Question about Rival VS107 Seal A Meal Vacuum Food Sealer
I have a VS106 and I'velost the drip pan an now it's not working.My question is , is that why it's Not working????
Lost the drip pan and tried to use the sealer and it will NOT work. No sealing no sucking of course
  • 59 Answers
Not sure of the product but some items like this will have some type of a sensor to see if the pan is in place before it will work.
Posted on Nov 09, 2014
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Where can I find a drip pan to put under my AC unit?
Did you look at the homedpo thay shod have one
Aug 14, 2012 | Heating & Cooling
Condensation water does not leave pan when it gets full you can hear the water being picked up and thrown around in the unit. There is no water flowing either inside or outside unit.
What you hear is an indication that the drain hole in the drip pan is clogged. Check the outside of the bottom of the drip pan. The hole may be hard to locate, as the clog can blend in with the drain hole. It may take patience & persistence to find it. A pipe cleaner works well to clear the hole. And while you're at it, check the downward tilt of the rear of the unit. The general rule of thumb is 1/4" to 1/2" downward tilt. This will help to water to flow to the rear of the drip pan and out thru the drain hole.
Hope this helps you and thanks for choosing FixYa.
Sep 05, 2011 | Electrolux Heating & Cooling
Loud noise coming from fan , alot of water coming inside instead of outside
The problem you're having is caused by the drip pan's drain being clogged near the rear of the unit and/or there is not enough downward tilt on the rear of the unit. 1/4" to 1/2 is the general rule of thumb for rear downward tilt. This allows the water to flow to the rear of the drain pan and out thru the drain hole. Instead of building up and overflowing the front of the drip pan. Be sure to turn the unit OFF & unplug it, before attempting to remedy the problem.
Correcting those to issues should solve the problem.
I hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | LG Heating & Cooling
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
Unit is leaking water into the house.
The problem you're having can be caused by 2 things. The drain hole in the drip pan is clogged and/or the rear of the unit is not tilted down enough, so the water can flow to the drain hole, near the rear of the drip pan. The general rule of thumb for the downward tilt is 1/4" to 1/2".
Finding the drain hole can be a challenge at times, as the clog can blend in with the hole. Patience & persistence are what's need in locating it. A piper cleaner works well to clear the hole.
Aug 07, 2011 | Friedrich WallMaster WS12A10E Air...
Water leaking inside home and window seal
Aug 07, 2011 | Kenmore Single Room Air Conditioner
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
How to remove and clean grease pan on Vermont Castings model 608SB
The drip tray is accessible from the rear of the Grill. It is necessary to lift up the pan slightly while pulling it out. Or depending on how old your VC grill is, it may be located on the left end of the grill (you should see a small handle). In which case you pull it out and was you reach the end of the drip tray, lift it up slightly to remove it.
TIP: To make clean up of the drip tray easier. Spread a thin layer of Speedy Dry (It's what NASCAR & garages use to soak up oil) on the bottom of the drip pan or tray. You can purchase a bag of it, at any auto parts store, When it comes time to clean the drip tray or pan. Just remove the tray or pan and dump the used Speedy Dry in the garbage. Then, spread a thin layer in it again. Actually, because the Speedy Dry absorbs so well, you'll find that you'll only have to dump the tray or pan occasionally.
Hope this helped you and Happy Grilling!!
Jun 23, 2011 | Grilling
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Rival VS107 Seal A Meal Vacuum Food Sealer Logo
212 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
