Potterton 80 locks out any suggestions why.
The boiler turns on, and after a few min makes a noise as if its leaking air or something and then the flame switches off. It has been cleaned , pump changed and full flushing was done in last three days. It has a new CH flow valve as well. Thank you
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Try cleaning the hole where the pressure sensor tube / rubber hose connects
Posted on Nov 30, 2014
SOURCE: My oil boiler is a
The actual final solution was to replace the fuel valve/solenoid following which the boiler has run without failure.
The conclusion was that the fuel valve solenoid was ok when cold but when heated up had some sort of electrical breakdown in its coils, causing the fuel valve to fluctuate until the boiler locked out.
Posted on Oct 17, 2008
jcpark50
  • 52 Answers
SOURCE: boiler making a loud hissing
sounds like a stuck expansion valve, the compressor makes pressure, but it can't be released to absorb heat from the desired environment. You could go to the manufacturer's website, request a detailed diagram of your system, find the expansion valve and order a new one. Can you put it in yourself and recharge the system? Probably not, call a repairman.
Posted on Nov 07, 2008
  • 85 Answers
SOURCE: Amana Gas furnace, Air Command
Buy a new ignitor here; The Ignitor Store. Or talk an Amana dealer/Contractor to sell you one. They can range from 15 to 35 bucks! Depending on their mark-up. Give them your model number, and or ignitor part number. Their simple to change out, good luck, please contact if you have any questions.
Posted on Dec 02, 2008
daddyo742001
  • 70 Answers
SOURCE: Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Posted on Jun 28, 2009
SOURCE: When firing the lochinvar knight
This kind of Manual High Limit issue can most likely be caused by two things :
1) If it's a Knight XL (399MBH and up), it's equiped with a manual high limit with is located in front of the boiler, behind the front panel just under the display bezzel. It has to be adjusted and reset (with the manual reset button on the control display).
2) If your unit is NOT equipped with that kind of Manuel High Limit, this message means that there was a low voltage wire that was shorted to the ground. Either the flow switch or the thermostat wire. The 24v fuse located on the main control board burned to protect the components. Lucky, Lochinvar provide replacements in the small plastic bag attached to the connection board.
Hope this help. Even if i'm late.
Posted on Nov 11, 2010
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Potterton profile not firing
did you bleed the pump as well
Jun 09, 2012 | Heating & Cooling
MAKES A LOUD NOISE AND BLOW HOT AIR AFTER BEING ON FOR A 5MIN
You can try to turn the power off and then on again at the disconnect for the outdoor unit...
However the problem is likely more complicated then that...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 25, 2010 | Ruud UBHC Air Conditioner
Potterton statesman utility boiler making screaching noise for 20 mins on start up then stops screaching and runs quietly!!!
Hi my boiler has just started to do the same. Have you had yours fixed and do you know what the cause was and how the problem was solved?
Thanks for a reply
Feb 18, 2010 | Heating & Cooling
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
Baxi 80 e some rads hot others cold
is the pump running or is there an air lock near to the boiler check water tank in loft the smaller one to make sure you have water in the system
Apr 24, 2009 | Combi Centre DX - Mango
Repressurise Potterton Performa 24 boiler
hope this is helpful. On my potterton 24 combi boiler it is the valve that sits the lowest, with a slight indent in the black tap. if you turn this for a short period you will hear a hiss and the pressure will quickly build to the desired pressure, when you can them turn the tap back off.
Jan 07, 2009 | Heating & Cooling
Ariston eurocombi boiler not firing up. Thermostat lights all on upto 80 degrees as if overheating. Pressure fine. No fan, no ignition.
The fault occured a few days after I altered the radiator layout and then refilled the system. Intially the boiler worked fine, then a few days later all of the temperature lights light upto 80 and the boiler would not fire. The pump was working but the fan was not. After diagnosing the electronics I came to the conclusion it was either the contol pcb or the temperature probe. As the temperature probe was the cheaper option I replaced that first. The system is now working again. I think this fault was caused by me failing to completly remove all air from the system after refill and an air lock occuring causing the probe to burn out.
Nov 26, 2008 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
