I need a user a maintenance manual fora Slide projector
The slide advancer stucks and doesnt return slides probably needs a missing part: I dont know.
  • kakima Nov 09, 2014
    What make and model?
    President:
  • 412 Answers
Kodak Service Manuals and Parts Lists will be tough to find.... but check with: www.micro-tools.com
They bought the entire service parts inventory from Kodak when Kodak decided to stop supporting slide projectors.
Good Luck !! Jim
Posted on Jan 21, 2015
  • 412 Answers
SOURCE: I bought a used kodak
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: Kodak 750H and 760H neither will advance carolsel without manual
Both of these models were manufactured by KODAK between 1971 and 1981 (roughly). My guess is that they both have the same failure: The "link" that connects the cycle solenoid to the slide change mechanism is broken. This "link" is plastic, and gets brittle & cracks over time. While parts are still available, this repair is best done by a factory-trained tech with the service manuals.
  • 412 Answers
This is a common problem with older projectors like this. There is a "link" that connects the slide cycle solenoid to the slide change mechanism. The "link" is plastic and gets brittle & cracks with age, rendering cycling non-functional. this is a difficult repair, but parts are still available. I recommend you contact an factory-trained repair dealer to get your projectors repaired.
Posted on Nov 21, 2010
  • 412 Answers
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: No manual or remote advance on kodak 35mm carosel
You didn't specify the model, but chances are that the cycling problem is caused by a broken "link". The "link" connects the cycle solenoid plunger to the slide change mechanism. The "link" is made of plastic, and gets brittle & cracks over time, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair requiring disassembly & a service manual - - best left to a factory-trained repair dealer.
Posted on Jan 04, 2011
The carousel in my slide projector is stuck
I presume you are talking about a kodak projector. Look down into the center of the slide tray as it sits on the projector. There may be a small slot. Get a quarter, put it in the slot and turn it clockwise (?) a little, then lift the end of the tray furthest from the stuck slide. The tray should lift away. WITH THE RING ON, turn the tray over and rotate the metal bottom of the tray until it clicks, returning it to the "zero" position. Turn off the projector (if it's on) and retrieve the slide. Turn the projector on and hit the FWD button to get the arm situated correctly.
Dec 29, 2014 | Office Equipment & Supplies
Can't get slide projector to focus with lens in projector
Check the lenses inside the lens tube and see if they are loose or out of place
Feb 05, 2014 | Kodak 4200 Slide Projector
Can I advance my tray manually?
WOW!! A model 600 !! That model was manufactured between 1964 & 1972. As the "entry-level" model projector, Kodak made it without a lot of the conveniences higher-featured models had. In order to advance the tray, a light touch of the SELECT BAR was required. There is no REVERSE function. If you hold the select bar down too long, the mechanism will "EJECT" the slide (and if you release the select bar, the slide will return to the optical gate. I hope this answers your question!! Good Luck !! Jim
Aug 08, 2013 | Kodak Carousel 600 Slide Projector
Sears tower projector jammed up. Need to know how to access the stuck slide
This should help
Apr 04, 2013 | Office Equipment & Supplies
Shutter stuck on Ektagrahpic III projector
First of all, the shutter will only open IF there is a slide in the gate. Assuming there is a slide in the gate, there are 2 things that could be preventing the shutter from opening:
1. Most likely - the shutter is spring-loaded. If the spring unhooks or is missing, the shutter will not open.
2. There is an adjustment that needs to be made after the spring is replaced or re-hooked (or just is out of adjustment. Refer to the Kodak Ektagraphic Service Manual @ the Kodak web site: http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf
Good Luck! Jim
Aug 18, 2012 | Kodak Ektagraphic III ATS Slide Projector
I just dragged this projector out of my grandma's basement. I have a new bulb and the projector appears to be in working condition except for the slide advance--the slides advance continuously. How...
There is usually a sliding tab on the side of the projector (behind the handle) that toggles between "manual" and "automatic" advance. (Some models will have a couple of pre-set advance settings between "manual" and "automatic." These usually advance the slides every three to ten seconds.) Push the tab to the manual setting--this will allow you to use the buttons towards the front of the machine to advance your slides.If moving the tab doesn't work it may be broken or jammed.
Jul 29, 2011 | Kodak Carousel 4400 Slide Projector
Slide tray does not advance and slide does not stay in proper position
If the slide tray does not advance or reverse, the slide will not go into the optical "gate" AND the "SELECT" function doesn't work, then chances are that you have a broken mechanism drive belt. The good news is there are all kinds of projector parts still available at: www.micro-tools.com The bad news is that unless you have a service manual and have been into a projector before, this is probably a repair best left to a factory-trained repair dealer.
Jan 22, 2011 | Kodak Carousel 5600 Slide Projector
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Will not advance although nothing is stuck in the machine.
Sounds like what your projector needs is a cycle contact adjustment.
Remove the slide tray & lamp module. Unplug the projector. Turn the projector upside down to remove the bottom cover (6 - T-15 TORX screws). Pry the bottom cover off from the handle side (Be careful!! The power cord is physically secured to the bottom cover!). I have attached an illustration for reference. Near the center of the projector you will find a contact as shown in the illustration. That contact needs to be in the position shown on the pad. You will have to slightly bend the "J"-shaped wire carefully(!!). Then plug the projector in, turn it on & cycle it a few times. The 2 contacts should look like the illustration when at rest. If they don't look like that, unplug the projector, "tweak" the contact wire a little bit more, plug the projector in & try again. This adjustment can take a factory-trained repair tech several bends to get it right (without breaking off the wire!!). Repeat until you are successful! jauburn_8.jpg
Apr 19, 2009 | Kodak Carousel 4400 Slide Projector
252 people viewed this question
jasbo
jasbo
