Question about Honeywell RTH7600D Touchscreen 7-Day Programmable Thermostat
How do I change the date on my thermostats rth7600 after it is programmed. I clicked the wrong date
  • 89 Answers
Heat pump works but not ac with honeywell rth7600
Was there an Rc and and Rh terminal on the thermostat sub-base??? If so, there must be jumper across the two for the cooling portion of the circuit to be energized.
Mar 19, 2015 | Honeywell RTH7600D 7-Day Programmable...
Change factory set date on thermostat
This is just general information for most thermostats. Press the set button until the date comes up. Press the up or down temp. buttons to where you want it. Press the run button to lock it in. I hope this helps.
Nov 11, 2013 | Honeywell Programmable Thermostat Heater
Hooking up a new thermostat honeywell rth7600 from a honeywell t8411r. we hooked up the wires as shown in the installation manual- we have fan but no cold air blowing out or it feels like the heat is...
apparently who ever did the wiring installation did not use the Proper color coding when they did the install. Now you must trace the wiring to the appliance and wire accordingly.
Oct 10, 2013 | Honeywell Programmable Thermostat Heater
Replacing chronotherm with new rth7600
R= power in G= fan Y= cooling W=heat O= heatpump reversing valve C= common used for clock on chronotherm Usually its pretty streight forward wire for wire. Unless you have a heatpump. The thermostat has to be heatpump compatable. And I ll usually use the 8000 for this. The w and y jumper may not be necesary on the new thermostat as the new one should do it internally once programed as a heatpump thremostat. At least thats how the 5000 and 8000 sreies work. So imagine the 7000 would be the same. You may also have to program the reversing valve operation not all manufactuers do it the same . Some valves have to be powered for heat while others have to be powered for cooling. Good luck
Jun 16, 2013 | Honeywell Programmable Thermostat Heater
How do i change the honeywell rth7600 thermostat from fahrenheit to celsius
http://www.homedepot.com/catalog/pdfimages/85/855cb54b-bbb7-45e8-b7a4-4c868f05e142.pdf
See 12a.
1. Press System/Fan
2. Hold down Fan for about 5 seconds
3. Press the "120" on the middle
4. Press the up to 320
5. Set to 1
6. Click done
Aug 04, 2012 | Honeywell Heating & Cooling
Where do I put the wires on my honeywell thermostat RTH7600. they are black green red and white
This is the official installation guide for your thermostat. Go here:
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Jul 06, 2012 | Honeywell Programmable Thermostat Heater
The date created is wrong on my photos
The file properties will always show the date downloaded, since that's the date the file was created on your hard drive. The date (and time) the photo was taken is stored in the file itself, in what's known as the EXIF data.
I don't know what operating system you're using, so I can't give you specific instructions on how to get the date the photo was taken. On Windows Vista, for example, if you click (not double-click) on a file in Explorer, the date taken will appear in the status area at the bottom of the window. Other programs will have different ways of displaying the EXIF data.
Feb 10, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I need to reset the date and year
I had exact same problem with RTH7500. Did not set the date properly at the beginning and than realized that there is no menu option to change the date after it is saved once (???!). I was very confused for few hours and wandering - trying to find changing option on thermostat menu; than I was looking online what can be done... I could not find solution...
Than I took out both AA batteries, open the thermostat (be very careful while doing this - you don't want to break plastic peaces that hold the thing together) and took out the button battery thinking that this will reset the thermostat... but it did not.
I repeated the same thing, but this time, while the button battery was out, I put two AA batteries back and this reset the thermostat... the old - blinking date appeared and I was very happy to see this on thermostat screen! This time I set the time properly and it works fine.
Hope this will be helpful if you did not solve the issue yet... if you did, someone else might find this solution useful.
Mar 01, 2009 | Honeywell Electronic Programmable...
Honeywell RTH7600D Touchscreen 7-Day Programmable Thermostat Logo
206 people viewed this question
Top Honeywell Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Honeywell Kitchen Range Expert? Answer questions, earn points and help others
