Question about Panasonic Kx-tg6641-b Expandable Digital Cordless Answering System With 1 Hand
Speaker failure on Panasonic cordless
Three handsets of five lost their speakers, one at a time. Any thought what the cause can be? an I repair it? Can anybody else do it?
    New Friend:
  • 50 Answers
I had the same problem with my last Panasonic cordless set. I fixed them with some very small speakers from ear buds but for the price of cordlessphones these days just get new ones.
Posted on Nov 09, 2014
CRACKLES ALL THE TIME ON ALL THREE PHONES , NO NOISE ON THE CORDED PHONE I HAVE
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones
Jan 17, 2011 | Panasonic KX-TG6311S 1.9 GHz 1-Line...
I have a panasonic kx-tga271 handset. The speaker phone, the ringer and keypad noise do not work. Is it fixanle?
It could be the speaker. I have a handset with the same issue. The internal speaker which produces these sounds broke. If you can find a small speaker that fits inside, its an easy fix - - just take out the screw inside the battery compartment and carefully undo the plastic assembly. The speaker is held in place with a plastic anchor that twists off. There are two dots of solder which attach the wires that will have to be melted and resoldered on the replacement. Anyone thats handy can fix this. Look for a used handset for parts. You might also consider breaking apart a cheap set of headphones for the speaker. It won't be as loud, but at least the sound will be restored to some degree.
Oct 21, 2010 | Panasonic KX-TGA271 Cordless Expansion...
Hot do you fix Panasonic KX-TGA560M 5.8 GHz Cordless that has nothing displaying on the screen?
Cannot hear from handset or earphone, can only hear from speaker phone. What can be the problem.
Aug 24, 2010 | Panasonic KX-TGA560M 5.8 GHz Cordless...
Speaker no long speaks
Unfortunatly you will need to send it for a repair or purchase a new one. You might have a deffective transistor or such.
Contacts on this electronic devices are thiner then hair. Simple shake or higher current then usual can cause all types of failures.
Your question is similar to a question of why people die....
Jul 18, 2009 | Thomson GE DECT 6.0 Cordless Phone
My handset speaker is blown,can it be repaired?
you need to replace it with new one and place it back ok
Jul 17, 2009 | Panasonic KX-TGA560M 5.8 GHz Cordless...
All handsets cannot be used at the same time
Some of the cordless phones do not allow more than one handset to be used at the same time. Is there a transfer button on the handsets? Can you call from one handset to the other? If not the phones probably have to be used one at a time.
To get off speaker phone just push the speaker phone button again.
Jan 28, 2008 | GE 25931 Trio Cordless Phone
Answering machine replay is garbled
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Jan 11, 2008 | Panasonic KX TC1731 Cordless Phone
I cannot hear from handset
Try changing the speaker in the handset. I had the same problem and tried a new speaker and it fixed the problem.
Jul 28, 2007 | Panasonic KX TC1740 Cordless Phone
Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Panasonic Kx-tg6641-b Expandable Digital Cordless Answering System With 1 Hand Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
