I can't get my scanner hooked up
I downloaded the driver but when it asks where I want to save my scanned material, I can't make the box work. I used to use it all the time but when they did some work on my computer, it got removed.
  • Doris Livezey Nov 11, 2014
    Canoscan Lide 25 for Windows 7. Where should I save my scanned material.
    Problem Solver:
  • 16 Answers
Are you getting an error message? It could be your path EV. Try this
Look in C:\Windows\twain_32 and there should one other folder in there. In my case it was named CNQ4803.This is the path that is needed to be added into the PATH environment variable.
C:\Windows\twain_32\CNQ4803
Now, follow these instructions to get to the dialog to modify the PATH environment variable.Control Panel > System > and then choose Advanced System Settings in the left hand column.This will bring up the System Properties dialog (it should already be on the Advanced tab).At the bottom of this dialog is an Environment Variables button. Clicking this button will bring up the Environment Variables dialog. In the bottom panel, scroll until you find the variable named Path. Select this one and then hit the Edit... button to bring up the Edit System Variable dialog.
In the Variable value text box, scroll all the way to the right and then add in the path C:\Windows\twain_32\CNQ4803 that was determined earlier. Make sure to separate this value with a preceding semi-colon. And also be careful not to make any other changes to this value.
Now OK your way out of all of the dialogs and CanoScan Toolbox should now work as expected.
Posted on Nov 13, 2014
Testimonial: "Thank you. I will see if this is a possibility. I was able to click on the location box and filled in something from my saved stuff. But now I'm only getting a half sheet scanned. I looked at it while it is scanning and the full light is on. But when it is finished, it says it is cropped. I wonder if I can call the company."
The scan on screen dialog box is corrupted. The buttons to the right to save the scanned document are not labelled and do not work. Unable to save a scan.
If you are in the US.
Go to www.usa.canon.com and click service and support.
Download drivers from there.
First un-install the previous scanner software.
There may be a delete driver file you can use.
Jan 28, 2015 | Canon PIXMA MP830 All-In-One InkJet...
Cant get the scanner software to work
Try reinstalling the software using the drivers from HP.com. If you go to HP.com and type in the model number into their search bar it will usually pull the printer right up. Then select drivers and downloads and find the software using your operating system. Simply download and reinstall the software and it should work just fine.
Mar 01, 2011 | HP Officejet 5610 All-In-One InkJet...
How do I get m,y scanner to work when it is hooked up
turn on your scanner
click start all programs look for your scanner open it up
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Feb 02, 2011 | Computers & Internet
Copy to Dell computer
I guess you was asking if you can use the scanner and make a scanning and than import the scanned image or document to the computer ..yes..this is possible but the scanning has to be initiated from the software that came with the device for scanning ..and command the scan from the software after that will be in the library of the software ...of wherever you save it ..If you do not have installed a software to manage the scannings go to the Lexmark support ..and there choose teh model from the list and download scanner software ..and install in the printer ..(remember this software is something different than the driver ..The driver is just to communicate ..this is to operate the scans from computer and import the result)
Jun 02, 2010 | Lexmark X2470 All-In-One InkJet Printer
Just need the steps to scan, I've never used the scanner.
You need to open your scanner program up, you will see a window representing a Scanner Platen, Open scanner and place image Face Down on glass, and close lid. Now click on "Preview" this will scan the image and allow you to "Select" exactly what via resizable selection box, that you can grab with your cursor and set it to whatever you want to actually scan. Now click the "Scan" button, this time it will do a"Final Scan" and ask you where to save it, usually it is saved as a JPG, if other formats are available use whichever one you wish. may have JPG, BMP PDF. Save your image. Now you can use this image how you want. Also once a scanner is installed you can scan into say Word, or Adobe, Publisher etc. Document by using the scanner. A Twain driver is installed so it can communicate between applications.
Feb 11, 2010 | HP Officejet J4680 InkJet Printer
How do I scan a photo into my computer?
you can use the generic windows scanner wizard which can be found under ...
My computer ----> WIA Canon MP620 (double click)
many graphics programs also have scanner utillities...
Illustrator CS2 or Photoshop 7 ----> File menu ----> import
good luck
rate if useful please
Oct 26, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Won't scan photo to computer.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | HP Photosmart C4280 Aio Printer
Canoscan 20
I had the same problem..the way to get around this is to open the toolbox and click "Save" instead of "Scan" After you do this you just create a file name and save it into a folder..also make sure you change the "save as type" to JPEG
Dec 18, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
CanoScan 8400F
Try this:
Open the CanoScan Toolbox.
Click the Save option.
Put a check in the box that states "Display the Scanner Driver".
Click Scan.
Click the Advanced Mode tab.
Make sure Select Source is set to "Platen".
Click the Preview button at the top left.
If the error still occurs, then most likely it will be a service issue.
One thing to check...see if the inside lamp illuminates when you turn the scanner on using the power button at the back left side of the scanner.
May 13, 2008 | Canon CanoScan 8400F Flatbed Scanner
98 people viewed this question
jasbo
jasbo
