Question about Rand Mcnally Intelliroute TND 510 Truck GPS
My gps port pins are damaged where do I get it fixed at
  • Official Brand Answer
  • 29 Answers
Rand McNally warrants the TND/RVND Products, and the component parts thereof, will be free of defects in workmanship and materials for a period of one (1) year from the date of first consumer purchase. This warranty may be enforced by the first consumer purchaser, provided that the product is utilized within the U.S.A. or Canada.
Rand McNally will, without charge, repair or replace (with a new or newly reconditioned unit), as its option, defective TND/RVND products or component parts. For repair or replacement of defective TND/RVND products, User may visit www.randmcnally.com/rma or contact 1-877-446-4863 for return authorization and instructions. User will be required to provide proof of the date of its first consumer purchase, such as a duplicate copy of sales receipt.
Repair or replacements have a 90 day warranty. If the unit sent is still under warranty, then the new warranty is 90 days or to the end of the original one (1) year warranty, depending which is longer.
This limited warranty does NOT apply: 1) to any product damaged by accident; 2) in the event of misuse or abuse of the product or as a result of unauthorized alterations or repairs; 3) if the serial number has been altered, defaced, or removed; 4) if the owner of the product resides outside of the U.S.A. or Canada.
To process an in warranty repair please visit www.randmcnally.com/support/rma.
For units with an expired warranty Rand McNally offers out of warranty repairs for a fee of $99.99. Out of warranty repairs have a 90 day warranty. You will need to call technical support to process an out of warranty repair.
Please call us if you require additional assistance or have questions regarding your warranty and repair options.
Technical Support is available:
Monday - Friday
7am - 6pm (CST)
1-877-446-4863
TNDSupport@RandMcNally.com
Posted on Mar 31, 2015
USB port on the backside of the Garmin Nuvi 265WT GPS broken. Can someone repair/replace the port?
The cost of repairs will be more than the cost of a new unit. A special tool is needed to open the unit to depress the multiple spring pressure locks all at the same time.
Jul 23, 2015 | Garmin nuvi GPS
Navman is stuck on usb screen
This is caused by the battery charger and USB combo connector port being damaged (bent pin), you will need to either have the connector in the GPS replaced or replace the GPS.
May 12, 2011 | GPS
To connect gps to computer wich pins do i connect of nmea cable?
pins 2(-) and 5(+) on a 9 pin serial cable, then you need a usb to serial adapter for input into the computer if you do not have a built in 9 pin serial port on you computer because the usb moves the information faster than the gps signal. gps is roughly 4800 baud, usb is moving so much faster you need a buffer
May 19, 2010 | Furuno GP32 GPS Receiver
I have two magella 4040's I was using themin a semi with them stuck to the windshield the solder joint on the charging port is weak, The 1st one had a 180 degree jack , straight out, the second one...
Re soldering the port is ok if the port it self is not damaged..they have A centering pin on the bottom and once they come loose for what ever reason, They shear that pin off, then theres Not much to keep them from moving again Because that pin on the originals Always break off. I also use a little hot glue To keep help keep it put Just As a precaution. The ones I sell, I haven't had any returned yet neither the ones I fixed or The ones the people put the port on themselves, I have however had to guys wanting me to fix there 4040 because they ripped the tracers off the board. (now there junk) I cant repair anything that has the tracers damaged, If I get one like that, I do not even try to fix it, because its beyond My capabilities. To answer your question I do sell the ports for 14.99 on ebay 12.99 off ebay shipping included And yes I do repair them but not if the tracers are damaged. I normally charge 45.00 to repair them and I pay the ship back but if you want me to do both of them And your going to pay shipping both ways. Ill do both for 80.00 I'm not trying to talk you out of anything but if you can solder half decent, I'm sure these would hold up for you, the hardest part is removing the old port without damaging the tracers
Jul 19, 2009 | GPS
GPS wont work!!
most likely the power port is damaged and needs replaced.
i repair those magellan gps if you need help. if i cant fix it there is
no charge. wmetz@comcast.net
May 28, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
May 28, 2009 | Navman PiN 570 GPS Receiver
Battery charging problem
May 17, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan 3100 won't charge
you cant charge a 3100 with the USB connection. most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
Mar 26, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Interfacing
have you checked to make sure that your serial port is enabled in your computer bios.
to check:
some computers require you to press del while booting other esc.
the message should read somthing in the line
press ???? to enter setup
go to the advanced tab
look in IO (Input/Output) devices or somthing similar.
Make sure Com1 or UART is enabled.
If the device is enabled, then check to make sure that your cable is making a connection properly.
(May require you to open up the unit) if out of warantee
To check that the cable is connected properly on the outside contact to db9 port.
Pin 1 2 5 are used on the db 9
on the inside there is a cable with 4 wires soldered to a board which links the outside to the inside.
Connect your serial cable to the GPS, using a multimeter check continuity by holding red lead on pin 1 of db9 serial port and checking each pin for continuity. only 1 should indicate continuity, continue with pin 2 and pin5 on serial port connector.
If you are sure that there is connection between cable and GPS, check the cable from the soldered points to the GPS Board. If those are ok, then you may have a problem on the board. Would then sugest you take it in for checking.
Jul 05, 2008 | Garmin eTrex Legend GPS Receiver
Rand Mcnally Intelliroute TND 510 Truck GPS Logo
205 people viewed this question
Top Rand Mcnally GPS Experts
Steve F
Vuk B
Are you a Rand Mcnally GPS Expert? Answer questions, earn points and help others
