Question about Kitchen Ranges
My oven on my frigadaire modle no. fgf366bc will not light it glows red but will not ignight and i can also smell gas
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
The oven igniter is going bad. Replace the igniter (the glowing part) this will fix you right up.
Posted on Nov 22, 2014
SOURCE: Maytag MGR4410ADW
You probably need to replace the the ignitor. Even though it glows red does not mean that it is working propery. If it does not draw at least 3.5 amps the gas valve will not open. This can be check with a amp meter.
Posted on Nov 18, 2007
FreeTech
  • 426 Answers
SOURCE: JGBC20BEHCT OVEN PROBLEM
can you hear a hissing sound? if your element isnt working it will need to be replaced as a saftey measure most ovens will not "pass gass" without a working element to prevent explosions, try wiggling the connnections to the element and make sure everything is tight and see if it will heat
Posted on Jun 05, 2008
tzweeb
  • 318 Answers
SOURCE: Oven will not light but smell gas
i think you probably have a weak ignitor. does the ignitor glow orange?
if it does, or i should say when it does, just tap lightly on the gas valve and see if that causes the gas to flow into the burner and then light.
you can use the handle of a screwdriver to tap with and it wont need to much force.
if this does work, then just replace the ignitor. when they get weak they will glow, but wont draw enough current thru the gas valve to allow it to open. your valve does get voltage but it opens when enough current draw opens the bi-metal portion of the valve to allow gas to flow.
Posted on Jan 15, 2009
jsrock516
  • 5911 Answers
SOURCE: Burners work,Broiler works but oven does not preheat
If everything works on your range, but the oven, the most likely culprit is the igniter for the BAKE manifold. What is confusing me, though is the statement in your question where you say the "oven will light up, but never get hot". Yet, you say the oven does not ignite. Can you clarify this? In some ovens the BAKE and BROIL manifolds BOTH light when preheating, to reduce the warm up time. Once the desired temperature is reached the manifold not in use, will shut off.
In any case, on a gas range, the burners for the BAKE and BROIL manifolds use an electric glow bar type igniter. There's a separate igniter for EACH burner. When you make a bake or broil selection on your oven control, the respective igniter begins to glow. After the igniter reaches a certain current potential, the gas safety valve is opened, gas flows to the manifold, and voila! You have ignition. It can take as long as 90 seconds for the burner to ignite. What can happen over time, is the igniter becomes weak or fails. If the igniter becomes weak, it will still glow, but it never reaches the desired current potential to open the gas safety valve. The result: you end up with an igniter glowing with no ignition. And, if you're like me, you're left scratching your head wondering why the thing isn't working when it "looks" like it is. You can easily tell if the igniter is working by opening your oven door and selecting bake. Watch the oven pan in the bottom of the oven. You should see an orange glow coming from under it. It here's no glow at all, the igniter has probably failed. If there IS a glow, a current reading will tell if it's within tolerance. The following link explains more on these igniters and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter is a common fail item as it gets used more frequently than the broil function. On your range both igniters are interchangeable. You can purchase replacements on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. The part number is WB2X9154. Shop all three sites for the best price.
I hope this helps you. If my assessment of your symptoms is wrong, or if you need further assistance, please let me know.
Posted on Jan 16, 2009
  • 42 Answers
SOURCE: OVEN WILL NOT (GAS) LITE
With the assumption you have a gas range with electric ignition and is fully powered (plugged in); the possible problem may be the "Electric ignitor/Glow bar".
When turning on the oven, do you see a redish (good) or yellowish (not good; replace) glow emitting from the very bottom or the oven/broil area?
There are typically 2 types of electric glow bar ignitors; Round and Square. Ignitors are actually fairly easy to replace, removing 2 mounting screws and cutting/splicing 2 seperate wires together. Is your ignitor "round" (circular - like size of finger ) or "square" (rectangular - like snickers candy bar)
If your ignitor is not coming on at all; this can be a couple things;
Defective Ignitor - Gone completely Bad - Out (Assuming your have full power 110v to ignitor)
Defective Gas Valve - Assist in passing 110V to Ignitor
Defective Control Board / Thermostat: Assist in passing 110V to Ignitor
FYI - As a safety measure, the ignitor needs to "come on and appear solid red" to properly pass power to gas valve; thus opening and allowing gas to pass through the burners and combust.
Posted on Jan 27, 2009
My oven won't light.
Does it glow real bright like orange or just red. Because if it's not real bright orange, the ignighter could be bad. The oven will not light if the ignighter is not hot enough.
Sep 22, 2014 | DCS RGT-366-L
Oven does not light
first check the igniter to see the color of it. if it is orange you need to replace it because it is too weak to ignite. it needs to glow white hot. second, the burning smell could be from the coil, check the coils as well near the gas valve.
Nov 08, 2009 | Ovens
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Oct 11, 2009 | Viking Ovens
Oven or broiler won't operate (no gas noise/smell or ignition noise) after power failure. over worked minutes before power failure is ther a factory reset button or something like that?
check one area at a time try the broiler first see if the glow plug or ignighter is glowing red hot the glow plugs have to get so hot before the gas valve will open, it is not usual for both to go at the same time, as for fuses or resets i have never seen these on any stoves, if you find that one works and the other does the glow plug is bad if not the gas valve may have went bad
Aug 22, 2009 | Whirlpool Kitchen Ranges
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Electric ignighter does not come on in the oven at all
In most cases it is the ignitor itself. Eledtricity goes thru the ignitor and as it gets hot it allows more electricity thru to the gas coils, allowing them to open and let the gas go thru. The ignitors do get weak and will glow but that is all. Not enough electricity can get to the gas valve solenoids and let gas thru. Find a local parts dealer and give them your make and model # to order the part.
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
Oven Not Working
see if your broiler works if it does replace the bootom ignighter even though it glowes does not mean its working right it has to pull a ceartain amount of amps for the safty valve to open if the broiler doesnt light then the safty valve needs replacing and reply for futher info
Aug 16, 2008 | Whirlpool GS460 Gas Kitchen Range
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Oct 29, 2007 | Frigidaire FGF376 Gas Kitchen Range
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
