What does [ time shift speed ] mean? And in Pvr it always displays c. Drive. It it won't allow selection of usb. It displays [ usb 0]
  • 59 Answers
Time shift speed on a PVR usually relates to the speed of the recording. It depends on how fast you want to fill up your drive. The faster the drive fills up usually gives you a better quality then a slower recording speed.
As far as the USB goes. "USB 0" is usually the first USB connection. Some electronic devices and electronics in general start counting at 0 not 1. Just plug it in the USB port and select USB 0. It should work for you.
Posted on Nov 09, 2014
I have a 2009 GMC Acadia. What should the ERS mode be in on a normal basis?
Driver Shift Control (DSC) or Electronic Range Selection (ERS): This position (M-Manual / L-Low) allows the driver to utilize the DSC/ERS system. When the shift selector lever is moved to this position, the driver may select upshifts or downshifts by using the paddle switches located on the steering wheel/shifter. An upshift is requested by pushing either + button. Refer to the vehicle owner's manual for more specific DSC/ERS information.
Driver Shift Control (DSC)/Electronic Range Selection (ERS)
Refer to the owner's manual for specific instructions on DSC. The TCM will override shift commands when maximum engine speed is achieved and will protect from any downshift which may cause excessive engine RPMs.
Electronic Range Select (ERS) Mode
ERS mode allows you to choose the top-gear limit of the transmission and the vehicle's speed while driving down hill or towing a trailer. The vehicle has an electronic shift position indicator within the instrument panel cluster. When using the ERS Mode a number will display next to the L, indicating the current gear that has been selected.
To use this feature:
Move the shift lever to L (Low).
Press the plus/minus button located on the shift lever, to increase or decrease the gear range available.
When you shift from D (Drive) to L (Low), the transmission will shift to a pre-determined lower gear range. The highest gear available for this pre-determined range is displayed next to the L in the DIC. See Driver Information Center (DIC) and DIC Operation and Displays for more information. The number displayed in the DIC is the highest gear that the transmission will be allowed to operate in. This means that all gears below that number are available. For example, when 4 (Fourth) is shown next to the L, 1 (First) through 4 (Fourth) gears are automatically shifted by the vehicle. the transmission will not shift into 5 (Fifth) until the + (Plus) button is used or you shift back into D (Drive).
While in L (Low), the transmission will prevent shifting to a lower gear range if the engine speed is too high. You have a brief period of time to slow the vehicle. If vehicle speed is not reduced within the time allowed, the lower gear range shift will not be completed. You must further slow the vehicle, then press the - (Minus) button to the desired lower gear range.
Automatic Engine Grade braking is not available when the ERS is active. It is available in D (Drive) for both normal and Tow/Haul mode. While using the ERS, cruise control and the tow/haul mode can be used. See Tow/Haul Mode for more information.
© 2017 General Motors Corporation. All rights reserved
Oct 09, 2017 | 2009 GMC Acadia
Can you record from a smart tv with arecording box
First of all you need to check if your TV supports recording. Some 2010 models do and most 2011 have it implemented. Look for stickers or logos such as:
  • USB Recording
  • PVR (Personal Video Recorder)
  • DVR (Digital Video Recorder
  • The following manufacturers support it in some of their models. Typically mid-end to high-end models. Check the manufacturer web site if you are unsure.
  • Samsung
  • Sony
  • LG
  • Philips
  • Panasonic
  • Toshiba
  • Sharp (only Time Shift pausing)
  • Grundig
    What you need
    Many consumers have USB recording enabled TVs without actually using the function - simply because it requires an extra USB hard drive ou need the following:
    1. USB Recording: A HDTV that supports recording.
    2. A USB HDD: FlatpanelsHD uses a USB HDD from Transcend.
    3. Digital channels: Recording is only enabled on digital channels - not analog. You can record SD, HD and 3D.
    Some manufacturers recommend USB hard drives with external power supplies but we have used a Trandscend USB HDD that takes power from the USB plug on all manufacturers' TVs without any problems. Manufacturers typically allow 1:1 recording, meaning that you will see no loss in picture quality.
