Question about Dell 23IN WS LED 1920X1080 1000:1 P2314H
How do I turn on split screen display
I have several LG monitors that allows the the screen to be split so that I can work as if I had 2 separate monitors. I am trying to figure out how to make this Dell monitor work in that manner
    Habit-Forming:
    New Friend:
  • 77 Answers
1. Have the windows you want on top of eachother open.
2. Right click the taskbar.
3. Click "Show windows stacked"
4. Presto! You're all done. Awsome, huh?
Posted on Nov 10, 2014
SOURCE: Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Posted on Jan 29, 2009
  • 19 Answers
SOURCE: Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Posted on May 16, 2009
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
  • 26 Answers
SOURCE: dell 2208wfpt monitor that turns on but screen comes in and out
video converter board ha to be changed
Posted on Sep 04, 2009
  • 121 Answers
SOURCE: Dell flat screen monitor does not come on after
Sounds like a capacitor on the power strip inside the monitor is failing.
The cost to repair can run $400.00. A tv repair shop may be able to fix it, but most technicians recommend buying a new monitor.
However, if you are experienced in electronics, you can disassemble the monitor and replace the capacitor. Radio Shack sells them for between $15 to $20.
Posted on Oct 10, 2009
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
Apr 02, 2012 | LG 22" FLATRON LCD Monitor
I have to hold the power on button down for several minutes to get the monitor to turn on, it attempts to but only for a split second.
Capacitors failing to hold charge, pressing the power button allows flow of current to the capacitors on the power board, which are then leaking the current rather than "storing" it, there is therefore insufficient charge to power the inverter with the jiuce it needs to light the screen.
Check capacitors for bulging or leaking ( better still get someone who is comptent to do it) . remember do not touch capacitors until 24 hours after powering off, as the can still retain a charge
Feb 07, 2011 | Scanport H21 21" LCD Display Monitor
Hello, 2 monitors running off d600 loptop one moniter not picking up windows wat is the problem help p'se
Hi. I hope this helps.
You need to open display properties, click on advanced, and make sure that the video adapter settings are configured to allow more than one monitor. some diplay adapters will only run on one monitor, some will allow cloning, where the same thign is displayed on both monitors, some allow span, which allows the total display to be split between the two monitors, and another setting to allow one to be the primary, and the second monitor for applications.
Also, check to make sure that on your power settings, you don't have it configured to power down monitors if not active. This can sometimes cause the second display to shut down when there is not an active signal going to it, and upon resumng it can cause the second display to not restart as it is supposed to.
Also, check each monitor seperately, having only one hooked up at a time, to ensure that the monitor isn't the problem. This is especially true if you are using flat screen monitors. They are notorious for working one minute, and the next they just quit. Almost all flat screen monitors..i.e. lcd, plasma, and dlp have capacitors that precharge to energize the screen, and those capacitors are quite prone for going out without warning.
I hope this helps you out.
Jan 23, 2011 | Dell Latitude D600 Notebook
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
LG L1717S has no light
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
My pc has a NVIDIA 7100 graphic card on board, now i want to split screens ( two monitors,one pc) by adding a nvidia 7300 to it. when i do so, the pc takes the 7300 as main graphic card and blocks out the...
better to use 1 video card with dual output, you can split the monitor - separate or different applications on each monitor or you can also extent the application window to the other monitor (useful for spread sheets, applications with timeline, etc.)
Nov 09, 2008 | Computers & Internet
Dell 23IN WS LED 1920X1080 1000:1 P2314H Logo
115 people viewed this question
Alun Cox
