Question about Saws
I cant seem to find the blade size for an older pro tech bandsaw model 3101. Is there a newer model that is compatible?
    Problem Solver:
  • 28 Answers
In case you don't know, there are band saw blade supplier that custom blade to any length. Call sawblade.com
Posted on Nov 12, 2014
There should be enough adjustment on the tensioner to allow you to use any size blade that will be close to the original size. Set the tensioner/adjuster to the mid position measure the size of the blade, and look for one close to that size.
Posted on Nov 10, 2014
  • 582 Answers
SOURCE: bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Posted on Aug 22, 2009
SOURCE: hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Posted on Jan 21, 2010
ToolBoxHero
  • 171 Answers
SOURCE: Sears 12" bandsaw Model 11324200 I
Here is a link to the parts diagrams.  You can order new parts and have them shipped right to your home.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113247210/0247/0744100?pathTaken=
Posted on Jan 06, 2011
Will a 59 1/2 inch blade fit my protech bandsaw model #3203
Click to open expanded view Olson Tko Special Band Saw Blade (TK17259) by Olson Be the first to review this item Price:CDN$ 24.15 FREE SHIPPING. Usually ships within 3 to 4 days. Ships from and sold by TEXASVALUE. 4 new from CDN$ 24.15 Hard edge Flex back For hard and soft wood, general purpose contour cutting, fast cuts, and medium finishes For Ryobi BS900 and BS901, BandD BS700, Sears Craftsman BS700, Pro-Tech 3202 and 3203, Delta 28-150, Colli Length: 59-1/2" > See more product details
Aug 13, 2015 | Blade Saws
I need to find the size and length of a powermatic bandsaw blade. Model PWBS-14
93.5 inches
Do you not have internet? I found the specs for your model instantly on Powermatic's web site. Don't be so lazy!!
Feb 27, 2015 | Powermatic 14" Bandsaw Model PWBS-14CS
Where do I get a blade for Pro Tek 10" model 3104
I buy mine on sawblade.com ; they are cutting blade stock to any length. Your bandsaw is using 62" right? Try to use a 1/4" 0.025 6 TPI flex back carbon blade for cutting non ferrous metals.
Jul 04, 2014 | Saws
How do I change the blade on my pro-tech model 3104 bandsaw
Before doing anything, check the length of the blade. You maybe have the wrong length.
It may not tracked and tensioned properly. Double check the adjustments.
Are the tires new? Tires should not be worn out. Guides must be positioned properly too.
You may want to check your manual. It can help to figure things out. And oh , try reading this
blog : http://bandsawblog.com/replacing-the-band-saw-blade-on-your-band-saw/ .
And you can check more informative blogs there. Hop[e I helped you.
Jan 18, 2013 | Saws
Replacement parts for central machinery bandsaw, blade and belt
take a look on amazon: Amazon com bandsaw blade, Last time I bought same parts from there. cheers
Dec 31, 2011 | Saws
I have a used bandsaw but i don't know what model
Band saws are measured by length and width of the blade so measure the length or just take it to the parts place and you should be able to get one of the same size unless its an old or off size no longer made but I dont see that being a problem. Try ebay for your measurements or even Grainger.
http://business.shop.ebay.com/Metalworking-Tooling-/92084/i.html?_nkw=band+saw+blades&_catref=1&_fln=1&_trksid=p3286.c0.m282
May 13, 2011 | Delta Saws
14'' Sears craftsman bandsaw blade slips off, not much power
It sounds to me like the blade has stretched which the do in changing temperatures.
Try replacing the blade before you give up altogether. i was having the same problem with a Ryobi Blade would come off whenever i tried to cut a pice of 3 ply. I eventually replaced the blade and all ny troubles evaporated.
Aug 29, 2009 | Saws
Saws Logo
142 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
