Do you know where I could find a manual for my Command Start then I could reprogram it myself. It is a CS555
I have replaced the battery. If I turn the switch on in the vehicle things work, I can start the car and unlock it but it will start in the middle of the night, even if the temperature is not low.
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Try the site linked here. Hopes it will help you.
Electrohelponline
Posted on Nov 17, 2014
2 Suggested Answers
  • 6 Answers
SOURCE: Valet 473T remote
It sounds like the system needs tach sensor reprogramming. The remote start system may have a tachometer sensing mode where the system "knows" that the car is running and to stop cranking the starter when when the engine is running. Generally when the vehicles battery is disconnected the system "forgets" the setting of the tachometer at idle which is programmed at the time if installation. Take it to a remote start installation store for this or get a hold of a maual for your system and shouldnt be too dificult to program.
Posted on Jul 10, 2008
I have 2 remotes for my 2007 Honda CRV, 2 that unlocks the doors and 2 with a button you push to start the vehicle. One of the starter units won't work. I took it apart to see what kind of battery it...
Typically a car remote does not have to be reprogrammed to replace the battery. Check the car's owners manual to verify the battery is a CR1229. I don't know of any 1229 number but I do know a CR1220. Verify the number and you can buy them at just about any store...from Walmart on.
Semper Fi,
Z
Aug 08, 2017 | Prestige Remote Start
My panasonic dvd recorder / remote control is not working On pressing button on remote I get dvd2 on recorder screen but no other response. I have tried reset without effect
Try reprogramming the remote itself; i.e. point remote at unit (while on), press and hold the [2] and [ENTER/OK] buttons together for 5 - 10 seconds, then release. The remote's command should now match that of the unit (DVD 2) (the unit should now recognise the remote). Failing that, remove batteries from remote, replace with new ones (just in case) and repeat the above suggestion. You should not need to reset the main unit.
Whenever the batteries are replaced in Panasonic remotes, in some cases, a remote command reprogram is often required to ensure that the remote commands the unit fully and correctly. You may find this procedure outlined in your instruction manual. Hope this helps a tad.
Aug 14, 2011 | Televison & Video
Remote start not working
it does have to be reprogram to the key look for the manual in the car or go to there site and request manual for that model and then look up reprogrm with key in ignition reprograming.
Feb 03, 2010 | Car APS687A Remote Start and Keyless Entry...
2000 pont. g/p int. start/stall. replaced theft module twice,comp., ig.swicht,keys,P1629
THIS SYSTEM REQUIRES A REPROGRAMMING PROCEDURE AFTER COMPONENT REPLACEMENT. THERE IS A MANUAL RELEARN YOU CAN TRY BEFORE HAVING TO TAKE IT TO THE DEALER FOR REPROGRAMMING. THE RELEARN IS AS FOLLOWS: DIS-CONNECT BATTERY FOR 5 MINUTES. RECONNECT BATTERY,TURN KEY ON BUT DO NOT START!! WAIT APPROX. 20 MINUTES OR WAIT UNTIL THEFT LIGHT GOES OFF. TURN KEY TO OFF FOR 5 SECONDS THEN ATTEMPT TO START. IF IT STILL WONT START LEAVE KEY IN RUN POSITION FOR AN ADDITIONAL 20 MINUTES OR UNTIL THEFT LIGHT GOES OUT THEN ATTEMPT START AGAIN. MAKE SURE BATTERY IS FULLY CHARGED!!! IF THIS DOESNT WORK IT WILL HAVE TO GO TO DEALERSHIP FOR REPROGRAMMING WITH TECH 2 SCANNER.
Aug 14, 2009 | 2000 Pontiac Grand Prix
Command start will not work
the remote probably needs to be reprogrammed.........if you could give manufacturer name and model number i could find some instructions for you.....or if you have it refer to your owners manual for the starter
hope this helps!
Jan 05, 2009 | 1994 Chevrolet K1500
Keyless entry remote
TRY PUTTING IT IN IGNITION TURN IT SO DASH LIGHTS UP THEN PRESS THE FOB WORKED ON MY CAR BUT MINE WAS A ASTRA
Oct 23, 2008 | 1997 Buick Century
Televison & Video Logo
Top Televison & Video Experts
