Question about Crafts & Hobbies
Hello,idowloaded and paid for drawing painting,ye which ive enjoyed firstbits,,cant now find it anywer can you help please x
Well paid in full no probs,,started up going well.couple weeks not on here back on now cantfind anywere help please
5 Suggested Answers
pagebor
  • 2785 Answers
SOURCE: TOSHIBA SATELLITE P200 1JV
disable the display adapter from safemode and restart normally.down load the latest drivers for your display form the the website
Posted on Apr 01, 2008
  • 1294 Answers
SOURCE: indesit washeing machine
Karen, that was nice.........
Posted on May 31, 2008
SOURCE: i want corel draw 13 full user with cd key sofware downloed .
Hello, dear very good morning . How are you ? I want and need corel dorel draw 13 full user With cd key downloed where i downloed Setup? Please help me now . Thanks & Regards Ankit Shukla
Posted on Jun 16, 2009
ssddff222
  • 101 Answers
SOURCE: i don't know how i
  1. Open up the MS Paint program to start a new document. The program can be found in the Accessories menu on your computer.
  2. Click on the background and foreground boxes, and select the colors you want each to have. Using a white background and black foreground is the most common choice for drawing manga because you can colorize it later.
  3. Select the tool you want to use to draw a manga picture of a face, for example. Using the pencil tool allows you to draw any type of shape you want while clicking on the buttons for ellipses or rectangles will make that shape appear on your screen.
  4. Draw the facial features with the pencil or brush tools.
  5. Make light glares in the eyes by using the eraser tool. Click on it, and then remove a small section of color from inside the iris.
  6. Create hair by clicking the "Line" and "Curve" buttons. These tools draw lines wherever the cursor is placed.
Hope this helps :)
Posted on Dec 28, 2010
Hello, im having problems with my Audiobahn a2300hct amp. Ive bought it from ebay, putted in my car, added my sub wirred on 2 ohm. It had pumped it for about 5 mins, and then went into a protection mode....
HELLO THESE AMPS ARE FAMOUS FOR DRAWING ALOT OF CURRENT AND IF YOU PLAY THE AMP WHILE THE VOLTAGE DROPS FOR TOO LONG YOU CAN FRY THE AMP BUT AS FAR AS THE SECOND AMP NOT WORKING AS WELL YOU MAY HAVE A PROBLEM WITH THE RCA'S OR THE OUTPUT ON YOUR HEAD UNIT WENT BAD OR YOU HAVE A BAD GROUND CHECK ALL FUSES THEN CHECK THE GROUND WIRE TO MAKE SURE ALL PAINT HAS BEEN SCRATCHED OFF AND THAT IT IS CONTACTING BARE METAL THE ONLY OTHER OPTION IS FIND A FRIEND THAT HAS THEIR WIRES RAN AND HOOK UP YOUR AMP ON THEIR SUB IF IT WORKS THEN TRY IT WITH YOUR SUB IF IT GOES INTO PROTECT THEN YOU MAY HAVE A BLOWN SUB CAUSING THE SHORT HOPE THIS HELPS THERE ARE ALOT OF OPTIONS START WITH THE WITH GROUND AND GO FROM THERE
Dec 06, 2014 | Car Audio & Video
Tip
Painting patterns using stencils
Painting a pattern on your wall can be very difficult if you want all the shapes to be the same size and level. But just like when you were little and had letter or shape stencils to help you draw perfect drawings, you can make stencils yourself for what ever it is that you want to paint on the wall.
Using a sheet of cardboard or a contact sheet draw and cut out the shape that you want to paint. If you want to make a pattern that goes all the way around the room then you should make two or three stencils so you can level them.
To use the stencils first prepare the wall you want to paint, you want to paint the base color before you use the stencil because painting around your design can be very challenging. When the wall is dry take your stencil and using painters tape, tape the stencil to the wall so it doesn't move. Making sure that you don't over load the paintbrush paint inside the stencil trying to be careful around the edges. When you finish filling the stencil carefully lift it off, make sure that there isn't any paint on the underside of the stencil because if there is and its wet it will leave unwanted marks on the wall.
Repeat the process of taping, painting and lifting until you have finished painting your pattern on the wall. When you are finished step back and enjoy your handiwork.
on Oct 24, 2013 | Crafts & Hobbies
I have a bad draw on my battery on my 85 toyota pickup ive removed the postive battery terminal and placed a volt meter between the positive battery cable and the positive battefy terminal its pulling over...
Had similar draw (not alternator specific) that two auto electrical repair experts diagnosed wrong that turned out to be a stuck starer solenoid that would not full release after cranking. Cleaned the solenoid (very simple and easy) and no more draw.
Could be a bad battery.
Mar 14, 2014 | Toyota Pickup Cars & Trucks
Lost password optoma hd66
Manufacturers normally have a backdoor, a four digit password to gain access into their operating software when the user changes the password settings.
Optoma people told me their default PASSWORD is usually 2468 or 8642. One of the two will work to unlock access to full menu options.
Remember to rate my answer as you can now enjoy your projectors 100+ inches :)
Dec 06, 2017 | Optoma Hd66 Hd-66 3d 3-d Home Theater Dlp...
DrawCast - Drawing/painting/sketching for iPhone Logo
Save the drawing to your photo album, and then post it from your photo album to Facebook.
Apr 28, 2012 | Daniel Cota DrawCast -...
I want corel draw 13 full user with cd key sofware downloed .
May 04, 2009 | Adobe Photoshop CS2 for PC
Starview codes for chorus cork 4th March 2009
00=CE 19 2E 87 80 61 74 90
01=62 FA D9 F3 CE 05 FA 79
should work
Mar 04, 2009 | StarTech.com StarView SV211K 2-port KVM...
Sony ericsson w910i
if its a pre paid you have to call 1512 for credit balance.
Jan 04, 2009 | Sony Ericsson W910i Cellular Phone
Crafts & Hobbies Logo
414 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
