Question about Vehicle Parts & Accessories
How do I reprogram a Command start for my car
I have a command start remote open,start,lock system on my Toyota but it needs reprogramming. It was installed in 1999.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If it IS an after market system you will have to find the manufacture and they will have to tell you. If it was installed by the dealer this would most likley be an after market system. If it came from the manufacture like this, you will need to get with the dealer
Posted on Nov 09, 2014
Saab experts
May be keyfob needs reprogramming.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There are few much related troubleshooting links mentioned below for remote key fob reprogramming. I suggest you to go through the list and click the link below to go through its details and procedure: -------
Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2009 Toyota Highlander: Smart Key Not getting Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Peugeot 206 key fob
Try with brand new key fob battery and see.If that helps.
Otherwise May be keyfob needs to be reprogrammed.
KEYFOB PROGRAMMING
Thanks.
Nov 28, 2012 | Peugeot Cars & Trucks
How program the key remot
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting Detected? http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob? http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
----------- Pin that holds the flick key part to the key fob? http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar? http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
----------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
Mitsubishi Car Key Not getting detected after replacing ECM http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
----------- Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not Working? http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
----------- Chevrolet Malibu: Key Stuck in ON position? http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
----------- Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not release? http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
Nov 23, 2012 | 2006 Toyota Tacoma
My panasonic dvd recorder / remote control is not working On pressing button on remote I get dvd2 on recorder screen but no other response. I have tried reset without effect
Try reprogramming the remote itself; i.e. point remote at unit (while on), press and hold the [2] and [ENTER/OK] buttons together for 5 - 10 seconds, then release. The remote's command should now match that of the unit (DVD 2) (the unit should now recognise the remote). Failing that, remove batteries from remote, replace with new ones (just in case) and repeat the above suggestion. You should not need to reset the main unit.
Whenever the batteries are replaced in Panasonic remotes, in some cases, a remote command reprogram is often required to ensure that the remote commands the unit fully and correctly. You may find this procedure outlined in your instruction manual. Hope this helps a tad.
Aug 14, 2011 | Televison & Video
The remote to unlock the doors won't work. replaced battery. the key will not unlock driver or passenger door or the trunk
I hope you're able to get into your car because it sounds like the system needs to be reprogrammed.
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
Aug 11, 2009 | 2005 Toyota Corolla
My central lock remote stopped working
It shouldn't need to be reprogrammed; it probably only needs a battery. The case either pries open with a coin or screwdriver; it might have a small phillips screw on the back. If it does need reprogramming, pull into your friendly Toyota dealer, they do it with a computer.
Mar 17, 2009 | 1997 Toyota Camry
Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Feb 21, 2009 | 2005 Toyota Camry Solara
Command start will not work
the remote probably needs to be reprogrammed.........if you could give manufacturer name and model number i could find some instructions for you.....or if you have it refer to your owners manual for the starter
hope this helps!
Jan 05, 2009 | 1994 Chevrolet K1500
Valet 473T remote
It sounds like the system needs tach sensor reprogramming. The remote start system may have a tachometer sensing mode where the system "knows" that the car is running and to stop cranking the starter when when the engine is running. Generally when the vehicles battery is disconnected the system "forgets" the setting of the tachometer at idle which is programmed at the time if installation. Take it to a remote start installation store for this or get a hold of a maual for your system and shouldnt be too dificult to program.
Jan 20, 2008 | Directed 473T Remote Control
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
