Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
Srx75 starter wont disengauge
I tried to start my SRX 75 and and when I turned the key the starter engauged it did not start and when I released the key the started remained engauged and finally killed the battery. I replaced the switch and had the same issue. now with the key off and when putting a battery charger on it, the starter immediately engauges and stays that way until I take the charger off, any ideas what could be wrong?
  • John Deere Master
  • 1,169 Answers
Replace your starter solenoid. Sound like has fused into the start position,
Posted on Nov 10, 2014
wireguy212
  • 1627 Answers
SOURCE: John deer 6400 Shuttle shift will not engauge
You have the old style reverser which has been replaced by one that beeps instead of kicking out.These are a known problem with Deere and that is why you can't buy them anymore.The fact that you can hold it in yourself indicates that the enable solenoid and the forward and reverse solenoid are ok and all safety switches are working.You need to replace the reversrer.
Posted on Feb 05, 2010
suzukiracing
  • 200 Answers
SOURCE: 3010 JOHN DEER PTO NOT SPINNING WHEN ENGAUGED
Check the cable running to the pto
Posted on Jul 20, 2010
SOURCE: My John Deere srx75 was
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Posted on Apr 19, 2011
wentlanv
  • 710 Answers
SOURCE: I was mowing in tall
Sounds like you're having a problem with your Power TakeOff system. The first thing to do is check to see if you didn't bump the PTO switch on your dash. Since you were in tall grass, check to see that there is nothing obstructing your machine.
If all appears OK, then the PTO should be tested. This is an electrical problem and requires a multimeter.
Before you test, check your battery to see if it's charged and that the terminals are clean.
For information on testing the PTO system, I'm pasting a web address with detailed instructions: >>>> http://www.ehow.com/how_7725472_troubleshoot-pto-system-john-deere.html
Copy and paste this link into your browser's address bar.
Good luck to you.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 16, 2011
  • 640 Answers
SOURCE: have a john deere sabre
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Posted on Aug 07, 2011
John deere srx 75 starting with key doesn't work why
if u wiggle the gear shift lever , holding key to start does it work ? if so then u need a new or adjustment neutral safety switch (also key does have running deere on it ?) as non factory keys don't work to well either
also this machine is listed on jd tech site as one that has been noted for an "starting improvement kit " part # - AM107421 jd has made it plain that they know it doenst start so well ,so they have released this kit to install that improves its starting
May 25, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Starter will not disengauge when key is released
The spring might be broken or stuck that returns the gear. Take off starter and clean or replace broken parts
May 06, 2015 | Toro TimeCutter SS5000 zero turn mower
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Sep 08, 2010 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Lt1000 hydrostatic drive stuck - will not engauge or disengauge
Does the tractor try to move or **** in any direction, if so you may want to check to see if the disk that controls the brakes is stuck, I've seen this many times.
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Starter problem when I push the bottom don't starts and some time starts I know the battery is fully charge
The problem could be either of two things. the starter solenoid or the starter relay. The solenoid should not be giving a problem on a bike this new unless it's been started a LOT of times. I have a '94 FXDWG with almost 30K miles on it and the starter works fine but you never know. I would be more apt to think the starter relay might be bad. The relay is a one inch black plastic cube located somewhere on your bike. On the Softail it's on the front side of the rear fender down low beneath the oil tank. I do not know where it is on your Road Glide, sorry. They usually costs about $12 here. If you can, get the one with the "shield" on it to help keep water out of the unit. I hope this fixes your bike if not repost with the results you found.
Apr 22, 2010 | 2008 Harley Davidson FLTR Road Glide
Car makes a weezing sound, turns over, but wont start
Yes, this sounds like your starter is begining to go out. What will happen as this problem continues to progress: is that when you go to start the car you will have to try 2, then 3 then 4 times for the starter to finally engauge. Then if you pray really hard when it gets to the 5th time it might start. The noise you hear is the bendix drive not engauging the flywheel.
Jan 25, 2010 | 1994 Buick LeSabre
The 4wd light stays on. I have tried pushing the level up and down without success. I also having a problem starting the car (manual gear). I also have a problem while starting the jeep. It is not...
Light will not go out until the gears actually disengauge. Typically there is SOME preload on the gears and that keeps them engauged and light indicates so, correctly. To disengauge, move lever to disengauge and drive in left and right circles. This allows the front drive and rear drive to alter their relation in the transfer case, eventually allowing for release.
Sep 01, 2009 | 2005 Jeep Wrangler
93 GMC Suburban Wont Turn Over
I may not be all the way in park or the safety neutral switch in not working. Did you try and start it in Neutral? Also move your shifter around while the key is engauged and see if it will start.
Jul 30, 2009 | 1993 GMC Suburban
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
