Question about Fitbit Zip Wireless Activity Tracker, Lime, 1 ea
How do I reset the time on my Fitbit Zip - Fitbit Zip Wireless Activity Tracker, Lime, 1 ea
How do I reset the time on my Fitbit watch
Here is the way you can reset time on your Fitbit without Reset Fitbit Charge HR -
  • Open the Fitbit app on your phone
  • Then Go to the Advanced Settings
  • Now turn off automatic Time Zone
  • Press Select Time Zone
  • Choose the time zone according to your country
  • Synchronize your Fitbit to your smartphone
The Guide Of Reset Fitbit Charge HR Complete Guide
Aug 08, 2017 | Exercise & Fitness
Need to reset time on my fitbit
you have to resync it with the dongle plugged into a computer.
was it a fitbit zip ? if yes then
you will have to take battery out and then put back in. for about two minutes you will be able to hook it up to a pc via the dongle and fit bit software .As it goes into pairing mode . for about two minutes from having battery inserted.
Jul 28, 2016 | Exercise & Fitness
How do I charge my fitbit zip battery?
You cannot charge the Fitbit Zip as it uses a coin battery.
The Fitbit Zip runs on a replaceable 3V coin battery, CR2025.
It can be found wherever batteries are sold.
You can change the battery while not wearing hence counting steps. Fitbit Zip Battery Change
Mar 15, 2016 | Fitbit Zip Wireless Fitness Tracker
Will not keep time or my steps
Good question, are we referring to the Fitbit Zip?
If so I would remove the battery for 10 seconds then replace, this will restart the unit.
Oct 19, 2015 | Fitbit Zip Wireless Activity Tracker,...
How do I set the time on my fitbit?
After you charge it back up, you will need to sync your Fitbit, this Sync will update the steps
May 20, 2015 | Fitbit Zip Wireless Activity Tracker,...
How do I set the time on a Fitbit Zip?
  • The current time can be viewed on the Fitbit Ultra's display.
  • The time can be displayed in 12 hour format (e.g., 5:00 PM) or 24 hour format (e.g., 17:00). You can adjust this setting on the Edit Profile page, which affects the displayed time on the Fitbit Ultra, graphs, and input fields across the site.
  • The clock display can be disabled from the Fitbit Ultra setup screen.
Feb 15, 2015 | Fitbit Zip Wireless Activity Tracker...
How do I reset the time on my ftbit
  • Clock/Time (Fitbit Ultra only)
Nov 09, 2014 | Fitbit Zip Wireless Fitness Tracker
How to set time on fitbit
But now you should have figured out out
https://help.fitbit.com/customer/portal/articles/1031792-the-time-is-incorrect-on-my-tracker-s-display
Jul 22, 2014 | Fitbit Zip Wireless Activity Tracker,...
Fitbit Zip Wireless Activity Tracker, Lime, 1 ea Logo
88 people viewed this question
Top Fitbit Exercise & Fitness Experts
Ravi
ray gallant
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
