Question about Samsung Tablets & eReaders
Samsung tablet color night right - Samsung Tablets & eReaders
Samsung tablet has been stolen when someone broke into my house. How do I track it when I only have the box
There is some info (could be dated) here
What To Do When Your Android Phone is Stolen
There may be a more advanced methods if you have 3G and/or already signed up to Samsung / Google / other tracking apps etc
Jun 24, 2016 | Samsung Tablets & eReaders
NP-Q1 screen damaged
We don't physically replace the screens, we just offer advice and directions on what you can or should do
You can call 1-800-SAMSUNG to get the nearest repair shop or to order a new screen if you wish to replace it yourself.
Let me know if you need anything else
Oct 24, 2008 | Samsung NP-Q1U/600 Tablet PC
How to get my battery to charge. plugged it into charger and will not charge. had it on the charger all night and still at same percentage
Check the charger and cable if they are not originally coming with the unit itself.
If they are aftermarket, check if they both on their own can support 2A charging current. For the adapter, its rated ampage should be on the label by ampere. For the cable itself, it must be a SAMSUNG tablet compatible one.
Aug 24, 2015 | Samsung Galaxy Tab 7.0" SCH-i800 16GB 3G...
Proscan tablet
Someone set the password. You may need to do a factory reset while it is connected to a PC. You will lose everything on it but at least you will have a tablet again. Alternatively, you can try 100 passwords each night for 100 nights until you find the right combination of 4 numbers.
Jul 31, 2014 | Supersonic 7" Touch Screen MID Tablet
My screen suddenly out of nowhere polarized and changed colors... seems to be functioning otherwise...
It sounds like their is moisture or clamyness inside the tablet. Let it lay in the sun bit with the screen downwards. See if it solves the problem.
Apr 01, 2014 | Samsung Metallic Gray Galaxy Note 10.1in...
Binatone homesurft
look for option in "display"...invert color..or something like that has been selected
Jan 30, 2014 | Tablets & eReaders
Device will not charge
Yes, all products that you buy have to be "fit for use". The 3 R's apply, repair, replace or refund. Under consumer rights law, they have to do this. Make sure you bring all packaging and receipts with you and speak to the shop manager. If you get no joy (they have to, by law, help you) report it to head office.
Dec 31, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
My tablet is frozen
What is the model? I suggest you can approach Unlocking4u.com and get unfreeze code for your Tablet device.they offer unfreeze code for Samsung models.
Dec 17, 2013 | Tablets & eReaders
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
22 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
