Question about Poulan Pro 25CC 2Cycle Gas Blower
How do i attach the bag for the vac
I have lost the Manual so i need a little help
  • Poulan Master
  • 14,417 Answers
Here's a link. User Manuals
Posted on Nov 10, 2014
I have a Craftsman electric Blower/Vac with no operatorers/instruction manual. I would have liked to use the vac option but have no idea how to couple the pipes together and attach the bag for this...
For maybe getting a manual, go to:
http://www.manualsonline.com/
You will find that you open the bottom vent, put a large suction tube in the recess and remove the blower tube and attatch a collection bag on the housing that held the blower tube. That's all there is to it.
Aug 13, 2010 | Craftsman 4 Cycle Blower/Vac
Hoover windtunnel dirt finder light stays red. We've cleaned the elbow the roller the hose and have a clean bag. The vacuum is new only had it for 3 months.
I'm not sure about a 3 month old vac, I'd probably go the warranty route. However, for the older vacs thy start getting false positives. The sensor is simply a microphone hooked to a computer chip detecting sounds of dirt entering the bag.
To rig it to start working, you'll need to remove the tool accessory tray and elbow that enters the back of the vac, and attached to the bag. This will reveal the microphone at the elbow, and wire that runs into the bottom area of the vac. When on, a large amount of air comes from the bottom screw and area where the wires enter. My fix was to clean up the microphone contact points a little bit with a screwdriver, and then leave the vac running while putting in dampering in the hole at the bottom, and around the back of the elbow. Cotton balls and electrical tape at the bottom hole, and napkins around the outside of the elbow (wedged between the back of the vac assembly and elbow did the trick). The schematic for the vac is here: http<colon>//www<dot>vacsrus<dot>com/CartGenie/pg_U6485900<dot>asp
Look for micrphone.
May 12, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Need to know how to attach vac bag
The bag should fasten to the blower where the blowing tube comes out. (blowing tube is removed to install the bag, and a pick up tube is installed on the 'screen door') It should have a tightening strap or velcro to hold it in place.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 09, 2009 | RTO Weed Eater Electric Barracuda 2595...
I'm trying to set up my vac as a blower! Help
Take the cloth bag and mini-imptor ofthe f. Then take you suction hose "that you would normaly put on the front" attach it to the side where you took the emptor off. It should lock on with a simple twist and lock. Now you have a blower. However you will need the intake guard assy. on the front of your kirby. Refer to the manual for that attachment. Good luck.
Nov 08, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
May 09, 2009 | Shop Vac Vacuums
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
Craftsman 4 cycle leaf blower/vac #71-79731
Solution offered by MrFixIt Jerr solved my problem. Thanks for the help. This is a great service. Mr. G.
Feb 08, 2009 | Craftsman 4 Cycle Blower/Vac
Utlimate g vacuum appholstery attachment
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier.
Since you lost your manual, you may want another. They are available in DVD, VHS or book format. Check it out!
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
Marci
Jun 02, 2008 | Kirby Ultimate G Bagged Upright Vacuum
The blower attachment
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. Since you lost your manual, you may need belt change instructions as well. Here is a link to my online guide that will show you how....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Marci
Oct 25, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
May 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Poulan Pro 25CC 2Cycle Gas Blower Logo
55 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
