No power to my humidifier motor
The humidifier on my furnace has a small low voltage motor that comes on when the furnace starts
    Novelist:
  • 112 Answers
I would begin by checking the voltage output side of the power supply that powers up your low voltage motor. If you have power there, try forcing the motor to turn on by adjusting your thermostat. At this point, if your motor is receiving power but not turning on, it could likely be that you may need to replace your motor. I hope this helps. Good luck.
Posted on Nov 10, 2014
Fan and water does not work
What brand and model do you have for starts. Sounds like a low voltage power issue.
Feb 24, 2015 | Aprilaire 700 Humidifier
Automatic pilot light wont light on a honeywell furnace
Honeywell is a controls company and makes a variety of auto-pilots. If this is a no spark problem,does the lead from the igniter go to a big PC board or a module. If a module, check voltage to the spark module or thermostat voltage to the ignition module. If it comes from a large board, the board may be bad. I'll need more Info. if this does not cover it for you.
Nov 18, 2013 | Honeywell Power Humidifier: Furnace...
2005 Aprilaire 700 humidifier. Replaced a non-working circuit board. Now, the humidifier works fine when the furnace is running. It starts and stops as it should based on humidistat setting. Problem: ...
It sounds like it is just miswired. The low voltage wiring off the humidistat should be on W and C on the circ. board at the furnace. If you have it on R and C then it will power it constantly regardless if the heat is running or not. W is only energized on a call for heat which is typically when you want that type of humidifier to run
Feb 02, 2013 | Aprilaire Humidifiers
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
The green light on my humidifier comes on as it should when the furnace comes on but will not go off when the furnace shuts off. Eventually my drain overflows. Besides this is a terrible waste of H20.
This sounds like a power flow humidifier. Turn the power off to the unit, remove the cover. Check the pad, if it is hard and dirty replace the pad. Most home Depot & Lowes carries pads for these humidifiers. Check your drain and make sure there is no blockage. This may be backing up into the humidifier. You can also take a 5 gall. bucket and try draining into this a coulple of times and see if the problem persists. There may also be a problem with the humidistst. It may not be regulating the humidty corrcetly and staying on. this could keep the soilinoid valve opened.After the furance shuts off you should not have any voltaged to the solinoid valve,. This would be either 24 volts or 110 volts. After the furnace shuts off disconnect one of the wires and see if the problem persists.
Jan 30, 2011 | Heating & Cooling
How do I run the low voltage wire for a Honeywell bypass humidifier to a new Goodman gas furnace. I need the instructions symplified. Is a current relay sensor necessary? How about the brown wire that...
Take the power from the fan after the on off switch then to a transfomer then up to the stat that goes with the humidfier then down to the humidfier,
Nov 29, 2010 | Goodman GMS90703BXA Heater
Increased Humididity Setting ands now Water
Humidifier receives voltage when the indoor blower motor comes on in the heating mode, and blower motor dose not come on right away.See if water flows when indoor fan is blowing heat, Good luck.
Mar 04, 2010 | Honeywell HE225B Humidifier
I would like to direct wire the humidifier to the furnace so evey time the furnace goes on so does the humidifier no humidistat I have a Heil NUGM100EHA1
connect a 24 volt,20 va transformer to the wires supplying power to the indoor blower motor of furnace, connect the primary wires to heat speed of furnace motor, then connect the two low voltage wires to the secondary side of transformer, good luck.
Feb 15, 2010 | Aprilaire 700 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Installation problem
I WOULD CHECK TO SEE IF YOU HAVE ENOUGH V/A OUT-PUT ON TRANSFORMER. I DONT KNOW IF YOURS CAME WITH ITS OWN TRANSFORMER. IF IT DIDNT YOU SHOULD HAVE A MINIMUM OF A 40 V/A RATING STAMPED OR PRINTED ON THE EXISTING TRANSFORMER. IF THE TRANSFORMER IS EXTREAMLY HOT ... YOU MAY NEED A 75 V/A TRANSFORMER WITH THE SAME VOLTAGES. INCREASING THE V/A CANNOT DAMMAGE ANYTHING IT JUST GIVES YOU MORE POWER WHEN EXCESIVE CONTROLS AND WIRING ARE ADDED TO A HVAC LOW-VOLAGE (24v) CIRCUIT. IF YOU LIKE YOU CAN CALL ME AT 727-363-7071. I AM A RETIRED HVAC&R CONTRACTOR WITH 45 YEARS EXPERIENCE. I HATE THE NEW SENSORS THEY HAVE TO ACTIVATE THESE NEW HUMIDIFIERS. I USE TO WIRE THE HUMIDIFIER TRANSFORMER (SUPPLIED WITH HUMIDIFIER) TO THE LINE (110V) SIDE TO THE LOW SPEED ON YOUR BLOWER MOTOR. THAT WAY THE ONLY THING THAT INTERUPTS THE CICUIT IS THE HUMIDISTAT. YOU NEVER WANT THE HUMIDIFIER TO RUN IF YOUR SYSTEM IS NOT "CALLING FOR HEAT". NEVER TRY TO ENERGIZE THE WATER SOLENOID THROUGH YOUR HEAT WIRE(USUALLY SMALL THE WHITE WIRE) FROM THE THERMOSTAT. THIS WILL RESULT IN BURNING YOUR HEAT ANTICIPATOR OUT ON THE T-STAT.
Jan 28, 2007 | Honeywell HE360A1027 Whole House...
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
