure the free wheel control lever at the back of the tractor is in correct position, or the brake plate may be stuck on but that would make a loud grinding sound.If it is a gear drive make sure the transaxle pulley is turning and make sure you didn't lose a rear wheel key from the axle,(if you had the tire off for a repair it is easy to lose the key when you go to put the tire back on.
Aug 09, 2009 | Garden
My John Deer L130 tractor needed a new tire so I bought one and put it on. Now it will not go into gear. It will not go forward or backwards. Why won't it go. Please help Tammy
This was a rear tire I assume. There's a square key about 2" long that fits in a groove in the axle and a slot in the rim. You probably pushed it out putting the wheel back on and didn't notice. Look where you took off/put tire on. It should be laying there.
Jun 10, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Clutch issues: release clutch and mower doesnt move.
"....I just took off the right rear tire to replace."
Make sure the key hasnt fallen out of the right rear tire. It has to have the key to work. Its a peice of metal about 3 inches long and flat on all sides. It should slip into the grove on the tires shaft. Hope that helps.
Apr 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
