Question about Kocaso M752 Black WiFi 7" Android Tablet PC w/ 4GB Storage & 512MB RAM
I recently ask a question how how to do a reset as i am stuck with android on the screen, i tried ur suggestion on power button and sound down button, nothing changed , do u have another suggestion to get me back to normal.
  • 110 Answers
I had this similar tablet...it quit on me after 2 months. I called the company and they replaced it with a M9200 which would not turn on after 1 month. I found the factory reset button on the back under a small sticker. Plug it into the charger and gently push a sharp toothpick or other sharp non metallic object inthe the small hole until you get resistance. Then gently push 'till you feel a tiny click...this should reset the tablet. Mine crapped out because it is a junk company. There are more complaints on this company than any other I have ever seen. I wised up and bought Google Nexus 7...best 7" tablet made.
Posted on Feb 11, 2015
How to reset android Ls660Zv6
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off.
  • Hold down on the Volume + button and hold down the Power button at the same time.
  • As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
  • At this point you will see a screen with boot options.
  • Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
  • On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
  • At this point it will be going through the wiping and resetting process.
  • When it's done you will see the first screen you came to when you first started the setup.
  • Just tap the Power button to select Reboot System Now.
Stuck in Android System Recovery Tips to Fix Recover Lost Data
Apr 27, 2016 | Tablets & eReaders
Stuck on home screen just shows the android writing across the screen, how do I fix?
u don't mention the make check to c if its got a reset button if not look for a little hole with reset on it stick a paper clip in it ??? if there is no reset try holding the power button down for 30 seconds or more if this wont work try holding down power button & the volume button both at the same time it might reset if not it could b faulty good luck
Jul 26, 2015 | Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
Why is my maxtouuch android tablet stuck on start up screen
has the tablet got a reset button hole if not try this ..try holding the power button down for about 30 seconds to c if it will reset if this does nothing hold down power button and volume button at the same time for 30 sec or more. good luck
Jul 11, 2014 | Tablets & eReaders
Tablet trio android
Had several do this lately
You got to do a hard reset but it might wipe out any apps or other data too. If you can hook it up to ur USB connection and backup ur data first. Try doing the soft reset first..hold the power and sound down keys until it reboots.. if this fails u always got the hard reset..the little hole in back by the card reader..use a toothpick and unplug it from power and computer first..CAUTION u can loose ur settings and be force to update and reinstall any apps if it is set for backup wipe data..
youtube has some good vids on diff resets but if you can access the menu then u got nothing to loose.
Let me know if u get stuck
Chad man
Apr 20, 2013 | Mach Speed Trio DROID-7C Android 2.3...
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Kurio kids tablet won't start up
I fixed mine like this, unfortunately you will lose all your data on the system.
1) Whilst holding down the Power button, hold down the Volume+ button for about 10 seconds and let go.
The table should boot into a screen with an Android with a open chest and a danger sign on top.
2) Press the Volume+ button, and the recovery menu will appear.
3) Press the Volume- button, to move to "Wipe data/Factory Reset" and press the Power button to select that option.
4) Press the Volume- button to move to "yes" and press the Power button to accept.
Now the system will wipe the data and factory reset the tablet.
5) When it returns to the menu, make sure it is on "Reboot system now" and then press the Power button.
The tablet will now reboot and should load.
Aug 25, 2012 | Techno Source Kurio Kids Tablet With...
Kocaso M752 Black WiFi 7" Android Tablet PC w/ 4GB Storage & 512MB RAM Logo
97 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
