Question about Thermador Dishwashers
<!-- from fixya rte -->E-15 ? Thermador dishwaher, it doesn't spot - Thermador Dishwashers
My dishwaher is not cleanng anything
Huh? No washy or water spots you are complaining about??
Jun 06, 2015 | Dishwashers
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
My thermador double ovens is not working the control board is not on. it is dead. It is about 8or 9 yrs old.
SUSAN!!!!!!!!! This is EXACTLY what happened to mine! The control panel doesn't show the time or temp or anything! I am going to watch for an answer!!!
Nov 18, 2011 | Thermador Ovens
What type of tool is used to take the nut off of a burnner on a thermador star burner
hello,that brass nut under the burner cap that holds the burner base is removed by a 13/16" socket,if it doesn't come off its "baked on" due to the heat,in that case it must be cut off or drilled out using a dremel rotaty tool with a cutoff wheel or i have found them to be easier to remove by drilling out using a tapered unibit drill bit,in either case the burner base to will need to be replaced since it will be damaged by cutting/drilling it
Good luck,
Gene
Aug 08, 2011 | Thermador PGR366 Gas Kitchen Range
Metal propeller still turns but plastic three arm proellers is broken therefore Glass tray does not revolve
you can order a new turn stub from thermador at there web site they cost around $ 15 and just pull out and push back in
Feb 15, 2011 | Thermador MBBS Microwave Oven
There is a brown film all over inside of dishwasher. I have to put it on power scrub for my dishes to get clean.
I had a similar problem with my Whirlpool dishwaher, and it turned out that my water softener was not working. Once that was resolved, I found that I have to use a rinsing agent in the dishwaher to completely eliminate spots on the cleaned dishes.
Dec 03, 2010 | Dishwashers
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Dishwaher
Generally, you need only hot water. It is advisable that the drain line be a little lower than used by a washer. Drains usually go into a modified portion of the sink's j bend in the drain. This sits at about 18 inches off the floor. You should fuse your electric line for 20 amps at 120 volts or 15 amps at 240, depending on your location. North American units are at 120.
Mar 15, 2008 | Dishwashers
Dishwashers Logo
Top Thermador Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
ray gallant
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
