Question about Shure MX418/S Microflex 18" Gooseneck Condenser Microphone MX418 S
I also, have a shure microflex 150 condenser mic. We use it at the pulpit of our church for 2 years at least. The mic went dead. I replaced the 185 cartioide cartridge but the mic is still dead. D
I also, have a shure microflex 150 condenser mic. We use it at the pulpit of our church for 2 years at least. The mic went dead. I replaced the 185 cartioide cartridge but the mic is still dead. Does the 150 ohm condenser cartriage go bad?
  • Shure Master
  • 3,382 Answers
It sounds like somebody turned off the phanton power on the mixer. Bring the main volume all the way down and turn it on, that should resolve the problem.
Posted on Dec 05, 2014
Why.....my two brand new Shure pg27's are BOTH dead...can I be THAT unlucky?? Or just dumb. I'd RATHER be dumb, hopefully I'm doing something wrong....but I'm trying to record with them in my Zoom R16. No...
The Shure PG27's are condenser mics. They need power. Since the mics don't have a battery compartment then the power has to come from the mixing console. Have you switched on 48V Phantom power?
Aug 11, 2014 | Shure PG27USB USB Condenser Microphone
How to modify Shure wWL-185 to use as wired mic MX-185
To convert a WL185 to the MX185, you need the Shure RK100PK preamp module.
May 17, 2011 | Shure MX185 Professional Microphone
We are using a Shure PG58 wireless mic. It worked very well for about 1 year and then it would work on/off. Even when we put new batteries in the mic it still just goes dead. Any suggestions?
Unfortunately, there are many, many things that can cause a unit to be non-functional. Try calling Shure to get it repaired, or call Delta Audio at 773-764-3634. Delta Audio also repairs older Shure equipment.
Jan 17, 2011 | Shure UT2 / 58 / PG58 Professional...
Using the Shure AMS22 with a 7V stable power source into a reg
These are a condenser mic which requires a very high impedance FET amplifier right near the condenser part. Most wired condenser mics use Phantom powering of the internal amplifier AND balanced line driver.
I would NOT recommend you try modify this unit for wired operation.
Incidently Phantom powering is usually at least 9 volts.
Dec 23, 2009 | Shure AMS22 Professional Microphone
Shure microphone MX418 microflex condenser 150
The mic requires phantom power from the mixer. Contact the mixer manufacturer to find out how to turn on phantom power.
Feb 19, 2009 | Shure MX418 Microphone
I have a shure microflex mic condencer 150 the led does not work and the mic is dead. Does the mic need a battery if so how do you instal it.
Try using a mixing console with phantom power ( + 48 ). A condenser mic needs 48 volts to operate. The led should light when the XLR microphone cable is connected to a console with phantom power.
Feb 19, 2009 | Shure (LX287CC) Professional Microphone
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
Shure MX418/S Microflex 18" Gooseneck Condenser Microphone MX418 S Logo
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
