Question about Kyocera Office Equipment & Supplies
FS1920 says "processing"
The Kyocera printer FS1920 says "processing" but never prints. Happens from the onboard menu and from the computer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kyocera Master
  • 884 Answers
Hi
It would appear that there is a problem during translation from the document to the printer. The following procedure may help:-
Try turning off the printer, on the computer clear the pending jobs for the printer until none are left. Turn off the computer and wait for 30 seconds. Turn on the computer and wait until it is fully booted. Again check the printer queue is empty. If it is not clear it by deleting the pending documents again and then reboot again. Repeat if and as necessary until the printer queue is and remains empty. Restart the printer and again wait until it is fully booted. Hopefully this will have cleared the error and you can start printing again. Start with something small and simple so that you are not putting a significant processing load on either machine.
I give below a link from which the manuals for this machine may be downloaded. If the above procedure doesn't work there may be something in the manuals that will.
Download Center
Good Luck
Posted on Nov 09, 2014
  • Patsy Hamilton
    Patsy Hamilton Nov 16, 2014
    This answer was very helpful. I'm so glad to have my Kyocera printer back. It's a workhorse. Thanks for the help.
SOURCE: change cartridge's instrutions for kyocera FS1920
Hi
To replace the toner in the Kyo fs 1920 you have to open the top cover, under you will se a small blue clip in the upper right section, you have to pull that to the right, it will release the the toner box what is the big black pice under the to cover. After removing the toner box place the new toner box in the right direction (if you are in front of the printer, you can read the text on the top of it) and push it gently down. You should hear a click and you can see the movement of the light blue clip. Ps.: don't forget to remove the orange pieces from the new toner box befor installing.
Posted on Oct 15, 2008
  • 43 Answers
SOURCE: kyocera fs1920 problem
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Posted on Dec 16, 2008
  • 523 Answers
SOURCE: Printer not printing - showing 'processing' but nothing happening
Reinstall the driver again, if it doesnot work, you have to update the firm ware of the machine, you can find this on kyocera website.
Posted on Mar 01, 2009
  • 88 Answers
SOURCE: Printer keeps processing - nothing happens - no print
Not really sure about Mac, but if this happens on a PC, I would first uninstall the printer (software-wise) then download the latest drivers and install.
Posted on May 27, 2009
  • 46 Answers
SOURCE: Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
Posted on Jun 11, 2009
Fs 1920 service 1200
your du-61 duplex unit is faulty or not installed correctly check the harness and gates if all this is ok its the engine pwb has failed
Feb 17, 2014 | Kyocera Mita Office Equipment & Supplies
How to add fs-1920 printer to HP300 pc
depending on u're OS you can use a wizard from printer and faxes for win xp and win7 or using installation cd. connect the usb cable or parralel cable switch on the printer the found new hardware appears continue with installation select u're model kyocera->fs1920 or nearest model-> then follow instructions
Jun 22, 2012 | Kyocera Mita FS-1920 Laser Printer
We have an Kyocera FS-1118MFP KX and it is printing out everything in really small type. How can I fix this problem?
1. On the computer:
- go on Print Preview, if document looks normal go to step 2.
- make sure you are writing in a font of at least size 10
- make sure you don't have ticked "Shrink to fit", but adjust to 100%.
- size of the paper is printing preferences is set up to A4 or Letter, depending on your region
- there is a known issue with Outlook printing in small font, you need a hotfix for that
2. On the printer:
- You have to go into the menu of the printer and see if there is an option for the font, if there is increase the size of it
- In the menu, make sure the paper size is correct
- None of these worked, you may want to reinstall the drivers of the printer
- If that does not work, you may have to put a new firmware on the printer. You can download drivers and firmware from Kyocera website
Nov 30, 2010 | Kyocera FS-1118 Printer
WordPerfect Printing Problems with HP Photosmart C5550
It's not the program, but the actual printer.
You see, when you print with an inkjet, the information is fed line-by-line through the CPU for processing. The larger the document in size, the longer it takes.
Switch to a color laser printer. They're about 150 dollars. It has an onboard memory and a CPU for processing. Speed wise is about 500% faster. Since it has it's own onboard computer basically, it doesn't need to interrupt the CPU to compute the information and send it to the printer. Laser printers are also known as page printers because they can store pages of information in their own memory.
Aug 09, 2009 | Office Equipment & Supplies
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
Nov 25, 2008 | Kyocera Mita KYOCERA/MITA - FS-2000D Mono...
Kyocera fs1920 problem
Nov 08, 2008 | Kyocera Mita FS-1920 Laser Printer
Change cartridge's instrutions for kyocera FS1920
Hi
Aug 18, 2008 | Kyocera Mita FS-1920 Laser Printer
Will not print
Go to the Start menu and select "printers & Faxes". Ensure that the FS2000 is set as your default printer (right click on icon and select as default). If you still cannot print you will need to reinstall the printer drivers from disk or download from the Kyocera website.
Aug 07, 2008 | Kyocera FS-2000D Laser Printer
74 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
