Question about Kitchen Appliances - Others
I have a Morphy Richards Toaster 44469 .One of the heatting panels has a broken element . It seems a shame to throw it away. Can the 4 slice central heater compartments be bought as a spare ?
kachbibi1
  • 979 Answers
SOURCE: Problems with Dualit 20247 2-Slice
It is probably not under warranty. I would advise getting a new one. By the time you send it off and pay the repair and get it back, you will have a repaired toaster will a question mark on when it will go down again. Get a new one same brand.
Posted on Feb 07, 2009
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
  • 56 Answers
SOURCE: What type pf screw driver do I need to unscrew the
Try getting he star srewdriver with the smaller one for the other srew
Posted on Mar 19, 2010
espressonist
  • 1711 Answers
SOURCE: Our 4-slice toaster (model 4cbc) is only toasting
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Posted on Apr 02, 2010
My machine stopped heating but everything else functions. Can that be repaired?
There is an element in the bottom.
Google
make model element
They appear to be available
Find Bread Maker Machine Heating Element ' eBay www.ebay.com > ... > Small Kitchen Appliances > Bread Machines Bread Machine Parts Finder is the place to find a Heating Element for your breadmaker. Bread Machine Parts Finder has a breadmaker Heating Element ...
Bread Machine Heating Elements - By Bread Machine Parts ...
www.breadmachinepartsfinder.com/catalog/25 Element-ABM300, Welbilt Bread Machine Heating Element ABM300, $9.99. Element-ABM300, Welbilt Bread Machine Heating Element ABM300-1, $9.99.
Bread maker Heating Element ' Bread Machine Parts Finder
www.breadmachinepartsfinder.com/taxonomy/term/696 Skip to main content. Bread Machine Parts Finder logo. Main menu. Home ยท Comments. You are here. Home. Bread maker Heating Element. Subscribe to Bread ...
Bread Machine Heating Element - Alibaba
www.alibaba.com > Home Appliances > heating > heating element Bread Machine Heating Element, Buy Various High Quality Bread Machine Heating Element Products from Global Bread Machine Heating Element Suppliers ...
What To Do If Your Bread Maker Stops Working? ' Mr ...
www.mrbreadmaker.co.uk/.../what-to-do-if-your-bread-maker-stops-wor... Apr 12, 2013 - Read our guide on dealing with common bread machine problems. ... are colder and the heat element is not working right then your bread will ...
Morphy Richards Breadmaker Parts ' Partmaster
www.partmaster.co.uk/morphyrichards/breadmaker/catalogue.pl?... Morphy Richards Breadmaker parts - repair your Morphy Richards Breadmaker with a Breadmaker spare part from Currys Partmaster. Worldwide and Next Day ...
Morphy Richards 48280 FastBake Bread Machine Heating ...
www.fixya.com > ... > Morphy Richards 48280 FastBake Bread Machine ...heating element for my SDYD 250 bread maker ? After three uses, the unit no longer heats up......I think it is either a bad control board, or a defective heating ...
Breadmaker Spares ' Spares & Accessories
www.morphyrichards.co.uk > Spares & Accessories Buy a Morphy Richards Breadmaker part. Spare parts for Morphy Richards Bread machine.
and a video of how to change.
How to replace the element in a breadmaker - YouTube
How to replace the element in breadmaker
Feb 06, 2016 | Kitchen Appliances - Others
Voltage change to 120V
You can change the plug out but I very much doubt that your toaster will even heat. The way toasters work is by a resistance wire that heats up because of the current going through it that causes the wire to heat up. Since the wire that is in your toaster is designed to heat up under 220V drawing 9 amps. SInce you are now supplying only 120V then since I=V/R then in the first instance 9=220/R or 9*R=220 =24.444 Ohms Since in the second instance your V=120 then your Current =4.9 Amps and this will not be enough wattage to heat up the wires.
Jul 14, 2013 | Morphy Richards Accents 44744 4 Slice...
Morphy Richards Fastbake makes cruching noises and debris
Hi, what sometimes happens is the drive belt snaps or comes off the pulleys underneath. If your machine has a removable panel on the bottom remove that panel and let me know if the belt is broken. If it is don't throw it away. I'll need the code # off the belt to see if I have a replacement in my stock. Email me if your belt has broken.
Apr 24, 2013 | Morphy Richards 48280 FastBake Bread...
Toaster, 4 slice, throws safety switch when toaster heats up.
If it is throwing safety switch, other wise know as circuit . I assume your talking about wall plug in circuit. If this is true, then you can try moving to different out let. All kitchens, where a toaster normally would be plugged in is a series of at least out lets by code requirements. If you find another outlet, that is on a different breaker, then should not trip. If you are on same circuit right now that fridge is on or microwave, toaster might be to much in conjunction with the fridge running continuously ,and micro wave at regular use. Please let me know if this helpful info to solf problem. Thanks mike from fixya
Jun 14, 2011 | Morphy Richards Kitchen Appliances -...
Where do you buy the special screw driver to take the bottom ff the 44336 toaster as the toaster wont stay down on that side?
Well, I don't have that type of toaster. What do the screws look like? If they look kind of like allen but an allen wrench will not work, they would be TORX.
Feb 03, 2011 | Morphy Richards 44051 4-Slice Toaster
I just bought a dab from Morphy Richards and, it appears that you need aa remote to change channels. Could this be so? Display says press select yet there aint no select on the unit... model is Morphy...
ok i just found out what it is digital radio !!!!!!!! ok i dont think we have a radio department but i think we still have a car audio department . those guys should be up on all this new stuff .... good luck
Mar 30, 2009 | Morphy Richards 44051 4-Slice Toaster
Morphy Richards coolstyle Model 44880 4 slice toster
I have the 44280 2-slice version and had similar problems. To dismantle, unscrew the two star-shaped screw heads which hold the retaining slides in place. I don't have a star socket (female), only the usual male, so I used a pair of pliers. Pull out the two chrome slides. Pull off the two knobs also using pliers. Remove the outer casing with care as there are two fine wires attached. Now you can see the problem - probably a broken or lost nylon retaining catch on the electromagnet, and probably unobtainable by an individual. At this stage I decided to buy a new toaster!
Alec
Sep 29, 2008 | Morphy Richards 44778 4-Slice Toaster
May 01, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Kitchen Appliances - Others Logo
93 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
