Does this have a radio - Audio Players & Recorders
  • kakima Nov 09, 2014
    What make and model is "this"?
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 02, 2011 | Hyundai Motor 2003 Elantra
I need a radio wiring diagram for a Hyundai Accent 11/2000.
Radio 12v orange/black + radio
Radio Ground black - radio
Radio Ignition blue/black + radio
Radio Illumination green/orange + radio
Factory Amp Turn-on
Power Antenna pink + radio
LF Speaker +/- red - blue radio
RF Speaker +/- white - brown radio
LR Speaker +/- green - orange radio
RR Speaker +/- orange - blue radio
Feb 27, 2011 | 2000 Hyundai Accent
I need a radio wiring diagram for a 1995 jeep wrangler
Answer
Radio 12v
pink
radio harness
Radio Ground black - radio harness
Radio Ignition red + radio harness
Radio Illumination orange (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- dk. green - brown/red +,- radio harness
RF Speaker +/- purple - dk. blue/red +,- radio harness
LR Speaker +/- brown/yellow - brown/lt. blue +,- radio harness
RR Speaker +/- dk blue/orange - dk blue/white +,- radio harness
Jul 15, 2010 | 1995 Jeep Wrangler
2002 kia speaker system diagram
It all depends on the Kia model but here is a diagram to get started with.
Radio Wiring Information:[B/]
Radio 12v red + radio harness
Radio Ignition orange + radio harness
Radio Illumination red/orange + radio harness
Factory Amp Turn-on pink + radio harness
Power Antenna white + radio harness
LF Speaker +/- black - yellow +,- radio harness or amp under driv seat
RF Speaker +/- red - blue +,- radio harness or amp under driv seat
LR Speaker +/- orange - green +,- radio harness or amp under driv seat
RR Speaker +/- white - brown +,- radio harness or amp under driv seat
Mar 27, 2010 | Car Audio & Video
I need a stereo wiring diagram for a 1991 ford escort four door sedan
Good luck and hope this helps, keep me posted if you need more information.
Radio 12v dk. blue/red + radio harness Radio Ground black - radio harness Radio Ignition dk. blue/black + radio harness Radio Illumination dk. green (dimmer) + radio harness Factory Amp Turn-on red/black + radio harness Power Antenna N/A LF Speaker +/- purple - dk. blue/orange +,- radio harness or amp near radio RF Speaker +/- dk. blue/white - white +,- radio harness or amp near radio LR Speaker +/- white/dk. blue - red/dk. blue +,- radio harness or amp near radio RR Speaker +/- white/dk. green - dk. blue +,- radio harness or amp near radioclear.gif
Jan 15, 2010 | 1991 Ford Escort
Where can i find a wiring diagram for toyota rav 4 2003?
RADIO 12V|blue/yellow |+ |radio |
| RADIO GROUND|brown |- |radio |
| RADIO SWITCH|gray |+ |radio |
| RADIO ILLUMINATE|green |+ |radio |
| LF SPEAKER|pink - purple | |radio |
| RF SPEAKER|lt. green - blue | |radio |
| LR SPEAKER|black - yellow | |radio |
| RR SPEAKER|red - white | |radio |
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 25, 2009 | Buck Toyota Rav4 2003 Stereo/radio...
I am hard wiring a radio into a 2003 hyundai sonata and i need to know what each wiring coming out of the car does
Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
Jul 15, 2009 | Car Audio & Video
Como obtengo un diagrama de conexiones del radio de la trailblazer 2006
RADIO 12V|orange |+ |radio |
| RADIO GROUND|black/white |- |radio |
| RADIO SWITCH| | | |
| RADIO ILLUMINATE|brown/white (dimmer)|+ |radio |
| POWER ANTENNA|gray |+ |radio |
| LF SPEAKER|tan - gray | |radio |
| RF SPEAKER|lt. green - green | |radio |
| LR SPEAKER|brown - yellow | |radio |
| RR SPEAKER|blue - lt. blue | |radio | Notes:
Van necesitar correr un cable para acessorio
Jul 11, 2009 | 2006 Chevrolet Trailblazer
Wiring diagram for the stereo
Radio 12v orange + radio harness Radio Ground black - radio harness Radio Ignition dark green + radio harness Radio Illumination brown + radio harness Factory Amp Turn-on orange + radio harness Notes: The amplifier is behind the glove box. Power Antenna N/A LF Speaker +/- tan - gray +,- radio harness RF Speaker +/- lt. green - dk. green +,- radio harness LR Speaker +/- brown - yellow +,- radio harness RR Speaker +/- dk. blue - lt. blue +,- radio harness HOPE THIS HELPS.
Aug 07, 2008 | Chevrolet Tahoe Cars & Trucks
 Grubhead
Grubhead