    How to set up USB Recording
    Once you have purchased a USB hard drive and connected it on the back of the TV you can move on to "pairing" the USB HDD with the TV. Here is how to set up USB recording.
  • Connect the USB HDD to a free USB port on the back of the TV.
  • The USB hard drive now needs to be formatted (all data will be deleted).
  • Most TVs help you to format the USB HDD automatically but on some models you need to enter the menu and select format HDD (or something similar)
  • Sep 29, 2016 | Televison & Video
    I have a 93 jeep Cherokee, it will move in 4wh and in 4wl but will not go back into 2wd?
    Hello guy
    try posting what 4wd system you have,? first.
    command trac or select track, (the latter is full time)
    part time or the full time system,
    we cant guess it....
    read the operators guide first, if a part time system only
    as i suspect, stop driving on dry pavement.
    it's only for ice, or dirt. part time. part time is not a full time system.
    Command-Trac
    shifting to 4wd on dry (means no ice) pavement causes, drive line wind up! and the gears to lockup. (see steering get tight in turns?> and is dangerous to drive it like this , you, me and the box)
    posted here 100s of times.
    http://www.rubicon-trail.com/4WD101/driveline-bind.html
    the non grand Cherokee. early
    had these choices
    • 1987-2001: New Process NP231 Command-Trac, part-time only, 2.72:1 ratio with low range
    NP231 has the following settings: 2HI, 4HI, N, 4LO
    • 1987-2001: New Process NP242 Selec-Trac, full-time or part-time, 2.72:1 ratio with low range
    NP242 has the following settings: 2HI, 4 full-time, 4 part-time, N, 4LO
    as you can see you need to first know, what NP box you have or
    photo your shift lever for 4wd, an post it and we tell you.
    more facts, on select trac. (totally unlike command trac)
    Selec-Trac locking hub is used on 4WD Cherokee. Selec-Trac
    utilizes a non-disconnect front axle. Engagement of 2WD or 4WD is
    accomplished at transfer case by means of mechanical shift linkage.
    System allows full or part time 4WD. Selec-Trac can be shifted into
    2WD or 4WD modes from inside the vehicle at any speed.
    unquote
    next from the service manual,
    4WD TO 2WD
    1) Place mode select switch in 2WD position. Transfer case
    should shift to 2WD and not allow shifting into 4WD or LO range. Axle
    should shift after transfer case shifts.
    2) To determine if front axle has completed a shift out of
    4WD into 2WD, position mode select switch back to 4WD position while
    operating vehicle at slow speed. If vehicle shifts into 2WD, axle will
    ratchet. If shift is not completed, transfer case will shift into 4WD
    and hissing sound will come from mode select switch.
    end quote.
    if unsure read the FSM book its free.
    shows you both systems and how to diagnose it.
    in the box, click Cherokee,,then click 1993, and behold.
    the real deal.
    http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
    May 10, 2016 | Jeep Cars & Trucks
    Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
    http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
    DG-DABVPR1TB
    down load and put on a usb drive,
    DGTEC firmware 2011 updates available
    New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
    Please update software first before replacing hardware...
    From DGTEC Website Software Upgrades page: -
    Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
    Obsolete Products
    * DG-FV500PVR Upgrade (zip file 4.3Mb)
    * DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
    New Products
    DG-HDMP1080
    DG-HDMP1080P
    DG-HDMP1080TT
    DG-HDMP500TT
    DG-DABVPR1TB
    DG-DABPVR500GB
    DG-HD2104AND
    Models
    DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
    DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
    DG-HDMP1080 - HD MEDIA PLAYER
    DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
    DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
    DG-HDMP500TT - (NEW MODEL RELEASE)
    DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
    DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
    TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
    GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
    Note: - Master Override Password 1973
    Instructions:
    Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
    Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
    Plug USB Stick to USB port of PVR
    Connect Power to PVR and switch on so that that the booting process commences.
    Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
    Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
    Alternative Method
    1a. Disconnect mains power.
    2a. Plug USB Memory Stick to USB port.
    3a. Press and hold the CH down arrow button on the unit and then connect mains power.
    4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
    7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
    8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
    · Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
    Once the update has completed, reset the PVR by restoring back to Factory Default.
    Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
    Check Software Version, Press Menu ? Installation ? Version Info ? OK
    download and put on usb drive
    Software Updates
    Apr 11, 2015 | Televison & Video
    Blue creen with blinking cursor
    you can do a clean install from your usb. i use this setup for all my flash drive boots.
    WinSetupFromUSB - Install Windows XP from USB Flash Drive
    This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
    Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
    I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
    Prerequisites:
    All you need is:
    a USB Flash Drive with at least 1GB of storage
    the original Windows XP Setup CD
    WinSetupFromUSB
    If you use nLite to slim down your version of Windows XP, please keep the following in mind:
    DO NOT remove "Manual Install and Upgrade"
    under Operating System Options!
    I also recommend to integrate Service Pack 3 into your Windows XP source files.
    1. Preparations
    Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
    Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
    Content of WINXPCD
    The following files will show you, which Service Pack is already integrated into your CD:
    WIN51IC.SP1, Sevice Pack 1
    WIN51IC.SP2, Sevice Pack 2
    WIN51IC.SP3, Sevice Pack 3
    2. Start WinSetupFromUSB
    Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
    WinSetupFromUSB - main window
    3. Select your Source Path
    Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
    Browse to Folder
    Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
    WinSetupFromUSB - source path
    4. Format USB Flash Drive
    PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
    USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
    I will use PeToUSB to format my Kingston Data Traveler with 2GB.
    In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
    PeToUSB
    Click Start and answer the following two questions "Continue?" with Yes.
    All existing volumes and data will be lost!
    If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
    The process with HP Format Tool is similar.
    5. Copy Windows XP Source Files
    To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
    WinSetupFromUSB - file copy
    At the end the following notice about the Windows installation process should be displayed:
    WinSetupFromUSB - notice
    Click OK and close WinSetupFromUSB with EXIT.
    6. Windows Installation - Part 1
    Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
    The ESC key is used by ASUS for the Eee PC series.
    Other manufacturers may use other keys, e.g. F8 or F12.
    After booting from USB Flash Drive, the following menu should be displayed:
    Windows XP/2000/2003 Setup - First and Second parts
    Press Enter or wait 10 seconds to get to the next menu:
    First part of Windows XP Home Edition setup
    Second part of XP Home Edition setup+Start Windows for first time
    First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
    7. Windows Installation - Part 2
    After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
    Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
    8. Windows Installation - Part 3
    Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
    DO NOT disconnect the USB Flash Drive too early!
    At next startup you can boot into Windows from your hard disk.
    Notes:
    After successsful installation, the following boot menu will always be displayed during startup:
    Please select the operating system to start:
    Microsoft Windows XP Home Edition
    USB Repair NOT to Start Microsoft Windows XP Home Edition
    If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
    Open the file boot.ini in the root directory of drive C:\ with Notepad:
    [Boot Loader]timeout=30
    Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
    [Operating Systems]
    multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
    multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
    Delete the following line:
    DO NOT delete the wrong line!
    Your computer may not boot the next time!
    Save changes to the file.
    At next startup the boot menu will not be displayed.
    If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
    [Boot Loader]
    timeout=5
    At next startup the boot menu will be displayed only 5 seconds.
    gd luck
    Mar 09, 2014 | Computers & Internet
    My touchscreen goes wild. Its like its sort of 'lagging' a bit. When I touch somewhere on the screen it reacting in a whole other place. H
    May be you should try to restart your phone and reinstalling the firmware may also solve this if these options not work then you have to change your phones display screen
    Sep 05, 2013 | Apple iPhone Smartphone
    Bauhn Manual for APVR-9650T
    http://forums.whirlpool.net.au/archive/2211037
    Quoting from above:
    Bauhn 1TB PVR
    model APVR-9650T
    a REVIEW
    Spent a couple of hours with this PVR, comparing it with an earlier model Bauhn 1TB PVR (AS-PVR1000R, 2011).
    Bought on sale Wednesday, $199.
    [Only commented on differences between models. Have previously reviewed the older model - which still is a reasonably good PVR.]
    Summary: not bad, some good features in a budget PVR, and a couple of annoying issues that weren't in older models (which should be easy to fix in firmware). Works well, responsive remote, although I prefer the button press of earlier model.
