My Simple Comfort 2000 thermostat show diff 01 in the display. It will not change when I push the buttons. I have just put in new batteries. When I returned from vacation I noticed corrosion on one
I have a Grandaire neat/AC unit
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
SOURCE: RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Posted on Mar 18, 2009
  • 248 Answers
SOURCE: I have a simple comfort 2000 thermostat and the
Sounds like the Fan/Auto switch is not working or is out of the circuit. Do you have a Volt/Ohm meter to check the switch? Set the meter on Ohms on the lowest range, turn off the breaker, disconnect the leads from the switch, and put the probes on the connections to the switch. The reading will be near zero when you touch the leads to connections that are turned on by the switch. You can buy cheap meters at Harbor Freight ($5) or other discount places. If the switch is working, it has been bypassed somehow, or the wires are connected wrong. Did you recently install the thermostat?
Posted on Aug 22, 2009
  • 74 Answers
SOURCE: thermostat reset???
after you changed the battries did you check the set point. it is also possible that the batteries have ruined the stat
Posted on Aug 30, 2009
shastalaker7
  • 1515 Answers
SOURCE: I need a diagram to
http://www.drillspot.com/products/571473/honeywell_home_bldg_center_rth7600d1006e_7day_touchscrthermostat
Shastalaker7
Posted on Apr 11, 2011
What is the tonnage on Trane AC Model # TTB030-048C?
Here's a really neat video applicable to any A/C.
Just FYI - your's is a 4ton unit according to this link -
Calculating tonnage of your air conditioner
Sep 25, 2017 | Heating & Cooling
I plugged it in and all of the lights come on, but when I press scan, nothing feeds. I hear no mechanical noise like it is trying.
Troubleshooting Scanner Problems in NeatWorks for Windows
www.neat.com/.../troubleshooting-scanner-problems-in-neatworks/
Troubleshooting Scanner Problems in NeatWorks for Windows ... Plug the scannerback into the computer, start NeatWorks, and try scanning again.
NeatConnect Scanning Issues - The Neat Company
www.neat.com/helpcenter/neatconnect-scanning-issues/
My LED screen wont turn on? If this is the first time using the NeatConnect scannerand you are not using it with a computer, please confirm that the cord is ...
Download Neat Software' Activate Neat ' Neat Company
www.neat.com/helpcenter/download-neat-software/
If you are looking to download or activate Neat software for your scanner, visitneat.com/activatend for more information. ... Desktop Software (For Existing Users) ...
Support - The Neat Company
www.neat.com/support/
Neat's Smart Organization System desktop software. ... Fast and efficient scanners to help convert your paper mess into an organized digital filing system.
Jan 14, 2016 | NEAT Desk Desktop Scanner and Digital...
NEED A DRIVER FOR My NEAT Scanner
Without a model number or OS there is little I can give you. However, the following link will take you to the NEAT support and drivers page. Pick the unit you have and the OS and you should be fine.
Nov 30, 2014 | Computers & Internet
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is on...is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
Hot engine air enters through opening where AC line goes into car
there is usually a shroud around the ac unit itself however they do break from heat etc. but if you feel confident sure with the use of a brush or putty knife cover the areas with even strokes being neat about it apply some-type of heat resistant caulking or other material to it
Sep 20, 2009 | 1995 Jeep Grand Cherokee
Hello, we have a grandaire unit in our house in florida. register set @ 77. unit can not keep up.outside temp @88 anything i can do before i call an a/c tech
check your filter if it clean then you should call a service company could be low on freon or needs cleaned and serviced.
Jul 06, 2009 | Heating & Cooling
Need new 13V AC power adaptor
a 12v adapter will do just fine.but make sure that the plug is fit for the unit.
May 20, 2009 | Altec Lansing Inmotion-IM600...
Heating & Cooling Logo
441 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
