Question about Singer 9960 Quantum Stylist Sewing Machine with Quilting and Sewing
My machine stopped running whenI accidently hit a safety pin on my quilting project. The needle did not break or bend, but I changed it hoping that was the problem. .the light comes on but it is not r
My machine stopped running whenI accidently hit a safety pin on my quilting project. The needle did not break or bend, but I changed it hoping that was the problem. .the light comes on but it is not running. as soon as it hit I pushed the off button to stop it before it ran oner the pin.Is there an auto safety shut off that I maybe ned to reset, there is nothing in he manual and I have tried everything I know to restart machine.Ist problem I have had I love this machine. Thank you
    Novelist:
  • 193 Answers
This will require an on-site or carry-in service. If you like the machine it is worth getting it looked at.
Posted on Nov 13, 2014
I am quilting and the thread keeps breaking. What is the problem?
Not sure if you are piecing or trying to free motion quilt. If FMQ, try using an Embroidery needle (it has a groove in the shaft that helps protect the thread) or a Topstitch needle. Make sure the thread is not too thick for the needle's eye. Check to make sure the upper and lower tensions are not too tight. You might try changing brand/type of thread.
Here's a needle guide:
SCHMETZ Household Needle Chart
Or review suggestions for breaking thread here:
Why is my thread breaking
Hope this helps!
May 20, 2015 | Sewing Machines
Needles keep breaking when i quilt, its like they dont fit or too long quilt expression 4.0
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Jan 09, 2013 | Sewing Machines
Can this machine sew over pins?
You must remove the pins as you sew otherwise you will either break the needle or do worse damage to the machine. Home sewing machines were never meant to sew through metal.
Feb 04, 2011 | Brother LS-2220 Mechanical Sewing Machine
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Keep breaking needles
Here are some solutions to try.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
your needle.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Tension
Several things to try, I have this set up and after six months I'm still trying to get some issues resolved.  First make sure the machine is treaded correctly, the Juki doesn't thread like most machines, make sure you have the bobbin going the correct way.  After the machine then it has to be in the frame which means that the fabric is most likely to tight, this is a common problem, if you are bending the bars then it is too tight.  Also, look at how the quilt is in relationship to the frame, is it level?  As you quilt and roll, you will need to adjust the frame up, the quilted part should not drag on the machine and the to be quilted part should not be below the machine.  It is a critical that the frame and the machine be even with each other, if not the machine will try to pull and won't sew correctly.  Also, another tip, after each quilt change your needle, the reason is that free motion is technically bending the needle.  Hope all this helps.
Sep 09, 2008 | Juki TL-98Q
Singer 9960 Quantum Stylist Sewing Machine with Quilting and Sewing Logo
147 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