    But product quality control is worryingly patchy. Bought 2 units, 1 was dead out of box!! Confirms my advice to buy 2 to get 1 that works well. (On power up with good broadcast signal, TV displayed Bauhn logo for few seconds, then blank screen, sound of HDD, and never advanced past "----" on PVR. Tried many times on different video outputs & TVs.)
    I'll probably be returning this PVR within 60 days as the few annoying aspects outweigh the added features for my needs, over my older BAUHN PVR.
    Features:
    Series Record:
    Records all programs with that title on that network. (Still assessing if SERIES RECORDs program on more than 1 network - e.g. records Simpsons on 10 & 11, but does it SERIES RECORD Mythbusters on SBS, as well as 7Mate?)
    Good if you are away from PVR as it changes recording times to latest EPG (as long as broadcast sticks to EPG times), if program schedule frequently changes, and does not record if program is dropped from schedule.
    (I have returned from overseas to find what I had set to record was not what was recorded as the program line-up had changed. SERIES RECORD should solve that.)
    But... takes up many available recording schedules including ones you may not want recorded (PVR has maximum of 50 TIMER schedules, so for example SERIES RECORD "QI" on ABC1 - with 13 episodes/wk, would occupy over ¼ of available schedules!).
    Also you cannot pad these recordings - adding a few minutes before/ after in case program starts early/ ends late. Changed recording time may conflict with other recording schedules meaning program may not record (check by EPG Search). Takes some getting used to to ensure consistent recordings.
    Setting up standard weekly etc TIMERS may be preferable & more predictable.
    EPG Search:
    Searches for all programs by title within 7 day EPG, on all channels. Shows & allows setup of recording schedule, and if there are conflicts between SERIES RECORD & recordings, to set Priority.
    Scheduled Recordings from EPG:
    Settings for recording Once, Daily, Weekly, Weekday/ Weekend.
    You can pad scheduled EPG recording times by up to only 10 minutes, in case program airs early/late.
    (The older 1000 model can pad up to many hours - e.g. to record multiple consecutive shows on 1 recording, and the recording date can be changed to skip that particular recording. You can manually set up recordings to achieve this on this PVR, but then lacks program name, which you can rename. An advantage if you are running out of schedule recording slots.)
    Time Shift:
    Up to 2 hours, which is adequate. Can set to always be on, so can pause/rewind live programs when you wish. (1000 model can be set to almost limitless Time Shift. Mine is set to 4 hours.)
    Editing Recordings:
    Editing would suggest removing unwanted sections, but this PVR simply marks sections of the recording for viewing, skipping the unwanted. The file remains the same size, and copying the file to another device leaves the original unedited recording.
    Settings:
    MENU-PVR Settings: (handy when setting up)
    Set Time Shift length (30-120 min) + Time Shift Function (Disable / Enable)
    Playback Start Position (Beginning of program / Continuing from where you were watching) Continuing is handy.
    Auto Play Next Program (Disable - stops playing at end at end of recording / Enable to watch recording then next recording )
    MENU-Settings:
    Audio&Video Output Settings
    (set to suit your TV etc)
    Time (by State & Daylight Saving - otherwise EPG & recording time will be incorrect)
    Channel List (press OK during live TV):
    Can delete unwanted channels (which the 1000 model annoying could not).
    Can set up 1 set of Favourite channels
    External USB Storage:
    2 USB (1 front, 1 rear) capable of accessing larger HDD (tried with 3TB) formatted as NTFS or FAT32. So quite useful, as I found on 1000 model.
    Copying is painfully slow. On 1000 model, crashes occurred when storage for recordings was set to a USB device (MENU-PVR-PVR Setting-Recording Storage) - don't do it!
    USB drives less than 16GB can't be formatted on PVR.
    WARNING: If PVR freezes (too high load on processor like copying too much or Copying + Recording) while writing to external HDD, HDD may be corrupted when you are forced to unplug PVR from power! (Have had Seagate HDD totally corrupted twice with 1000 model - files cannot be recovered due to storage method). Best not to copy too much at time to HDD!
