Question about Measuring Tools & Sensors
I have a nearly new briggs and stratton 800 snowseries snow blower that was purchased about 5 years ago. Used less then 10 times with no problems. It sat the past few years and still looks really clean. I put fresh gas in it and it won't start electrically or pulled. It tries to turn over but just won't fire. And quick tips or hint i could use? Thanks
Most likely the carb is varnished up. Gas sitting too long will go bad and will gum up the carb jets, valve seats, etc. Rebuild the carb, and it should run. If storing for long time make sure to add fuel stabilizer to the gas, run the unit for ten minutes, shut fuel off let it run until it quits, then put in storage.
Posted on Nov 10, 2014
SOURCE: My briggs & stratton will not start
i had a similar problem on a 20 hp v twin. there was trash in the fuel shut-off solenoid screwed in the bottom of the float bowl stopping fuel. It will come out without pulling the whole carb apart.
Posted on May 28, 2009
  • 109 Answers
SOURCE: 20 hp briggs and stratton revs up and down
lower throttle and if that doesnt solve it check the governor might be broke
Posted on Jun 24, 2009
SOURCE: Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Posted on Aug 16, 2009
  • 583 Answers
SOURCE: briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Posted on Oct 25, 2009
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
What is the head gasket torque spec for a 8.5 horse power horizontal shaft brigg and Stratton engine.
not nearly as critical as you think. I bet 40 ft lbs on all bolts would be fine. It's more the consistency among the Bolts than the actual torque
Sep 28, 2014 | Craftsman Snow Blower / Snowblower Bottom...
What oil to fill briggs stratton 14.g ohv
They use good grade of SAE 30 ...if using on snow blower on very cold areas you may want to use a multi viscosity like SAE 10-30 ..will give you protection in extreme cold while handle summer operation. Good luck..
May 27, 2014 | Briggs & Stratton Garden
What spark plug wrench is used to remove the spark plug on a TORO 38624w snowblower?
it is prob a 13/16 this is the most common most of the time you cannot get a wrench on a plug but a socket , if it is smaller then it is a 5/8 lefty loosie righty tighty do not over tighten the plug
Jan 20, 2014 | Toro 826OXE 2-Stage Snowblower 38624W
I bought an Ariens, model #921031 Deluxe 24 with a Briggs & Stratton engine brand new online and haven't used it yet. It's been sitting and now I have a puddle of oil under it. The place t
Some times, the seals not sealed yet not being run. Check all your oil and gear oil levels and run it. Hope everything will be ok then.
Feb 10, 2012 | Briggs & Stratton Garden
357cc is equal to what in horsepower MTD
From my website: movingsnow.com. Five years ago the power output of every snowblower sold here in the United States was measured in hp or horsepower. It was a nice simple measurement that everyone was used to.
Three years ago they changed the rules and started selling snowthrowers with the power measured in gross torque. Of course no one understood what this meant and even though companies like Briggs & Stratton tried to explain it, it still didn't make much sense.
Well they changed the rules on us again.
So we just start to get used to measuring an engine's output in torque and now for the 2009/2010 season a lot of the snow blower manufacturers are dropping the torque measurement and only giving us engine size in cc's.
I spent a great deal of time researching this and I'm not going to spend time trying to explain why the engine manufactures have changed their terminology. Instead I'm just going to show you a formula you can use to figure it out yourself.
Here's the formula I used from the Briggs & Stratton website (rpm x torque / 5,252) The engine manufacturer's used 3600 rpm most of the time to rate the engine's horsepower so I will use that number in the formula. I also used the torque ratings from the Briggs & Stratton website for their motors to keep this chart simple. Other manufactures (like Powermore) may have different torque ratings for their motors. If you are trying to get exact hp measurements you should research the torque ratings for the specific brand.
For 2009/2010 MTD has dropped all torque ratings on snow throwers. The engines are only labeled in cc's.
Here is a simple chart of approximate cc to torque to horsepower conversions. It's not exact, but it will give you a better idea of how big the new engines are. I used 3600 rpm in the formula for this comparison. Assume that your new snowblower motoe runs at less rpm.
123 cc = 4 hp
179 cc = 5 hp
208 cc = 8 to 9 Gross Torque = 5.5 to 6 hp
277 cc = 11 to 11.5 Gross Torque = 7 to 8 hp
305 cc = 13.5 to 14.5 Gross Torque = 9 to 10 hp
342 cc = 15.5 to 16.5 Gross Torque = 11 to 12 hp
357 cc = 12-14?
420 cc = 14-15?
To me cc's is not a good comparison from one motor to another. It is also not a good comparison from one manufacture to another. For example, a 190cc Briggs & Stratton side valve motor will not have the same power as a Honda 190cc overhead valve motor. cc'c doesn't give you a good measurement of what the engine is capable of. True, an overhead valve motor from a specific manufacture should have more power with more cc's but there are a lot of other factors that go into determining how much power is available for you to use. The true power of a motor is determined by engine type, (overhead valve/side valve) carburetor (naturally aspirated/fuel injected/turbo) rpm you use it at (2750/3100/3650) and many other factors. I hope this helps.
Jan 03, 2011 | Garden
I have a 5.5 Vertical Briggs and Stratton about 6 years old that is mounted on a woodsplitter. This year it started dieing under load. It's driving a brand new 2 stage 11 gallon pump because I thought that...
If the generator was used during these 6 years continuously on full or near full load, it may have loosed compression (and derated load).
If you can measure the pump current and compare with the rated of the generator it should be less than the half of the rated to run properly in continuous mode. If it is greater than 75% it may be more than the possible for this generator.
Nevertheless the new fine oil, the overheating or lowering of the oil level during operation may be the reason for stopping.
Jul 06, 2010 | Briggs Stratton H7159 & Stratton® 5500,...
Owner's manual
10-30 w, or SAE30 eg Briggs & Stratton 30.
Jan 30, 2009 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Measuring Tools & Sensors Logo
70 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
