Question about Frigidaire Refrigerators
How to lower freezer temperature
I have a Frigidaire Refrigerator/Freezer, with thermostat in refrigerator unit, and a diversion vent in the freezer. In spite of the vent set to divert maximum cooling to refrigerator portion, the freezer contents remain too cold. Anyone have any answers as to what might be wrong, or what can be done to correct the problem?
Not sure what you mean by the freezer too cold? The freezer section should be at or below 0 degrees C or 32 degree F. if its working properly. If the FF section is too warm and your temp control door or vent is at max cold either the vent is not moving (stuck in the closed position) or the fan in the freezer is not working.
Posted on Nov 10, 2014
  • atlantis43 Nov 10, 2014
    When I say "too cold" I mean that the ice cream is frozen, rather than tempered. It's way too far below 32F. I took freezer apart, and maybe(?) my diverter was complately out of position, so I reset it. Won't know if that was the problem until tomorrow.
Freezer working, refrigerator not
Hello Georgia Peterson - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means that the unit has a faulty compressor or a sealed system leak. Also there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Jan 13, 2013 | Frigidaire FRT21H8 Top Freezer...
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Refrigerator not working, freezer works great
Yes, only one compressor. The refrigeration system actually only cools the freezer. Then there is a vent from the freezer to the refrigerator that allows the cold air to circulate to the refrigerator side. That little dial you turn to set the refrigerator temperature is actually only open or closing that vent. The dial for the freezer temperature is an actual thermostat that operates the compressor.
The temperature of the freezer should be between 0 and -10 degrees Fahrenheit. If it is in or near this range and the refrigerator is only at 55 degrees (the refrig should be at 38 to 45 degrees) then check for blockage or icing where the air from the freezer circulates into the refrigerator.
If the freezer is not in or near the 0 to -10 degrees then you have a refrigeration problem. First thing to do is clean the condenser coil on the bottom of the unit using rags and a shop-vac. Be careful of the wiring and tubing down there plus the sharp metal.
Unplug the unit before cleaning.
Otherwise, you'll need to call a refrigerator service technician to repair the refrigeration system for you.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Kenmore 52282 / 52284 Side by Side...
Freezer blowing cool air, but not freezing.
Hello there:
first make sure that the back of the unit is clear of any dirt or obstructions
also make sure that the food is not stacked up so high that the air cannot circulate also you may want to check the temperature setting if the unit does not respond to a lower setting your refrigerant level may be low or than you will have to have the temperature controle thermistor serviced or replaced
Sep 15, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
THERMOSTAT
Hi, Here is the Part # 5304421256.
This is a common issue with this model. Just remove the 4 screws holding the control panel up and you will be able to see the thermostat/cold control
I hope this helps you.
Please let me know if I can assist you further.
Vicl
Jul 05, 2009 | Frigidaire FRT17G4B Top Freezer...
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Refrigerators Logo
107 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