    Networking: (Not assessed yet)
    Via Ethernet cable. Can access recordings, photos, music on PC, and transfer to PC from PVR. Access is typically MUCH faster than to USB storage. But requires files to be in set folder, which may be unsuitable.
    Media Player (Not assessed yet)
    Photo & Music Players have been added . Playing MP4 files is not great.
    Annoying aspects...
    OSD can't be hidden when using Pause
    Pausing live program, or recording leaves an information box on screen - there is no way to remove it. Pausing a recording is something I regularly do, to view details. The PAUSE bar includes the EDITING tools, making it larger than normal. As the on-screen-display covers nearly 20% of the screen, at the bottom, subtitles and information bars broadcast with the program can't be seen! You can only increase the Transparency, meaning you can see through the OSD (MENU-Settings-PVR Setting 1-60%). However, setting a high level of Transparency makes using any OSD difficult.
    Slow boot time
    It takes about 35 seconds to.power up from Standby to fully operational. While that is marginally faster than the older 1000 model, it is slow.
    Slow navigation within EPG, Timer & Media Browser etc
    There are no P+/P- (Page up/down) buttons as on 1000 model. Moving up/down a list to select between possibly hundreds of programs (recordings) is SO slow - moving 1 at a time instead of a page at a time. (Strangely the P+/P- can still be found in the onscreen keyboard when you Rename recordings or do an EPG Search. There it performs a keyboard shift function.)
    Slow navigation within Recordings & Time Shift TV
    FF/REW speed is a maximum of 32X, against 64X on 1000 model.
    There is a very handy undocumented feature of FF/REW by holding down the right/left arrows - located around the circular OK button (while watching your time position on the progress bar). Handy for moving quickly to position in program or skipping ads. (I found this on the earlier 500 & 1000 models.) However it is SO much slower to FF/REW on this model.
    Bright Standby light
    As in the older model, the very bright blue light can be annoying, but easily fixed with a small piece of black electrical tape or similar.
    PVRs take time to discover their flaws & features, so I'll keep exploring ;-)
    Aug 10, 2013 | Cell Phones
    Usb on bd610 lg won't work
    I don't understand this term: "choose either dvd or usb menu". Do you mean instead ""choose either dvd or cd menu? I've used many usb hard drives and I've never seen such a "menu".
    Feb 27, 2013 | LG BD610 BRay Disc Player
    My check engine light its on.. on my 06 mini cooper.. the codes are p1787, and 1698... can someone let me know what this means??
    P1787 AUTO box ecu failure
    P1698 Bipolar stepper motor short circuit
    It can also mean that you must carry out an auto-box relear procedure
    Try this and get back to us :-
    BMW MINI P1698 and P1787
    Mini Cooper Transmission Relearn Procedure
    If the gear selection display on your Mini Cooper has an x before the gear selected,
    like xP or xD or xR, then you need to run this procedure.
    The usual cause of this is a dead or disconnected battery for a long period of time.
    First make sure you have a good battery that will hold a charge or fix the charging
    system problem.
    Get the car someplace where you will be able to drive for a mile or two without
    interruption on a fairly level road.
    Follow ALL steps and don't skip anything.
    Clutch Adaptation
    1. Begin with a cold engine and start the car. Shift to N for 10 seconds, then shift
    to D for 10 seconds.
    Shift to P. Display says xP.
    2. Repeat the following ten times. Shift to N for 3 seconds, then shift to D for 3
    seconds.
    3. Repeat the following ten times. Shift to N for 3 seconds, then shift to R for 3
    seconds.
    Step-up Ratio Adaptation
    1. Accelerate vehicle to a speed greater than 80 km/h. Don't be afraid to go above
    the redline on the tach for a few seconds. At this point the car may buck and snort
    a little as it tries to get into a higher ratio. As soon as it settles into a higher
    gear and the revs are above 4500, rpm let off the accelerator quickly. Don
    Mar 08, 2011 | 2006 BMW Mini
    Pontiac Aztek Hard Shifts (From 1 to 2) When Cold and No Speed!
    check your transmission fluids or have the transmission flushed..you supposed to do that at least once a year!!
    May 24, 2009 | 2001 Pontiac Aztek
    Computers & Internet Logo
    57 people viewed this question
    David Payne
    David Payne
