Question about Refrigerators
Runs but fridge does not get cold. What's the problem?
  • 603 Answers
Sounds like your frig has lost it's Freon. Depending how old it is you have to decide whether you wish to repair or replace. GOOD LUCK FRIEND.
Posted on Nov 10, 2014
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
M y Westinghouse mastermind fridge/freezer just runs and runs , it is cold but hardly ever cuts out
Hay Paul ,
1) Are the door gaskets torn ?
2) Is the fridge empty , in order for the unit to cycle it must replace warm air with cold air .
GOOD LUCK
APPLIANCES R'EN
Dec 11, 2013 | Washing Machines
My freezer is not getting ice
If the freezer is not cold enough you may have a compressor problem. First totally defrost the fridge. then plug the fridge back in and check that the fan in the bottom that cools the compressor is working. the cold control can fail so turn the cold control to the highest setting and note if the compressor stops running before the freezer starts making ice. If the fridge just runs and runs and does not get cold enough to make ice you have a somewhat serious problem. the compressor can be replaced but it is expensive and you might be better off to get a different unit (new or used) that will work correctly. Most used appliance stores will have something that will work well and won't cost that much.
Apr 18, 2011 | LG Refrigerators
Compressor runs but fridge and freezer are not cold
what type of fridge freezer are we talking here ?? its likely to either be a dead thermostat or dead realy
Sep 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My refrigaator runs all the time and doesnt stay cold
More than likely the fridge isn't breathing properly. The most common solution for this is to clean behind the fridge. It is the most common place that people forget to clean. On the back of the fridge at the bottom there should be a "filter" usually cardboard that gets full of dust bunnies and just all around dirt. The back is where the fridge breaths air in and without air the fridge suffocates itself and will run more trying to get air in resulting in a warm fridge. Good luck.
May 17, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Compressor runs for 5sec.
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Contents does not turn cold
The contents does not get cold even when the fridge runs in my Frigidaire FRTS5A
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 09, 2008 | Frigidaire FRT18FS5A
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
