Question about Brother Sewing Machines
How do I get my brothers pacesetter XL703 to come off the stretch material stitch
The needle goes forward and back and I want a straight stitch
    Sergeant:
  • Brother Expert
  • 455 Answers
Marilyn, get your manual and read... That is a simple stitch selection change.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Posted on Nov 30, 2014
  • 106 Answers
SOURCE: Can't get a neat straight and stretch stitch underneath
Sounds like a bottom tension problem, to be sure I would have to have a look, I would suggest you have it looked at. Not sure about the materials you are sewing and have serious doubts as to whether the machine you are using is up for the job and will give you a satisfactory finish. It is possible a "walking foot" machine is what you need.
Posted on Mar 26, 2008
  • 4 Answers
SOURCE: Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Posted on Nov 30, 2008
  • 632 Answers
SOURCE: Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Posted on Jan 05, 2010
  • 255 Answers
SOURCE: Elna Stella TX - stretch stitches missing on stretch material
Oh yes, a ballpoint needle would indeed help.
Good luck and let me know if this solves the problem.
Posted on Jan 15, 2010
  • 68 Answers
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Posted on Feb 25, 2010
I cannot get my Pacesetter PC 6000 to adjust the the stitch length. No matter what I set it on, it looks like a basting stitch. Please help???
Quick test: Does it stitch correctly on paper? Or do you see something like _ ____ _ _ ________ _ ________ instead of _ _ _ _ ?
If it doesn't stitch correctly on paper:
Clean the machine, paying particular attention to the bobbin case and shuttle area and put in a new needle, right way around (flat side to the back) appropriate in size and thickness to the fabric you're going to sew... sharps for wovens, ballpoints for knits.
This is often a user error -- needle in backwards, needle size too small for the fabric, needle point style wrong for the fabric -- but it can also be due to a bad needle, dirty machine or a machine a little out of time (though that's quite rare). It can also be due to "flagging" -- the fabric rises and falls with the needle like kids bouncing on a trampoline. Paper or other stabilizer above and/or below the seam can help.
Jun 20, 2014 | Brother PC-6000 Pacesetter
How do I set for basting
Some compuerised machines will have a basting stitch programmed in, it may have a symbol like a dot then a long dash then another dot. This will give you a decent spaced basting stitch. On mechanical machines sometimes you can get a basting needle plate - you set up for the longest widest zigzag stitch and the tube on the plate makes one side of the zig not catch so you get a long straight stitch.
But if you are joining silky fine fabrics together, then needle and length of thread doubled is still the best way, takes a little longer but the fabrics won't creep and slip.
Oct 23, 2011 | Brother PS-1250 Pacesetter
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
I have just bought a Brother XL 5500SE. I am having problems with sewing jersey fabrics. I need a stretch stitch=SS- but cannot regulate the stitch length. and the dial of stitches available e.g. 13...
i would use ball point needles and check my manual for what they suggest for stitching. Sometimes the shell stitch is great and other times I use the straight stretch. If, you look at your manual you will see a chart as to what the best size needle and thread for your project. Don't be afraid to experiment, just relax and enjoy. All it costs is a little scrap material and you can teach yourself so much. Go online for support if you need it at Brother-usa.com and they have frequently asked questions there, too.
Sep 28, 2010 | Brother Sewing Machines
I have a brother pacesetter 607 model. It used to work very good for years but lately its not sewing the zigzag or any other stitch other than the straight stitch. can you help please? Thanks.
Simple things first, check the needle to make sure it is perfect, if you can select all the patterns and the needle moves from side to side but does not pick up the thread then it could be a timing issue and you can email me for attachment of instructions, if the needle is not moving side to side when you select a pattern then it may well be a split camstack.
drivewithken@blueyonder.co.uk
Jul 05, 2010 | Brother 925D Serger
Jan 13, 2010 | Elna Sewing Machines
Skipped stitches
Change the needle first and make sure it is inserted correctly. Use good thread i.e.: Guterman or Metler are some. If you are using a stretch material then put a stretch needle in the machine. If you do all this and it still skips then you may have a mechanical problem with the machine. The machine is "out of timing". Have a good tech. look at it. This happens quite frequently on "inexpensive" machines. Sorry.
Jul 17, 2009 | Brother LS-1217 Mechanical Sewing Machine
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
How do you thread a brother pacesetter 6000 for twin needle sewing
Two reels of thread on the top,make sure the threads go seperate sides in between the tension discs, thread both needles but remember not to put the stitch width more than 2.
May 02, 2009 | Brother PC-6000 Pacesetter
Mar 25, 2008 | Bernina Activa 130
Sewing Machines Logo
100 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
