Question about Andis Hair Trimmer PMT1 Pivot Pro Trimmers
My black wire has came loose in side of my Andis model Pmt-1 how do I repair it
The Black wire is hanging where does it Go
2 Suggested Answers
  • 8 Answers
SOURCE: I brought the andis speedmaster with the pivotpro
Some outliners have an adjustable blade set while others are fixed. You will need to remove the blade set and observe if the movable blade is adjustable forward and backward in relation to the stationary blade. If it is adjustable, take caution no to adjust the two blades completely flush. If they are too close they will nip and pinch and can break the skin.
Posted on Apr 10, 2011
How do I find what model my Andis pet clipper is
On the back of the clipper it should say something like AG, AGR, or AGC does it look like any of these dog clippers Dog Clippers .
Has it got a power cable or is it a Rechargeable? Also age is a good clue?
Feb 04, 2014 | Andis AGC2 Hair Trimmer
Red wire loose hanging from inside front of window a/c.Its a frigidaire model #fra105ct1.the red wire is zip tied to a double black wire that goes to the front radiator of the a/c.Would ya know what it...
If its hanging out of the front, I would think that its a broken wire off one of the sensors. There are usually 2 sensors on the front. 1 measures room air temperature, (Air sensor)and the other measures the refrigerant temperature in the pipes (Pipe sensor) The air sensor has a small bulb on the end of it and is usually clipped onto the front of the coil or the front panel.. The pipe sensor has a small copper tube on the end which slides into a hole or sleeve on the side of the evaporator coil.
Jan 28, 2018 | Dehumidifiers
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
I brought the andis speedmaster with the pivotpro trimmer model pmt-1 as was happy to purchase but when I got home and use the pro trimmers they didn't outline the way I expected I thought they would edge...
Apr 10, 2011 | Andis Pivot Pro 18174 Hair Trimmer
When I attempt to use my andis T Outliners, I get a shock when the blades touch my skin. They haven't gotten wet and I've tried plugging them in different sockets. Can you please help me?
The electrical wire Red or Black is bare and touching the shunt arm on your Andis T, check for this by unscrewing the top screws, (make sure you unplug the electrical cord on your Andis T before you open the top cover) Check to see if the black tape is rap around the black and white wire, also check to see if the red wire is not lose or touching the shunt are if so you will see black arcing marks were it is making contact. if you need any more help email us at ask@mannyssharpening.com
Dec 14, 2010 | Andis 04710 Beard Trimmer
Loose wires.one white and one black at bottom of dishwasher
the black wire is the HOT wire ... it should be connected to 120 volts AC .. the white wire should be connected to the neutral/return wire (also white) ... the incoming AC line shoiuld also include a bare ground wire .. that should be attached to a green grounding screw ... if your machine is already hooked up then there should not be any wires hanging down not connected .. you may be able to see the incoming wire but it should be covered by the dishwasher panels .. all connnections should be made inside a metal box that should be provided under the machine and there should be a strain relief fitting that keeps the wire from pulling out of the box .. ..
Oct 06, 2009 | Dishwashers
Leviton 8299 combination
first you must know which wires are hot from the breaker box and witch ones go to the device you are switching--lets call it a light bulb. The hot wires coming from the breaker should go where it says "LINE" black one on the "HOT" side and white one on the "White" side. One of the black wires hanging out of the switch should go on the "LOAD" "HOT" side of the switch, then attach the other hanging black wire to the black wire going to the light with a wire nut. Your white wire going to the light must go on the "LOAD" "WHITE" side or it just won't work.
Apr 06, 2009 | Leviton 8299 Combination Switch / Smart...
Andis Hair Trimmer PMT1 Pivot Pro Trimmers Logo
802 people viewed this question
Top Andis Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Andis Office Equipment and Supply Expert? Answer questions, earn points and help others
