Question about Electronics - Others
Were is the fuse for cruise control on 1995 benz c220
  • 3 Answers
SOURCE: i have a mercedes benz C220 cdi '01 and i wan't to
for the 220cdi,it is a 611.961 motor, you have to refill 6.5 liter,included the olilfilter.Whenyou have refill,and after the motor has running,you can check the oil-level in the board-computer.
succes
Posted on Mar 28, 2009
lastech
  • 408 Answers
SOURCE: mercedes-benz c220 1995 model car radio cassette password
hello,you need to contact your dealer regarding your radio code,
Posted on Apr 16, 2009
lastech
  • 408 Answers
SOURCE: 1995 Mercedes Benz C220 will not start, and key
hello,steering lock mechanism and your key need to replaced,if you want try to remove your under dash,steering lock mechanism have a small pin(around 5 mm) which pit to steering housing,drill out the lock,then try to turn steering wheel,ty
jonathancole
  • 127 Answers
SOURCE: The cruise control does not activate.I have
check the botton they go out alot first
Posted on Aug 13, 2009
  • 436 Answers
SOURCE: the horn and cruise control doesn't work,fuses are
the horn input to ground is located in the cruise control module. if they both don't work then your cruise control module or the clockspring coil for the steering wheel needs to be replaced. If airbag lights is on as well then I would change the clockspring coil first.
Posted on Oct 02, 2009
I have an ESP problem in my Mercedes Benz C220 CDI, 2008 and the problem is an ESP CURRENTLY unavailable. Cruise controls and speedtronic inoperative
It is usually a ABS wheel speed sensor has gone faulty, but you would have to have electronic diagnostic done to read off a fault code (DTC) and maybe a live data scan . Hope this helps
Nov 21, 2014 | 2008 Mercedes-Benz Mercedes Benz C Class
Were is the fuse for cruise control on Benz c220 1995
flick lever up to engage-- away from you to disengage --- there are no separate buttons/switches
flick lever up when engaged to increase speed 25276939-mipgmtelf3zvbavbhe0y2tjj-4-0.jpg
Nov 10, 2014 | Mercedes-Benz 220 Cars & Trucks
C220 Engine dies when deccelerating to a stop.
check all engine breather pipe for security, perishing and be sure they are not partially blocked
Sep 17, 2010 | 1996 Mercedes-Benz C-Class
W202 mercedes c220. Flashing heater panel lights and only hot air
hi. have the exact same problem on my 1995 c220 (UKmodel). Did you manage to sort it? If so - what was it???
Sep 17, 2009 | 1995 Mercedes-Benz C-Class
My 1995 c220 benz air mass sensor, throttle valve
hello,try to clean your throttle valve actuator,sometimes the flap get sticky because of fumes of fuel,ty
Apr 15, 2009 | 2004 Mercedes-Benz C-Class
Radio won't turn on
you may check the fuse for radio,remove fuse cover,look for fuse designation for radio.
Jan 12, 2009 | 2002 Mercedes-Benz C-Class
Engine
Yes, a c220 engine will fit, but you will also have to use the ECM and wiring harness from the c220
Nov 06, 2008 | 1994 Mercedes-Benz C-Class
Electronics - Others Logo
42 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
