Sorry it's a 32 ld550 that comes on for about 10 seconds and then shuts off. Is there a reset button that would help me
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 10, 2014
Smp-n200 shuts off after 10 seconds. reset button not effective. 6 months new
Simple fix when this happened to me... I replaced the battery on the remote controller and the media player started working and didn't shut off again. Apparently, when it first comes on, it does a self test. if it receives no input from the remote, it shuts itself off. Hope this helps... BTW, the battery for the remote is any 2030 battery. Just replace it and try it. let me know if it worked...
Dave
Jan 28, 2013 | Sony SMP-N200 Streaming Media Player with...
My iphone 3G just shut off on its own & it will not come back on when I try to trun it back on. Does anyone know more or less what I can do to fix that?
Is it completely charged? Plug it in and charge it overnight.
If it is charged, these steps may help:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 16, 2010 | Apple iPhone 3G
I have a Mitsubishi VS-55707 and I have a couple of problems. first it takes 5-10 minutes to warm up (scrambled picture) after that it works fine, but its getting longer to warm up. Second every once in...
i had the same problem. im sorry to say that you are out of luck and you tv is on the way out. i had the same problem and spend $100's of dollars to have people come and try and fix it to no luck. sorry
May 23, 2010 | Mitsubishi VS-55707 TV
Acer ZG5 shuts down in a few seconds
time to set up a rma and ship it to service center sorry nothing to do but have them repair it now.
Jan 31, 2010 | Acer Aspire One PC Notebook
The off and on button is on but the screen says it is shutting down, but it will not shut down or let me go on to another stage. I have pluggged and unplugged it. It still comes back to shutting down mode
Hi
Try resetting the printer, follow below steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
Regards,
Rizwan
Jan 27, 2010 | HP Officejet J5780 All-In-One InkJet...
After Reset, router will not accept admin signon. "admin" can be the userid, or the password, or both -- none of these combinations is accepted.
Are you sure that you held the "Reset" button in long enough?
The manual says to press it for 5 seconds - try 10 seconds.
Also (it is a little bit tricky to do but it helps sometimes):
  1. Press the "Reset" button.
  2. Unplug the power for about 10 seconds while holding the "Reset" Button pressed down.
  3. Plug the power back in and hold the Reset button for another 5 seconds.
  4. Let the router restart and use the standard credentials (username empty, password "admin").
If that does not help, come back here and leave a comment - I'm happy to help.
Nov 28, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Fix my tv
unplug it for 5 to 10 minutes
make sure the reset button isnt pushed in or sticking as the reset button might be the problem
plug it back in & turn it back on
hope that fixes it for you
Sep 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No power
turn power off hold down power button for 10 seconds then wait 30 seconds to turn power back on. see if that helps
Aug 29, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
