Question about Dometic CF-050DC CF-50 Waeco CoolFreeze Portable Fridge Freezer DC Onl
Waeco cf50: error code is 3 flashes
Turn on and fan runs compressor doesnt. Panel lights up but 3 flashes come up on error code
    Master:
  • 371 Answers
This company website is: www.waecousa.com
SPECIFIC product information
including "for service" suggestions, is here:
http://www.dometic.com/enus/Americas/USA/RV-Products/Portable-Refrigerators/products/?productdataid=81811
You can download the product manual
at the (elsewhere) link below - however it does not include the error codes:
Download Manual - DreamMaker Hot Dog Carts:
www.dreammakerhotdogcarts.com/manuals/cf-series.pdf
Lastly, while not what you specifically asked for, here is their (lengthy!) 'Plan B' contact information. Hope this helps!
For RV products:
Customer Support Center
2320 Industrial Parkway
Elkhart, IN 46516
Phone: 1-800-544-4881
CustomerSupportCenter@DometicUSA.com
Sales and Marketing
Elkhart, IN 46516
Phone: 574-294-2511
Fax: 574-293-9686
Recall Department
Dometic Corporation
Recall Phone Numbers:
Servicers: 888-803-0013, press 3 and enter your account number Consumers: 888-446-5157
Recall Fax Number: 574-389-3955
For Marine products
SeaLand and VacuFlush toilet systems and products
Dometic Corporation
Sanitation Division
P.O. Box 38
Big Prairie, OH 44611
Sales and Customer Service
13128 State Rt 226
Phone: 1-800-321-9886
Phone: 330-439-5550
Fax: 330-496-3097
sealand@dometic.com
For Dometic's air conditioning systems
including Cruisair and Marine Air Systems,
and other Adler/Barbour, Grunert, Eskimo Ice
and Sentry products -
Dometic Marine Division
2000 N. Andrews Ave.
Pompano Beach, FL 33069
Phone: 954-973-2477
Fax: 954-979-4414
Tech Support 8:00 AM to 5:00 PM ET: 800-542-2477
Tech Support After Hours & Weekends: 888-440-4494
MarineSales@dometicusa.com
Marketing Division
Phone: 954-973-2477
Fax: 954-970-8703
For Truck products
Dometic Corporation, Environmental Division
P.O. Box 15299
Richmond, VA 23227
Phone: 804-746-1313
Fax: 804-746-7248
sales@dometictruck.com
For Hotel products
Toll Free: 800-301-8118
lodging@dometicusa.com
Dometic USA
PO Box 490
Elkhart, IN 46515
Phone: 574-294-8665
Fax: 574-294-3369
Posted on Nov 10, 2014
Mains adaptor for waeco cf50 has broken down (240 volt)
Have you tried getting in touch with an authorized service center?
Or Waeco Pacific Pty Ltd, 1 John Duncan Court Varsity Lakes QLD 4227 Australia Phone: (07) 5507 6000 Fax: (07) 5507 6001.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 22, 2008 | Refrigerators
Tv doesnt show anything
Got (if model listed is correct) any blinking lights?
Set has a self check:
Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 29, 2012 | Mitsubishi WD65737 65" DLP TV
Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Apr 18, 2009 | Fujitsu 24R1 Air Conditioner
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dometic CF-050DC CF-50 Waeco CoolFreeze Portable Fridge Freezer DC Onl Logo
439 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
