How do I hook up a funal remote to a toshiba tv
How do I hook up a funal remote to a toshiba tv and is that possible because my toshiba remote broke and I was wondering if it was possible to switch that funal remote over to a toshiba
    Top Expert:
  • Televison & ... Master
  • 35,654 Answers
If your Funai remote is programmable, you can search for a suitable code for your Toshiba TV. If no result, you may have to try another programmable remote.
Posted on Nov 09, 2014
Can you help, i have a toshiba tv (quite old, not flat screen) and i broke the remote control. I now have a [URC22S Universal Remote Controller] and I'm having a lot of trouble getting it to work
Please provide more details. What do you want to know. Setup codes? If so, check this site. Setup code list and setup proceedings to many popular brand remote controls are given.
Apr 22, 2013 | Televison & Video
Hooking VCR to DISH Network Reciever Box
In order to diagnose the problem I need your help.
Have you hooked the dish receiver directly into a tv or another device and had it working?
Have you tried a different cable at all?
Have you tried pressing the ant. button on the remote or tv/vcr button?
Please update me with as much info as possible and I will figure out where the problem is coming from. thanks
May 04, 2008 | Toshiba W627 VCR
My on off switch is broke! anything i can do?
Switch on the power.then use use your remote. or replace power switch. unplug first before replacing switch.
Apr 04, 2011 | Toshiba 35A44 35" TV
Model 32HF73 I replaced the remote from Toshiba and I don't have a vcr or anything hooked up to it and the remote won't work. Sometimes when I was pressing the on/off switch a bunch of times,not turning...
hello, usually if the remot control is ok, then the infrared receptor need to be replaced, he is placed near the stand by light.
in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility
that something is wrong at the microprocessor circuit.
i hope it was helpful!! Let me know if you need further guidance
Nov 09, 2010 | Toshiba 27A34 27" TV
Can get tv to work after hooking up to cable
Try using the input button on the remote's. and keep pushing it to see if it changes to a regular channel.. But first try turning on the TV switch on the TV.
Feb 07, 2010 | Toshiba 32A33 32" TV
Our daughter gave us a Toshiba TV and remote. We plug in the TV and hook up the cable,and try to turn on the TV but nothing happens. We can turn on the TV with the TV button,and it works fine,but we would...
If the remote is the original Toshiba remote, it obviously should work the TV. Have you checked to make sure it has good batteries? Also, if old batteries leaked in it at any time there may be corrosion on the battery contacts keeping it from working. Make sure the metal contacts look shiny, not crusty and corroded.
If the remote still doesn't work there are two possibilities. One is that the remote is just bad. You can get a universal remote, set it for Toshiba and try it. It will at least control power, channel and volume functions. If the universal remote doesn't work, the remote sensor in the TV would be the probable cause. Like any other part, they can sometimes fail.
Apr 11, 2009 | Toshiba Televison & Video
Toshiba mo#20af44 hooking up 360 xbox
As far as I'm aware, the only way to switch inputs on the TV is by using the Toshiba remote--there aren't buttons on the TV itself to do it. Which means unfortunately, if nothing on your universal remote will do so and you don't have the Toshiba remote (either to use or to reprogram your universal remote with), you may be out of luck.
Oct 11, 2008 | Toshiba 20AF44 20" TV
Masterplug tvr c4n remote(universal)
Try these simple trick to find out your remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the TV.
Jul 13, 2008 | Philips Magnavox Learning Universal Remote
Antenna hookup broke off
You have to re solder the connector. The other solution is to patch from the Direct TV box AV out to the AV input on the back of the TV. This will bypass the tuner and give you a cleaner picture. However, if your TV does not have an external input you must re solder the connector. As easy as it may seem, this should be done by a qualified technician. Its not as easy as it looks and requires good soldering skills.
Nov 12, 2007 | RCA F19207BC TV
Coding to the dvd player remote.
not sure you could code it to the dvd remote or not but you can get a replacement remote from here that would work on your tv
http://replacementremotes.com/store/productdetailp.cfm?productid=17889
riz.
Oct 21, 2007 | Sony DVP-NS55P DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
